lcottrell
Posted: Sun Jan 28, 2007 6:31 pm Post subject: tank troubles |
I still seem to be having more problems than I can fix. Sigh!, some days are like that. My problem now is that my two tanks that are hooked together with a "Y" do not pull fuel the same. I had wanted to do that since my EIS only has one aux feature to read the fuel levels.
I had thought that the pickup tubes were getting kinked, so I took the pickups out of the tanks, cut the metal tube to about 3 inches, installed a flex fuel line and a brass strainer to the bottom. I still have the problem, and it is not always the same tank that is pulling more. I have decided that I am going to have to install a selector valve and a two way switch to switch back and forth from the front to the rear tank to see how much fuel I have. I really don't want to, still trying to follow the KISS principal.
I am at a loss.
Larry, Oregon
Posted: Sun Jan 28, 2007 6:50 pm Post subject: tank troubles |
I am at a loss.
Larry, Oregon
Hi Larry:
I never had an airplane with this "screwy" system of pulling fuel from
two tanks through one line.
If I did have two tanks, you can be assured I would be pulling from
the bottom of both into a T. I can assure you you will then be
getting equal draw from each tank.
There is a neoprene grommet and elbow fitting available from Kolb or
most any UL parts house for tapping a plastic or metal tank. I have
used them for many years and many hours with great success.
If you still want to pull fuel from the top of the tank, then tap the
bottoms, tie them together so gravity can do its job for you.
Why switch back and forth between tanks with your fuel level sender
when you are working with a flow system that doesn't work logically?
My thoughts for what they are worth. 2 cents.
_________________ John Hauck
Titus, Alabama |
jindoguy(at)gmail.com Guest
Posted: Sun Jan 28, 2007 7:55 pm Post subject: tank troubles |
If it helps any Larry, you're not the only one in this boat. When I found a cracked grommet that was just beginning to weep fuel, I was determined to keep all fuel taps on the top of the tanks. I figured out how to modify a Weatherhead valve so I could have right, left, both and off, but the fear of running a tank dry and sucking air has me debating the real merits of this set up.
I haven't come up with anything better than John's method of putting an interconnection between the tanks on the bottom and let them self level.
Until I get the rewiring program accomplished I've been doing the Scarlett O'Hara method. "I shall think about that tomorrow".
Rick
On 1/28/07, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote: | Quote: | --> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
I am at a loss.
Larry, Oregon
Hi Larry:
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
lcottrell
Posted: Sun Jan 28, 2007 7:58 pm Post subject: tank troubles |
lcottrell
Posted: Sun Jan 28, 2007 8:08 pm Post subject: tank troubles |
Posted: Sun Jan 28, 2007 8:27 pm Post subject: tank troubles |
Larry C:
The push in grommets and fittings have a proven track record, a hell
of a lot better than your current fuel system.
I have some in my fuel tank that have been in service for 15 years.
Titus, Alabama |
Posted: Sun Jan 28, 2007 8:29 pm Post subject: tank troubles |
If it is the vents, try switching the caps between the two tanks and see if you get the same results. My old system always drew evenly from both tanks.
WARNING, the following is an untested idea, but I will be using it to vent my tanks.
I drilled a 1/4" hole through the little cap on the tank handle and the threaded boss it screws onto. I beaded a short piece of 1/4" aluminum tubing on both ends (put the cap on this tube before doing the second bead, you can guess how I learned that one) Bead one end about a 1/2" from the end so there is tubing to go down in the boss rather than just setting on top. Slide a piece of fuel proof line onto this and connect the two tanks with a tee. Run the single line from the tee up to the engine mount tube then back down and out the bottom of the cabin. I believe this will do two things. One, prevent any kind of fuel spill in case of being flipped over, and two, pick up ram air to pressurize the tanks and take a bit of load off the fuel pump. I stole this idea from the LongEZ guys.
Rick
On 1/28/07, Larry Cottrell <lcottrell(at)fmtcblue.com (lcottrell(at)fmtcblue.com)> wrote:[quote] --> Kolb-List message posted by: "Larry Cottrell" <lcottrell(at)fmtcblue.com (lcottrell(at)fmtcblue.com)>
George Alexander
Posted: Mon Jan 29, 2007 6:53 am Post subject: tank troubles |
Larry:
Rick's suggestion of switching caps is the most likely to find the source of
your dilemma. The way you describe the current setup and the results,
improper venting is most likely. Odds are that them 'daubers (or some
eight-legged critters) did their do before the single digits set in.
As for pickups in the bottom of the tanks..... If the grommets are installed
correctly there shouldn't be a problem.
Before I got religion and switched to a Kolb, I had 8 years in a couple of
Quicksilvers. The Quicksilver tanks hang over the root tube and have a
cross over loop to equalize the fuel in the areas below the root tube. Also
has the pickup on the bottom. As part of the spring ritual, would change
out the grommets (two on the cross over and one on the pickup), all fuel
lines and filter. (My original FS also had the feed from the bottom. Same
spring routine.) Probably overkill, but it made me feel better.
I found that a little oil on/in the grommets first, put them in the tank,
then push the elbow straight in... as opposed to twisting and turning and
yanking and cranking and pulling and cussing. Use a pair of locking pliers
to hold the elbow because it does take some force to get it into the
grommet. Never had a leak (of fuel that is) in 10 years of this routine.
Rick's method of vent/overflow is also a good ideee.
As Beauford would say..... Worth what you paid for it.
George Alexander
http://gtalexander.home.att.net
DO NOT ARCHIVE
_________________ George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net |
Posted: Mon Jan 29, 2007 6:18 pm Post subject: tank troubles |
John Hauck wrote:
I am at a loss.
Larry, Oregon
Hi Larry:
I don't know didly about Kolbs, but most high wing Cessnas with 2 wing
tanks & the selector on 'both' feed unevenly. Others have mentioned
venting issues; that's usually the cause of uneven feeds. It's very
difficult to set up the tank vents where both tanks pressurize evenly.
Add in inadvertent slip angles in flight, slight differences in fuel
line length, routing, etc & It would be more surprising if they *did*
feed evenly.
One technique in the homebuilt community (the Bede BD-4 is a good
example) to work around the problem is to feed both tanks into the top
of a small low mounted 'sump' tank & feed the engine from the bottom of
that tank. Bear in mind that no homebuilt I'm aware of uses a syphon
type feed out of the primary tanks; all draw from the bottom of the tanks.
FWIW,
Charlie
Posted: Mon Jan 29, 2007 6:39 pm Post subject: tank troubles |
fuel
*did*
| feed evenly.
| Charlie
Charlie:
Pull the fuel off the bottom of both tanks, siamese the vents to one
line, and I bet the fuel will drain evenly from both tanks.
Titus, Alabama |
Posted: Mon Jan 29, 2007 7:09 pm Post subject: tank troubles |
John Hauck wrote:
fuel
*did*
| feed evenly.
| Charlie
Charlie:
It might, but it might not. Some of the previously mentioned Cessnas
have the tank vents siamesed together. They still don't feed evenly.
Charlie
