Handheld Radios
lumkes(at)msoe.edu
PostPosted: Wed Jan 31, 2007 6:15 am    Post subject: Handheld Radios Reply with quote
The recent little snippet about how to switch the COM antenna to a handheld made me think of a scenario I am considering for my panel: What opinions does this group have about using a handheld for the primary and only radio. My flying would almost all be local with some cross country (Zenith601). I am leaning towards the ICOM-A24 or Sporty's SP-200, both with NAV/COM. The radio would be "hard-wired" to the plane in terms of external antenna, headset adapter, and external power planned ahead for a desired mounting location. Since I plan on having a moving map and GPS (probably PocketFMS on a mini-ITX or similar) the NAV portion of the radios would only be backup, and from what I have read, that already might be asking a lot of these features as installed in a handheld. Besides the NAV feature, buying one of the handhelds for my primary COM is cheaper, newer electronics technology, lower in weight, and flexible in terms of future options or upgrades.
John
Zenith601HD/R912--70% complete
BobsV35B(at)aol.com
PostPosted: Wed Jan 31, 2007 6:58 am    Post subject: Handheld Radios Reply with quote
Good Morning John,
Why not just scratch the Navigation portion?
I bought the communication only version of my last handheld because it has bigger lettering which is easier for my old eyes to read.
If you are VFR only, you are very likely going to be flying occasionally at altitudes and in places where VOR reception is poor. GPS is much better almost all of the time.
For emergency back up, carry a second or third GPS!
I am not familiar with all of the products now available in the market, but I bought a Garmin E-trex several years ago for less than a hundred bucks. It has the same chip as the fifteen thousand dollar units.
It will tell you within one hundred feet where you are anywhere on the planet earth. Beats the devil out of any VOR based unit.
Chances are there are better and cheaper units available now than there were back then.
If you do go down in the boonies and are capable of getting out of your machine, the handheld radio will allow you a good chance of being able to contact somebody on 121.5 and the handheld GPS will allow you to tell the rescuers where you are.
I carry a small leather bag that contains a basic GPS, an extra I-Com with a AA battery pack and a large supply of batteries for both.
That bag, and clothing suitable for the area being overflown, should provide very good potential for early and successful rescue.
Wouldn't be a bad idea to carry the bag on automobile trips!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
In a message dated 1/31/2007 8:20:01 A.M. Central Standard Time, lumkes(at)msoe.edu writes:
John
aurbo(at)ak.net
PostPosted: Wed Jan 31, 2007 7:01 am    Post subject: Handheld Radios Reply with quote
John,
I used to fly a 1946 Taylorcraft with no electrical system. I used it for "fish spotting" and having radio's were mandatory. I used a hand held exclusively, I built a holder for it and used a head set and PTT and it worked great. I finally got tired of the stupid little battery going dead and wired in a wheel chair battery and that took care of that problem.
So, for a com radio a hand held is great (IMHO) and with the external antenna you won't have any trouble talking to ATC.
Mike Ice
Anchorage, Alaska
N6030X(at)DaveMorris.com
PostPosted: Wed Jan 31, 2007 7:07 am    Post subject: Handheld Radios Reply with quote
Hi John,
Here's my 2 cents worth:
It's going to depend on what kind of flying you do. If you fly in or
around controlled airspace that requires you to be in contact with
ATC, or if you plan to do a lot of cross country flying with Flight
Following, then you're going to find the handheld to be
inconvenient. If you don't expect to be doing much talking to
controllers, then it might be a better deal.
Here's why: As you are cruising along at 8500 feet chatting with
your friend in the seat next to you or listening to tunes on your
iPod, suddenly ATC will pop in and say "Barnstormer 34 Xray contact
Lubbock Approach one two six point niner five goodday". Now, you
only have a scant few seconds to respond, before ATC will try to
contact you again (which you don't want).
If you have a conventional radio with a Standby window, then
1. the instant you hear your callsign, you shush your copilot and put
your fingers on the comm radio frequency selector,
2. while ATC is reading you the new frequency, you are dialing it
into the Standby window
3. then you read it back to him in the split second after he says it
and wish him a good day
4. you write the new freq down on your notepad for reference
5. press the transfer button, and you're on the new frequency ready
to contact the next ATC.
If you don't have a standby window, you have to
1. wait until he finishes reading you the frequency, while writing it
down, if you can find your pencil, OR
2. memorize the frequency - risky as you get older Wink
3. then read it back to him
4. then dial the new frequency into the radio
If you are unable to raise ATC on the new frequency, the standby
window type of radio gives you the ability to hit the transfer
button, go back to the previous frequency, and check in again to
verify you have the frequency correctly or get new instructions.
