		ptiller(at)lolacars.com Guest
				 Posted: Thu Jan 25, 2007 5:47 am    Post subject: Main monowheel tyre |
				Hi,
 I've acquired yet more wheels and tyres and so need to decide on one.
 Given a choice of the following main mono tyres, which do the 'mono-drivers' on this list recommend?
 a.   7.00-6   McCreary Air Trac,  6 ply
 b.   8.00-6   Titan Turf Glide,  4 ply   (this appears to be identical in appearance and spec to the Carlisle 'Turf Glide' so I guess Carlisle took on the production).
 My guess is to stick with the McCreary that has already been recommended.  What do others think?
 Visit -  www.EuropaOwners.org
		johnwigney(at)alltel.net Guest
				 Posted: Thu Jan 25, 2007 8:35 am    Post subject: Main monowheel tyre |
				Hi Phil,
 FWIW, I  have used a McCreary Air Trac, 7.00-6, 6 ply with very
 satisfactory service. Total time is 520 hours over 5 years and
 approximately 760 landings. The majority have been on asphalt with just
 a few on grass. I keep my tire at 18-20 psi. Higher pressures tend to
 make for 'squirelly' landings on asphalt. I will be replacing the tire
 with an identical tire when I do my annual in a month or so because of
 uniform tread wear. The grooves are still showing but there not much to go.
 It is possible that you may have trouble with clearance in the tunnel if
 you use a larger tire. Also, I do not think the Turf Glide was designed
 for aircraft use and wear may be a problem.
 Cheers, John
 N262WF, mono XS, 912S
 Mooresville, North Carolina
  	  | Quote: | 	 		  From "flyingphil2" <ptiller(at)lolacars.com>
 the production).
 do others think?
		gcrowder2
  Joined: 09 Jan 2006 Posts: 136 Location: Golden, Colorado USA
				 Posted: Thu Jan 25, 2007 9:47 am    Post subject: Main monowheel tyre |
				I use the same tire on my EA81 powered mono, very happy with it so far.  I
 might be
 inclined to try a McCreary 8.00 x 6 if I knew it would fit and get a smidgen
 more ground
 clearance, maybe even allow a 68" prop for more efficiency.
                                                       Glenn
  	  | Quote: | 	 		  From: John & Paddy Wigney <johnwigney(at)alltel.net>
 Reply-To: europa-list(at)matronics.com
 To: ptiller(at)lolacars.com, Europa-List <europa-list(at)matronics.com>
 Subject: Re: Main monowheel tyre
 Date: Thu, 25 Jan 2007 11:33:10 -0500
 Hi Phil,
 approximately 760 landings. The majority have been on asphalt with just a
 few on grass. I keep my tire at 18-20 psi. Higher pressures tend to make
 for 'squirelly' landings on asphalt. I will be replacing the tire with an
 identical tire when I do my annual in a month or so because of uniform
 you use a larger tire. Also, I do not think the Turf Glide was designed for
 Cheers, John
 on the production).
 What do others think? *******************
 Get Hilary Duff’s homepage with her photos, music, and more.
 http://celebrities.live.com
		96victor(at)gmail.com Guest
				 Posted: Thu Jan 25, 2007 2:03 pm    Post subject: Main monowheel tyre |
				Hi Glen
  I have a 800 - 6 in my mono.  It was a tight fit.
  Tom Friedland
  On 1/25/07, GLENN CROWDER <gcrowder2(at)hotmail.com (gcrowder2(at)hotmail.com)> wrote: [quote]--> Europa-List message posted by: "GLENN CROWDER" < gcrowder2(at)hotmail.com (gcrowder2(at)hotmail.com)>
 might be
 more ground
                                                      Glenn
  	  | Quote: | 	 		  From: John & Paddy Wigney <johnwigney(at)alltel.net  (johnwigney(at)alltel.net)>
 Reply-To: europa-list(at)matronics.com (europa-list(at)matronics.com)
 To: ptiller(at)lolacars.com (ptiller(at)lolacars.com), Europa-List < europa-list(at)matronics.com (europa-list(at)matronics.com)>
 --> Europa-List message posted by: John & Paddy Wigney
 < johnwigney(at)alltel.net (johnwigney(at)alltel.net)>
 Hi Phil,
 Cheers, John
 >From "flyingphil2" < ptiller(at)lolacars.com (ptiller(at)lolacars.com)>
  >on the production).
  	  | Quote: | 	 		  My guess is to stick with the McCreary that has already been recommended.
		gcrowder2
				 Posted: Thu Jan 25, 2007 5:11 pm    Post subject: Main monowheel tyre |
				Hi Tom - What tire pressure do you use and have you experienced any rubbing
 on undercarraige components?  Did it give you any more prop clearance?
