f.miskelly(at)imperial.ac Guest
Posted: Sun Jan 28, 2007 3:03 am Post subject: Jack plug question (shielded wires) |
Hi Bob
My harness linking the radio to microphone and headphone jacks do not have shielding. Neither does the positive supply or the PTT switch wires. From another thread on this forum 'shielded wires' i see others use shielded wires in this situation. Your link below recommends shielded wires. Other points are: There is substantial interference in the radio and I wonder are shielded wires more important in a composite aircraft?
My questions are
a) Is there a method of testing whether a wire should be shielded eg wrap in aluminium foil to see the effect on the interference?
b) Do you think it is worth the hassle to return the full harness and ask them to replace the wires to the jacks, the PTT and the positive supply with shielded wires?
Many thanks
Frank
From: owner-aeroelectric-list-server(at)matronics.com on behalf of Miskelly, Francis G
Sent: Wed 24/01/2007 17:16
Subject: RE: RE: Jack plug question
Many thanks Bob.
The schematic in your link shows the harness linking the radio to the microphone jack is shielded. Not sure if mine is but will check.
I'm afraid i don't have a wiring diagram - they wouldn't give me one. Contacted the technician who did the wiring harness several times and he was vague about the need for a ground. Maybe he thought i had a metal panel or maybe he didn't understand the wiring and was just doing as he was told?
Think i'll install an earth on the microphone jack anyway. I presume it won't do any harm and may solve the problem. Also check the shielding
Thanks again
Frank
From: owner-aeroelectric-list-server(at)matronics.com on behalf of Robert L. Nuckolls, III
Sent: Wed 24/01/2007 05:40
At 03:10 PM 1/22/2007 +0000, you wrote:
| Quote: | Thanks Bob.
The KX155 is 6 months old. This problem has been there from the beginning.
It came with harness pre-wired and i installed it. Sometimes i use a
handheld (ICOM A20) wired into the a/c power supply and aerial and there's
some ignition noise but not a serious problem. Its just the panel mounted
KX155. The microphone jack interferes with the volume (even with the
squelch turned off) and introduces interference
Two possibles i thought of were
1. The microphone socket may need an earth? The panel is fibreglass and
the socket has 2 wires running into it but is not earthed to the airframe
2. Could the wires in the microphone socket be transposed?
As the ICOM works OK that seems to exclude power supply or aerial issues?
Very grateful for your advice.
Frank
If the push to talk circuit is active in your
microphone wiring, then the mic jack would need
two wires plus a ground. See:
http://aeroelectric.com/articles/micjack/micjack.html
If your mic jack is intended to handle ONLY
microphone audio and PTT is handled with other
wiring, then only two wires would be required.
Do you have a schematic of the pre-wired harness?
Have you checked your harness against the diagram?
nuckollsr(at)cox.net Guest
Posted: Sun Jan 28, 2007 4:58 am Post subject: Jack plug question (shielded wires) |
At 11:01 AM 1/28/2007 +0000, you wrote:
| Quote: | Hi Bob
My questions are
I gotta tell you that shielding used on most wires in small
aircraft has only a modicum if not zero benefits. The lengths
of wires used to run between various black boxes and other
components of a system are so short and the list of potential
antagonists of the kind that are held at bay by shields is
also tiny if not zero.
The headphone and mic wiring of our radios will run just fine
with twisted pairs or trios of wires. Having said that, I use
a lot of shielded wire here in the shop and in some installations
not because the shielding is necessary but because the wire
is mechanically and logistically handy. I have off-the-spool,
multi-conductor cables that are easy to use and have a sort
of universal applicability.
But here's the rub on a schematic or wiring diagram . . .
there's nothing in the diagram that tells us how long any
run of wire is nor what bundles that wire shares with other
systems. One system installed in a C-150 would be at zero
risk for electro-statically conducted noise in the C-150
where the interconnected devices are inches apart but an
entirely different matter when the same electro-whizzy is
installed in bizjet with the two boxes perhaps several feet
apart and the wires run in bundles with other, potentially
antagonistic systems that don't even exist in the C-150.
