construction questions
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
wb2ssj(at)earthlink.net
PostPosted: Sun Feb 04, 2007 11:10 am    Post subject: construction questions Reply with quote
I have a few questions on the building of the Lighting.
1. Page 23-2 (rudder hinge installation) a picture shows the support on the elevator below the mating bracket which is on the vertical fin. Does the lower bracket also go below the its mating bracket?
2. The bearings for the brackets on the rudder are .650 in diameter. The holes are .625. What has anybody addressed this so far?
3. When doing the firewall, you need to put a slight radius bend into the edge all around. What tool have you used?
Thanks for your reply. TEX
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