 Inquiring minds yada yada!
                                          Glenn
  	  | Quote: | 	 		  From: "Tom Friedland" <96victor(at)gmail.com>
 Subject: Re: Re: Main monowheel tyre
 Date: Thu, 25 Jan 2007 14:01:57 -0800
 Hi Glen
 Tom Friedland
 >might be
 >smidgen
 >more ground
 >                                                      Glenn
 > >Hi Phil,
 >a
 >an
 >for
 > >Cheers, John
 >in
 >took
 > >on the production).
 >recommended.
 >_________________________________________________________________
 >Get Hilary Duff's homepage with her photos, music, and more.
 Get in the mood for Valentine's Day. View photos, recipes and more on your
 Live.com page.
 http://www.live.com/?addTemplate=ValentinesDay&ocid=T001MSN30A0701
				 Posted: Thu Jan 25, 2007 7:07 pm    Post subject: Main monowheel tyre |
				Hi Glen
  Hmm,  not quite flying yet so can't answer some Q's.  No rubbing with retraction.  Prop clearance difference?  Don't know because I didn't have a prop then but geometry says that it must be increased!  Tire pressure?  I'll probably start out with about 18psi.  Have you other suggestions?
  Tom N96V
                                          Glenn
  	  | Quote: | 	 		  > >
 > >Hi Phil,
 >a
 >an
 >for
 > >Cheers, John
 >in
  	  | Quote: | 	 		  >took
 > >on the production).
  >>recommended.
  	  | Quote: | 	 		  > >What do others think? *******************
 Live.com page.
		gcrowder2
				 Posted: Thu Jan 25, 2007 10:35 pm    Post subject: Main monowheel tyre |
				Hi Tom - The mono with the 8.00 x 6 could be slightly easier to land (its
 very easy now and
 I'm a very low time tail dragger pilot) with a little higher deck angle.
 This should allow the a/c to be
 more stalled when the main wheel contacts which could reduce the minor
 bouncing you get if
 you land a little too flat.  Its not even a problem now, its just the
 technique you learn.  If you
 find yourself bouncing your landings, you just didn't land with the tail
 quite low enough.  I rarely
 get any bounce at all except maybe in gusty conditions.
   Does it look like the tire could contact the landing gear frame in a
 slightly sideways landing?
 How much clearance is there at 18 psi?
                                                  Glenn
 Date: Thu, 25 Jan 2007 19:06:58 -0800
 Hi Glen
 I'll
 Tom N96V
 >rubbing
 >                                         Glenn
 > >Hi Glen
 > >Tom Friedland
 >far.  I
 > >>might be
 > >>smidgen
 > >>more ground
 > >>                                                      Glenn
 > >> >Hi Phil,
 >just
 > >>a
 >make
 >with
 > >>an
 >uniform
 >if
 >designed
 > >>for
 > >> >Cheers, John
 >identical
 > >>in
 > >>took
 > >> >on the production).
 > >>recommended.
 >Live.com page.
 Valentine’s Day -- Shop for gifts that spell L-O-V-E at MSN Shopping
 http://shopping.msn.com/content/shp/?ctId=8323,ptnrid=37,ptnrdata 4095&tcode=wlmtagline
				 Posted: Fri Jan 26, 2007 3:05 pm    Post subject: Main monowheel tyre |
				I have over 2000 hours of tailwheel time in Cessna 140s up to DeHavilan Otters and some in a DC 3 but none for 40 years...  I am a little aprehensious but will probably be just fine.
  There is over an inch of clearance from the tire to the sides of the tunnel so misalined landings should not cause rubbing or binding but they can sure cause other bad things.