I have personally found the 2 window Com radio to be a great
invention. The busier the airspace you're in, the faster you want to
be able to react to ATC. Just last Sunday I was flying through the
DFW Class B airspace mixing it up with 757s and other planes coming
in and out of some very busy airspace. The controller was rattling
off instructions virtually non-stop. But every so often there would
be a shriek, a pause, and confusion. Turns out a poor Cherokee pilot
had lost his primary radio and was trying to use a handheld. He must
not have had an external antenna on it, because he would stomp all
over the approach controller or other airplanes, calling for
approach, and never hearing anything, so he'd do it again and again
and again. This went on for about 20 minutes. The controller was
about to stroke out from rage, and all of us pilots had eyes the size
of saucers, were quiet (as the proverbial big-mouth frog at the end
of that joke), and were EXTREMELY fast with our transmissions and
reactions to anything ATC said. The best course for that poor
Cherokee pilot would have been to get out of the Class B post haste
and reassess the utility of that particular handheld installation.
As for the utility of the NAV section on the radio, you're going to
be using your GPS for everything, so the NAV will strictly be a
backup. I hardly even fly by the DG any more... Ground Track is the
most important thing in getting there, and the GPS becomes the focal
point of all navigation. I have a Loran and a Nav radio as my 3rd
and 4th backups (after pilotage), but rarely actually use them.
I carry a handheld JRC com/nav radio in my flight bag in case
everything goes to hell.
Dave Morris
www.N6030X.com
John
nuckollsr(at)cox.net
PostPosted: Wed Jan 31, 2007 7:11 am    Post subject: Handheld Radios Reply with quote
It's been done many times. I've got pictures somewhere
showing various brackets on panel and sidewalls where
builders have provided mounting provisions for a hand-held
along with wire dressing techniques that keep the bundles
reasonable organized when the hand-held is slipped out
of the bracket for programming, etc.
frank.hinde(at)hp.com
PostPosted: Wed Jan 31, 2007 7:43 am    Post subject: Handheld Radios Reply with quote
Yes I would have to agree with the last two posts on this.
I flew my Zodiac for 400 hours and had a Icom A200 and a handheld
GPS...Oh and a transponder which I really found to be essential, not
only for flying controlled airspace but for flight following too.
My one experience with a handheld com was less than stella and I simply
decided to remember "7600" for the transponder code if the radio died.
Doing it this way avoids you having to explain that your radio died to
ATC who probably won't be able to hear you anyway.
Then if you can hear ATC he will give you directions and if you can't
you simply turn around and get out of their airspace.
If the concern is going down somewhere I think I would invest in a GPS
powered PLB....And if the landing looks hairy activate it before you hit
the trees!
If cost is a concern, there are many second hand older handheld GPS
units out there that work perfectly well....My old Lowrance will be
going into my flight bag as a backup to my IFR panel mount.
As to the ICOM radio...I was so impressed with it, it is is also now my
Com1 unit in my RV7.
Personally I would forget about using VOR's I'm half way thru my IFR
training and I still get confused by them.
If you intend to do a lot of Xcountry work in your Zodiac the one really
nice upgrade I would suggest is a Trutrak autopilot...Spendy yes but the
Zodac is a twitchy beast (at least the HDS was) and I thing the wing
leveler would see you arrive fresh rather than ragged as always happened
to me after more than two hours of flying the thing.
Frank
SteveR
PostPosted: Wed Jan 31, 2007 7:51 am    Post subject: Handheld Radios Reply with quote
John,
With a good quality install like you are talking about, I see no
reason not to do it. I use a Vertex VXA-150 handheld as my primary
radio in my Pietenpol, and I have no problems with it. I was even
based at a very busy class D airport under KDFW's class B for nearly a
year (Meacham, or KFTW, in Fort Worth), and I never had any problems.
If you have external power, an external antenna, and a reliable
headset connection, it is not a bad idea IMO. With an external
antenna that I made from a brass brazing rod, I have been able to
transmit and recieve over 80 miles air to air, and I can reliably
communicate with anyone who has a decent radio at 40 miles. I even
used the handheld on an 840 mile trip bringing the plane home.
The one thing that would be more handy with the handheld is a
"flip-flop" feature, and maybe easier to use presets for different
frequencies. The menus on the VXA-150 are cumbersome to use, but
otherwise I'm happy.
The antenna is critical, you may already know how to make one, but if
you are still studying that, Google Jim Weir of RST Engineering
(www.rst-engr.com)...he sells an inexpensive booklet that will tell
you everything you need to know about antennas.
One thing that is a bad idea in my opinion is the NAV feature. Skip
it, and spend that $100 on a handheld portable GPS if you really want
a backup. In an emergency or a critical situation, fumbling with the
NAV feature on a handheld will likely just waste your time in my
opinion. A handheld GPS will give you much more information with much
less work and for about the same amount of money.
Steve Ruse
WOT Electronics
Quoting John and Kim Lumkes <lumkes(at)msoe.edu>:
John
JOHN TIPTON
PostPosted: Wed Jan 31, 2007 8:44 am    Post subject: Handheld Radios Reply with quote
I presume you are in the USA, over here the majority of 'microlights' use the ICOM as their only radio
John - England
Bill.Dawson(at)pepperdine
PostPosted: Wed Jan 31, 2007 11:24 am    Post subject: Handheld Radios Reply with quote
Im not sure how well the nav portion would work because the nav wants a horizontal antenna. The handheld com/nav would use the same vertical antenna. Yes, a nav will work with a vertical, but it's not the best.