So the rule of thumb is, if there's any risk at any time
for any possible installation for conduction of electro-
static noise into a potential victim wire - shield it.
The cost-delta for using shielded versus unshielded wire
in a production environment is trivial . . . it's disappointing
that the folks who made your harness "skimped" on this
but their perceptions of low-risk are not incorrect. I'd
leave the harness alone unless you DO experience a noise
problem. Because you're more likely to have a problem due
to poor attention to ground systems than because any
one set of wires was not shielded.
Give me the name of the company that did your harness
and their phone number. If you have the name of the technician
you talked to, I need his/her name too. I'll give them a
call and see about shaking loose some data. There's no
excuse for not supplying everything you need to know about
a product they supplied to you.
Posted: Sun Jan 28, 2007 1:04 pm Post subject: Jack plug question (shielded wires) |
Thanks for the offer (and explanation) Bob but i'm based in London, England and the harness was supplied by Harry Mendelssohn in Edinburgh, Scotland www.gps.co.uk
I'm sure you're correct the problems is grounds rather than the harness. You don't need to be on this forum long to realise the importance of grounds. I tried to get a schematic but they said King didn't supply schematics for customers.
For info (rather than action) their tel is 0044 131 447 7777 and technician is Danny.
I'll focus on the grounds and leave harness for now.
Thanks again
Frank
Sent: Sun 28/01/2007 12:57
Subject: RE: RE: Jack plug question (shielded wires)
| Quote: | Hi Bob
My questions are
wgill10(at)comcast.net Guest
Posted: Sun Jan 28, 2007 1:27 pm Post subject: Jack plug question (shielded wires) |
What schematics do you need Frank? I may have something I can email to
you.
Bill
Posted: Sun Jan 28, 2007 1:48 pm Post subject: Jack plug question (shielded wires) |
Thanks Bill.
Its a KX 155 installation manual. Esp the wiring diagram. If that's possible it would be great!
Frank
From: owner-aeroelectric-list-server(at)matronics.com on behalf of William Gill
Sent: Sun 28/01/2007 21:27
you.
Bill
Posted: Sun Jan 28, 2007 3:14 pm Post subject: Jack plug question (shielded wires) |
At 03:27 PM 1/28/2007 -0600, you wrote:
you.
Bill
Bill, if you have a KX-155 manual and can scan
the wiring diagrams, I'd be pleased to add them
to my website's installation data.
maurv8(at)bresnan.net Guest
Posted: Sun Jan 28, 2007 4:34 pm Post subject: Jack plug question (shielded wires) |
Bob,
I have a complete KX-155/165 installation manual I would gladly mail to you as I no longer have a need for it, if you want it
Mauri Morin
Polson, MT
RV-8 N808M (reserved)
C180 N2125Z Flying
SEMPER FI
Posted: Sun Jan 28, 2007 4:52 pm Post subject: Jack plug question (shielded wires) |
At 05:30 PM 1/28/2007 -0700, you wrote:
| Quote: | Bob,
Very kind of you sir. I'd be delighted.
The website is moving to new quarters pretty soon
and we should have a faster, more stable connection
to the 'net along with much larger file space resources.
I'm looking for ways to enhance our library of downloadable
materials and the wiring diagrams for this popular
radio would be a great candidate.
Posted: Sun Jan 28, 2007 4:55 pm Post subject: Jack plug question (shielded wires) |
| Quote: | Bob,
Mauri Morin
Polson, MT
C180 N2125Z Flying
SEMPER FI
Mauri. Hold off my friend. Another List member
has just sent me a .pdf copy. Wasn't aware of it
until I opened the message right after yours.
I think I've got what I need. I'll get it
checked over and then post what looks like
would be most useful for our brother across the
pond.
Posted: Sun Jan 28, 2007 5:04 pm Post subject: Jack plug question (shielded wires) |
| Quote: | Hi Bob
was told?
Frank. Send me your direct email and I'll forward a
link for downloading a .pdf copy of the manual that has
come into my possession.