  Tom
 very easy now and
 bouncing you get if
                                                 Glenn
  	  | Quote: | 	 		  From: "Tom Friedland" <96victor(at)gmail.com (96victor(at)gmail.com)>
 Hi Glen
 I'll
 Tom N96V
 On 1/25/07, GLENN CROWDER <gcrowder2(at)hotmail.com (gcrowder2(at)hotmail.com) > wrote:
 >--> Europa-List message posted by: "GLENN CROWDER" <gcrowder2(at)hotmail.com (gcrowder2(at)hotmail.com)>
 >rubbing
 >                                         Glenn
 > >Hi Glen
 > >Tom Friedland
 > >On 1/25/07, GLENN CROWDER < gcrowder2(at)hotmail.com (gcrowder2(at)hotmail.com)> wrote:
 >far.  I
 > >>might be
 > >>smidgen
 > >>more ground
 > >>                                                      Glenn
 > >> >To: ptiller(at)lolacars.com (ptiller(at)lolacars.com), Europa-List <europa-list(at)matronics.com (europa-list(at)matronics.com)>
 > >> >Hi Phil,
 >just
 > >>a
 >make
 >with
 > >>an
 >uniform
 >if
 >designed
 > >>for
 > >> >Cheers, John
 > >> >>From "flyingphil2" <ptiller(at)lolacars.com (ptiller(at)lolacars.com)>
 >identical
 > >>in
 > >>took
 > >> >on the production).
 > >>recommended.
 Valentine's Day -- Shop for gifts that spell L-O-V-E at MSN Shopping
				 Posted: Fri Jan 26, 2007 3:53 pm    Post subject: Main monowheel tyre |
				Tom
 you were obviously very well trained, I would love to have flown a DC3,
 a most admirable airplane. You will however need to be very quick on the
 pedals with the Europa. It's not like a long wing glider, unless you are
 lucky and have the long wings. You need to read its mind and react
 before it does then avoid overcontrolling.
 Currency is the key, I know I'm not current any more. Last time I tried
 a Europa landing on tarmac I ended up essing down the runway. (My
 previous landing was 5 years earlier.
 Graham
 Tom Friedland wrote:
  	  | Quote: | 	 		   I have over 2000 hours of tailwheel time in Cessna 140s up to DeHavilan
  Tom
		gcrowder2
				 Posted: Fri Jan 26, 2007 8:53 pm    Post subject: Main monowheel tyre |
				Geez Graham, I'm not saying you're wrong but I just can't fathom what
 you're referring to.
 I did a few swerved landings when I was first training on the mono but
 really none since then for several hundred landings.  Every time I hear this
 stuff I get really tensed up for the next flying session and wait for bad
 things to happen but it always floats in like a pussycat with no
 theatrics required.   Most landings I don't touch the pedals at all, maybe
 slight pressures.  Maybe you were flying a poor example or I'm flying a very
 good example, just makes no sense!
   Possibly your a/c was much lighter than mine.  I can see where that could
 be an explanation.
                                            Glenn
  	  | Quote: | 	 		  From: Graham Singleton <grahamsingleton(at)btinternet.com>
 Date: Fri, 26 Jan 2007 23:51:51 +0000
 Tom
 you were obviously very well trained, I would love to have flown a DC3, a
 lucky and have the long wings. You need to read its mind and react before
 Currency is the key, I know I'm not current any more. Last time I tried a
 Europa landing on tarmac I ended up essing down the runway. (My previous
 Graham
 >  Tom
 Check out all that glitters with the MSN Entertainment Guide to the Academy
 Awards®   http://movies.msn.com/movies/oscars2007/?icid=ncoscartagline2
		Kevin Klinefelter
				 Posted: Sat Jan 27, 2007 5:23 am    Post subject: Main monowheel tyre |
				Perhaps Graham is recalling experiences with the original tailwheel
 setup as opposed to the XS?
 Kevin
 GLENN CROWDER wrote:
  hear this stuff I get really tensed up for the next flying session and
  wait for bad things to happen but it always floats in like a pussycat
  with no
  maybe slight pressures.  Maybe you were flying a poor example or I'm
  flying a very good example, just makes no sense!
  could be an explanation.
                                            Glenn
 > Tom
 > DC3, a most admirable airplane. You will however need to be very
 > quick on the pedals with the Europa. It's not like a long wing
 > glider, unless you are lucky and have the long wings. You need to
 > read its mind and react before it does then avoid overcontrolling.
 > tried a Europa landing on tarmac I ended up essing down the runway.
 > (My previous landing was 5 years earlier.
 > Graham
 >>  Tom
  Academy Awards®
  _________________ Europa XS, Mono Wheel N211KA
Intercooled 914, Airmaster Prop |
				 Posted: Sat Jan 27, 2007 10:27 am    Post subject: Main monowheel tyre |
				kind thought Kevin, but no it was an XS tailwheel. I had 150 hours on
 the old tailwheel and never groundlooped it. Did a fair bit of bouncing
 though.