Bill
ceengland(at)bellsouth.ne
PostPosted: Wed Jan 31, 2007 4:37 pm    Post subject: Handheld Radios Reply with quote
John
With the icom, be absolutely sure it will work on external power (read
the actual manual) before purchase.
I bought an A-4 on the assurance from the factory rep that it would
work, only to find after I got it home that it will only charge the
rechargable battery when power is supplied to the ext. jack(radio
operation is disabled). Says so right in the manual, which I didn't read
before purchase.
Charlie
Not a big fan of companies who make bad design decisions, then lie about
them.
wrmaxwell(at)bigpond.com
PostPosted: Wed Jan 31, 2007 4:55 pm    Post subject: Handheld Radios Reply with quote
Not familiar with the A24 but the previous model, the A22 will power
externally quite happily and here Downunder, is commonly used as the main
radio in our ultralight category ( similar to the advanced ultralight in
Canada) without the battery attached.
Bill
billsettle(at)bellsouth.n
PostPosted: Wed Jan 31, 2007 5:39 pm    Post subject: Handheld Radios Reply with quote
John,
I used to have a Luscombe 8E. I used a Garmin GPS/Com 190 Handheld as my only radio. It did not do that well until I connected it to the external antenna and onboard power. After that, it worked great. Never had a problem communicating with anyone. I could receive up to a couple of hundred miles and transmit up to about 60 miles if I was up around 8-10k.
Bill Settle
Winston-Salem, NC
RV-8 Wings
Date: 2007/01/31 Wed AM 09:14:42 EST
To: <aeroelectric-list(at)matronics.com>
Subject: Handheld Radios
John
lumkes(at)msoe.edu
PostPosted: Thu Feb 01, 2007 6:17 am    Post subject: Handheld Radios Reply with quote
Thank you everyone for the excellent feedback! I am reconsidering the NAV portion and may rethink a panel mount with dual frequency inputs if I think that I might be in busier airspace. If I had to purchase right now I think that I would stay with the plan to use a "mounted" handheld; there seems to be many satisfied people with this arrangement. I was already planning for a gps moving map and a handheld gps backup.
Have a great day,
John
miltonbland(at)gmail.com
PostPosted: Thu Feb 01, 2007 6:22 am    Post subject: Handheld Radios Reply with quote
About a year ago I decided to "install" a handheld com radio in my Ercoupe. My decision was based on a friend who has dual Icom A3's in his Luscombe. I found a good deal on a new Vertex 210 Pilot. It worked great on the ground and ok in the air with the "rubber ducky" antenna. But range with that antenna was limited to about 5 miles or so. It had a SMA antenna fitting so I ordered an adapter and hooked up the old com antenna that was still on the airplane. That's when the problems really began. Everything seemed good on the ground but at about 150 feet in the air the radio would not break squelch. Also I picked up interference from FM radio stations, loud but not always clear. Basically the radio was useless in the air with the aircraft antenna. I called Vertex and they told me the radio was not engineered for use in an airplane! I asked them why their manual suggests otherwise and they told me that was a marketing error! So much for customer support.
I now have an Icom A6 but I have not had an opportunity to try it in the air. I am hoping it will work as well as the old A3's. I have noticed the A3's seem to really hold their value on eBay. Maybe that is because they work well as a primary light sport radio.
PostPosted: Thu Feb 01, 2007 6:56 am    Post subject: Handheld Radios Reply with quote
ICOM has, in my estimation, been at the top of
the mountain for technical excellence in radio
manufacturing. The problem you were experiencing
with FM stations on the other hand-held was due
to inadequate control of band-pass filtering -
keeping signals of no interest from getting
into the receiver's vulnerable "front end".
This is no mean task . . . especially in miniature
radios. The FM broadcast band is located just below
the aircraft band. The broadcast stations are on
tall towers with effective radiated powers in the
tens of kilowatts. Your stations of interest in
aviation are all on short towers with ERP's in the
tens of watts. So while the hand-held receiver is
working diligently to decode microvolt intelligence,
it has to contend with millivolt level antagonists
located right next door.
My experience with ICOM many years past is that they
are demonstrated masters at controlling front end
pass-band characteristics. I'll have to tell you guys
about a "hidden transmitter hunt" I participated in
about 25 years ago where only an ICOM receiver would
do the job. If anyone has more recent experience that
argues with this assessment, I'd be pleased to hear
about it.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
BobsV35B(at)aol.com
PostPosted: Thu Feb 01, 2007 8:14 am    Post subject: Handheld Radios Reply with quote
Good Morning John,
I don't have one, but I do believe the newest I-Com has a flip flop frequency capability. My only recommendation would be to buy the double A battery pack as well as the pack with a more modern battery that can be recharged from ship's power. I think they still have that available.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
In a message dated 2/1/2007 8:19:57 A.M. Central Standard Time, lumkes(at)msoe.edu writes:
Have a great day,
John
