wreining(at)gmail.com Guest
Posted: Fri Feb 02, 2007 6:46 pm Post subject: How to Get the RV-10 Out the Workshop Door |
I need the outside distance from main gear to main gear, assuming the engine, fuselage and tailcone are all attached. This is the likely configuration that will be pushed out the door. I have checked Tim Olsen’s excellent site, and have almost all the dimensions, except for this one. That is to say, the engine to tailcone measures 22.5 feet, and the cabin top to the floor measures 80 inches. The greatest width seems to be from wing stub to wing stub, at 57 inches. But then, oops, I forgot about the gear! Hopefully all this will fit through a standard 8 foot wide by 8 foot tall roll-up garage door. Why am I asking? I have to build the workshop, and want to make sure I get it right (did I mention the door has to be on the side of the building, since I live on a hill?) Another question – is it feasible to wait and put the fuselage on the gear once it is out the door? Your data and suggestions would be greatly appreciated. Tim Olsen, if we get a good number, please add it to your “Work Area Tips and Workspace Requirements” site.
Bill (and Jon) Reining
40514 tailcone
Tim Olson
Posted: Fri Feb 02, 2007 7:34 pm Post subject: How to Get the RV-10 Out the Workshop Door |
I think 8' is going to be a little tight. There have been people
who have used straps to pull the gear legs closer, or you could
try to get one gear leg out first and then the other. But, now
don't quote me on this, but I think that when I loaded mine on the
trailer the gear tire center-to-center as 93-94". So then you
add on 1 full tire width plus little axle stub to that and
you'll get more than 96" wide. I'm pretty sure that without
doing one of the "tricks" you won't just roll it out the door.
My trailer was a 10'L x 108" wide trailer. It fit comfortably
inside that trailer for the haul to the airport. But I would
think you'll end up needing about 102" or so door width if you
just want to roll it out. Of course, bringing them together
with a strap will make the plane taller, but at 8' high you
probably don't have to worry about that one. I did...mine
made it through my garage door with about 1" clearance if I
had the door all the way up.
If someone does get me an exact measurement, I'll be happy
to update that page....it's been a question asked more than
once in the past few weeks, so I should really list that width
there.
As far as putting the gear on later, I see no reason why you
couldn't pin the gear in place using slightly undersized
bolts and then pull the gear for the trip out the door and
put it back on. It'll be a little lifting and work, but
it should be OK. You may want to take some caution tape and
put it on the fake bolts so you don't forget to swap the
real ones in once you're outside the garage. I kept a small
whiteboard with any critical things to remember as well.
Bill Reining wrote:
| Quote: | I need the outside distance from main gear to main gear, assuming the
40514 tailcone
bcondrey
Posted: Sat Feb 03, 2007 10:15 am Post subject: Re: How to Get the RV-10 Out the Workshop Door |
I just measured mine at the top of the tire and without the wings on the plane. Distance from center to center at the top of the tire is 89", and edge to edge is 94". Obvisously if you've got the axle extensions on for the wheel pants you'll have to also add that in.
Bob #40105
Tim Olson
Posted: Sat Feb 03, 2007 11:14 am Post subject: How to Get the RV-10 Out the Workshop Door |
Thanks Bob, I used your numbers to update my "workspace requirements"
tip area on my site. I knew 94" seemed like a good number. I just
didn't remember it as outside width. Great to have people at all
stages of the build!
bcondrey wrote:
Bob #40105
http://forums.matronics.com/viewtopic.php?p=92627#92627
