		mikedoble(at)wi.rr.com Guest
				 Posted: Tue Jan 30, 2007 5:03 am    Post subject: Tools to Sell |
				All – I’m convinced now that I need a pneumatic squeezer (thanks a lot Dave Leikam…).
 Any of you that are done want to part with yours???  If not, I’ll call Avery or Cleveland Tool.
 Also, there was some discussion a few weeks ago about how to rivet the tail cone skins without wrinkles.
 Does anyone know what mushroom set was suggested for this?  I seem to remember the Cleveland set with rubber guard (not the swivel).
 Mike
 Builder 40691.  Working on my tail……20 hrs so far.
				 Posted: Tue Jan 30, 2007 5:51 am    Post subject: Tools to Sell |
				Re the tail skins. The key for me so far is to backrivet as much as
 possible. I've been using a 12" X 30" X 3/8" steel plate (it doesn't
 have to be polished or milled flat) along with several pieces of 3/8"
 packing box plywood. I found that the Cleaveland backrivet set does a
 *much* better job than the ATS set I started with (see below) The long
 backrivet set along with a short one helps a lot too. Almost ever rivet
 forward of the 2 rearmost bulkheads can be back riveted. I haven't done
 the top skin yet.
 I plan to use the backrivet set and the backrivet bucking bar from
 Cleaveland for the top skin - but I'm looking for other advice here.
  From my previous post on backrivet sets:
 I've been using the backrivet set from ATS and getting acceptable
 results. However, I recently had my first opportunity to use a 12" long
 backrivet from Cleaveland and discovered that it was easier to get good
 results.
 The ATS has a thick plastic collar that I had to grind a flat spot on in
 order to get squarely on the J stiffener rivets. I've hit it twice more
 with the grinder to ease access on other rivets.
 The ATS also has a convex face on the set. I found that unless the set
 was well centered and straight, it was easy to get tilted, concave shop
 heads.
 The Cleaveland 12" tool (or whoever's tool they distribute) has a thin
 plastic collar and I found it fit the J stiffeners very nicely. The face
 of the set is flatter and it's easier to get square, flat shop heads. I
 just ordered their normal length backrivet set and understand it is
 setup the same as the 12".
 Mike Doble (Home Office) wrote:
  Dave Leikam…).
  Mike
		kearney(at)shaw.ca Guest
				 Posted: Tue Jan 30, 2007 7:28 am    Post subject: Tools to Sell |
				Mike
 Call the yardstore (www.yardstore.com) as they sell good quality *used* pneumatic squeezers and they stand behind what they sell.
 Cheers
 Les Kearney
 Rv10 # 40643 – Not riveting due to wristus fractus
		greytex
				 Posted: Tue Jan 30, 2007 7:53 am    Post subject: Tools to Sell |
				<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->  Good luck getting someone to part with their squeezer. It is a "Charlton  Heston" tool. Cold dead hands speech>>>>>
		moons1999(at)yahoo.com Guest
				 Posted: Tue Jan 30, 2007 8:35 am    Post subject: Tools to Sell |
				Mike,
     I use the mushroom set with rubber guard that you are referring to.  At first I didn't like it because the rubber was to thick and the rivet popped out a little bit.  I ended up trimming down the rubber and it works great now.  Much easier to do single-person riveting with the rubber "holding" the rivet gun in place.  Prior to doing that I had sworn off single-person riveting with a bucking bar.  I have not used the swivel one so I can't comment on that.
 --Shawn
 40366
		LarryRosen
				 Posted: Tue Jan 30, 2007 9:27 am    Post subject: Tools to Sell |
				Try ebay for the pneumatic squeezer.
 Use this for the search string, including the brackets.
 (squeezer,squeazer,squeezers,squeazers,squeeze,squeaze) (rivet, rivit)
 They are tough to find, but you may get lucky. Nothing on ebay now
 unless you are looking for a Tatco hand squeezer.
 Larry Rosen
 N205EN (reserved)
  Dave Leikam…).
  Mike
  _________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
		Nick Nafsinger
				 Posted: Wed Jan 31, 2007 6:03 am    Post subject: Tools to Sell |
				LMAO, you’re welcome John.  J
 Now get the Backrivet Table built so we can get the Rudder done this weekend!
 Nick
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cram
  Sent: Tuesday, January 30, 2007 9:53 AM
  Subject: Re: Tools to Sell
 ----- Original Message -----
 Sent: Tuesday, January 30, 2007 9:25 AM
 Subject: RE: Tools to Sell
 Mike
 Cheers
 Les Kearney
 Rv10 # 40643 - Not riveting due to wristus fractus
 -----Original Message-----
  From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Doble (Home Office)
  Sent: Tuesday, January 30, 2007 6:03 AM
  Subject: Tools to Sell
 All - I'm convinced now that I need a pneumatic squeezer (thanks a lot Dave Leikam.).
 Any of you that are done want to part with yours???  If not, I'll call Avery or Cleveland Tool.
 Mike
 Builder 40691.  Working on my tail..20 hrs so far.
     	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com   href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com  |
   01234567890
      --  Release Date: 1/30/2007 11:30 PM
  1/30/2007 11:30 PM
  _________________ RV-10  40569
Flying! |