 Graham
 Kevin And Ann Klinefelter wrote:
  <kevann(at)verizon.net>
  Kevin9582005
				 Posted: Sat Jan 27, 2007 11:14 am    Post subject: Main monowheel tyre |
				Hi Glenn
 I'm never wrong but I'm not always right ?
 That particular Classic (with XS tailwheel) was not particularly good, I
 must admit but I have found that they are all different, sometimes
 surprisingly so.
 Europa Monowheels are certainly much less docile on the ground than a
 Supercub. You just have to be very quick with your eyes and feet.
 I am beginning to slow down a bit, can't drive as well as I used to
 since I lost one eye.
 Odd but I suspect that the memory devoted to that eye is now not used
 which slows down the computer between my ears.
 Graham
                                            Glenn
		gcrowder2
				 Posted: Sat Jan 27, 2007 12:37 pm    Post subject: Main monowheel tyre |
				I've heard that Supercubs are very easy.  The only other taildraggers I've
 had
 time in were a brand new Citabria (Adventure) and a Champ.  The Champ I
 flew was a total snake and I wouldn't fly again if you paid me and the
 Citabria was fun but I found myself concentrating much harder than the
 Europa.
   Somewhat roll instable even well after touch down and had to fly it to a
 stop.
 One of the wings is always trying to lift.
   The mono seems very damped in yaw on the ground and action on the ground
 is just
 gentle pressures.  It does seem to lose some directional stability under 35
 mph after
 the rudder quits working but just seems to start drifting slightly to the
 left or right after
 it slows down.  I have never had a wing lift after touchdown.  Its fun to
 taxi at 40 mph
 with both outriggers lifting off the ground.  Feels like riding a motorcyle
 with training
 wheels!
                                                  Glenn
 Date: Sat, 27 Jan 2007 19:12:54 +0000
 Hi Glenn
 surprisingly so.
 I am beginning to slow down a bit, can't drive as well as I used to since I
 lost one eye.
 Odd but I suspect that the memory devoted to that eye is now not used which
 Graham
 >                                           Glenn
 Live.com page.
				 Posted: Sat Jan 27, 2007 2:24 pm    Post subject: Main monowheel tyre |
				Who was it said that taildraggers with toe in were snakes? Toe out is OL
 and makes them stable. How do you arrange toe out with a monowheel?
 Graham
    The Champ I
  	  | Quote: | 	 		   flew was a total snake and I wouldn't fly again if you paid me and the
  Europa.
  a stop.
		garrys(at)tampabay.rr.com Guest
				 Posted: Sat Jan 27, 2007 3:16 pm    Post subject: Main monowheel tyre |
				Better yet.........how do you adjust toe-in and toe-out on a Europa trigear?
 Garry Stout
  Graham
    The Champ I
 > Europa.
 > stop.
				 Posted: Sat Jan 27, 2007 3:58 pm    Post subject: Main monowheel tyre |
				Good question. Get it right first time or Redesign it?
 Graham
 Garry wrote:
  trigear?
  Garry Stout
		h&jeuropa
				 Posted: Sat Jan 27, 2007 5:17 pm    Post subject: Re: Main monowheel tyre |
				We started with the 8.00 - 6 tire (or tyre) that came with the kit.  Ran it at 18 psi.  After doing max gross weight flight tests (1500 lbs), we noticed that the brake caliper was machining a nice groove in the tire.  The tire also rubbed the inside of the swing arm and it was very close in the tunnel ( we had moved the brake master cylinder to get more clearance).  So at that time we changed to 7.00 -6 like many others.  We think the plane is a little more stable with this tire.  Also no problem with the brake caliper hitting at max gross weight.
 The plane is easy to land on grass.  As Graham can attest, we don't do so well on pavement (major ground loop requiring a lot of repair).  Have been flying a Champ lately, and our Europa is not as easy to land as the Champ.  You really have to look down the runway and keep it straight.
 Jim & Heather
 N241BW
		Kevin Klinefelter
				 Posted: Sat Jan 27, 2007 7:43 pm    Post subject: Main monowheel tyre |
				How do you arrange toe out with a monowheel? You get a tire with
 funny-looking tread!
 Kevin
 Graham Singleton wrote:
  OL and makes them stable. How do you arrange toe out with a monowheel?
  Graham
    The Champ I
 > the Europa.
 > to a stop.
