Fusible link question
steerr(at)bellsouth.net
PostPosted: Tue Jan 30, 2007 7:20 pm    Post subject: Fusible link question Reply with quote
Bob,
Can a fusible link be included in a wire bundle, or is it better practice to
keep it separate from a bundle? I'm wiring up fuse blocks; the fusible
link, as shown in Z-1, is in the wire that connects the main buss terminal
to the master switch.
Thanks for any info.
Bill Steer
Zenith 601HD, Stratus
nuckollsr(at)cox.net
PostPosted: Wed Jan 31, 2007 5:38 am    Post subject: Fusible link question Reply with quote
At 10:21 PM 1/30/2007 -0500, you wrote:
Bob,
to keep it separate from a bundle? I'm wiring up fuse blocks; the fusible
I do not recommend the use of fusible links in any locations
other than those illustrated in the drawings. If fabricated
as suggested with the fiberglass sleeve, they may be tied
into bundles with other wires. The sleeve contains the
potential for propagating damage to other wires.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
