nameplate location
Lynn Matteson
PostPosted: Thu Feb 02, 2006 5:22 am    Post subject: nameplate location Reply with quote
Where have you folks attached your nameplates? I've seen them on the
tail access covers and the cockpit console. It seems like it's up to
the DAR and what kind of mood he's/she's in, eh? The FAA wants it where
it "can't be removed during normal service of the plane", so that seems
to preclude the tail access covers, but I've seen them there on some
'foxes.
Lynn
Lynn
Kitfox IV-Jabiru 2200
N369LM
Bill Willyard
PostPosted: Thu Feb 02, 2006 8:13 am    Post subject: nameplate location Reply with quote
I put mine on the tail access cover. The inspector from the FAA didn't say anything against that. I guess the it depends on your (their) definition of "normal service".
Bill W.
Bill Willyard
Classic IV 912UL
morid(at)northland.lib.mi
PostPosted: Thu Feb 02, 2006 8:20 am    Post subject: nameplate location Reply with quote
Lynn, I think this is correct. Well, that's the way I was told anyway. I
was also told that it's not an FAA requirement, but the DEA so they can
figure out who you are after they shoot you out of the sky which also
corroborates the requirement for them being stainless steel so there'll be
something left for them to verify. Smile
Seriously, I mounted mine under the stab down low right on the fabric below
the access cover. A simple aluminum backing plate glued to the inside cover
with the data plate riveted to it.
Deke
Lynn Matteson
PostPosted: Thu Feb 02, 2006 8:55 am    Post subject: nameplate location Reply with quote
Thanks Bill and Deke...maybe a call to my intended DAR will answer the
question. Either that or drill the holes in the plate and wait until
they show up to actually hang it. Deke, I just talked to Duane and his
is on the right side of the console...where I remembered it.
Lynn
On Thursday, February 2, 2006, at 11:19 AM, Fox5flyer wrote:
<morid(at)northland.lib.mi.us>
anyway. I
there'll be
below
cover
Deke
Lynn
N369LM
roncarolnikko(at)hotmail.
PostPosted: Thu Feb 02, 2006 9:30 am    Post subject: nameplate location Reply with quote
Lynn I have heard that it has to be permanently attached to metal on the
airplane. My neighbor had to move his from the removable inspection plate
to get his AW certificate from our inspector. I was thinking of using
aluminum pop rivets on the horizontal stab cover plates. These would allow
me to pass the "permanent" part and yet be removable with a drill. I'll
be listening closely for the best solution as I have yet to attach mine.
Ron NB Or
Subject: nameplate location
Date: Thu, 2 Feb 2006 08:22:30 -0500
'foxes.
Lynn
rjdaugh(at)rapidnet.com
PostPosted: Thu Feb 02, 2006 10:21 am    Post subject: nameplate location Reply with quote
As another data point. My inspector OK'ed my point as on the fiberglass,
low and just ahead of the left door. This Series 7 firewall forward has
this fiberglass permanently attached to the frame.
Randy
rdmac(at)swbell.net
PostPosted: Thu Feb 02, 2006 3:56 pm    Post subject: nameplate location Reply with quote
Lynn,
I attached my 'data plate' to the fabric right below the left side
access cover on the vertical stab. I riveted it to a back up plate on the
inside of the fabric. Can't take credit for the idea, got that from Don
Smithy I think. It worked out great. The FAA inspectors never even mention
it, which means they approved.
Roger Mac
smokey_bear_40220(at)yaho
PostPosted: Fri Feb 03, 2006 11:27 am    Post subject: nameplate location Reply with quote
I made a metal backing plate and attached it to the
tubing on the right side across from the left side
access panels. No problem getting it passed and easy
access to the back side if I need it.
I have seen Aeroncas with it mounted on the top of
the fuselage half way between the wing and tail. Very
easy to read there, but you need a backing plate
mounted to the tubing.
I would suggest not drilling any structural tubing. I
riveted it to the longeron that olds the fabric out on
the side and epoxied it to the lower structural tubing
on mine.
Kurt S. S-5/ NSI
Lynn Matteson
PostPosted: Tue Feb 07, 2006 4:09 am    Post subject: nameplate location Reply with quote
Thanks everybody for all the suggestions about the nameplate/data plate
locations. I finally called my DAR-to-be and he wouldn't approve the
tail access covers, so I made a backing plate and placed it behind the
fabric, below and to the rear of the access cover on the left side, and
far enough rearward to catch the vertical member that I had made to
streamline the fin/rudder junction. This member is aluminum, and I
caught two rivets in it, and the other two go through the fabric and
the backing plate. Very sturdy, and no chance of buffeting, I'm pretty
sure.
Lynn
Lynn
N369LM
PostPosted: Tue Feb 07, 2006 11:44 am    Post subject: nameplate location Reply with quote
Good call Lynn. Where is your dar coming from?
Ron NB Ore
Subject: Re: nameplate location
Date: Tue, 7 Feb 2006 07:11:29 -0500
sure.
Lynn
Lynn Matteson
PostPosted: Tue Feb 07, 2006 4:14 pm    Post subject: nameplate location Reply with quote
From Pontiac, Michigan...I'm in Grass Lake, MI.
Lynn
On Tuesday, February 7, 2006, at 02:40 PM, ron schick wrote:
<roncarolnikko(at)hotmail.com>
Ron NB Ore
> From: Lynn Matteson <lynnmatt(at)jps.net>
> plate
> and
> sure.
> Lynn
Lynn
N369LM
msm_9949(at)yahoo.com
PostPosted: Wed Feb 08, 2006 6:33 am    Post subject: nameplate location Reply with quote
Hi Lynn.
Have you tried Art Nadobny, FAA safety inspector out of the Detroit MISO at Willow Run? He's a great guy, drove 4 hours North to do my inspection and had no problem with nameplate mounted under stab on the access cover of my model II. Also, he scheduled me within a couple weeks of receiving the materials, unlike Grand Rapids FSDO that needed 4 months to get to me. Maybe best of all . . . he'll do your airworthiness inspection for free! Contact me off list if you'd like his number.
Lynn
Ron NB Ore
> From: Lynn Matteson
> plate
> and
> sure.
> Lynn
Marco Menezes
Model 2 582 N99KX
Brings words and photos together (easily) with
Lynn Matteson
PostPosted: Wed Feb 08, 2006 1:00 pm    Post subject: nameplate location Reply with quote
Thanks, Marco...I just sent an email your way.
Lynn
On Wednesday, February 8, 2006, at 09:30 AM, Marco Menezes wrote:
Hi Lynn.
his number.
Marco Menezes
Model 2 582 N99KX
Lynn
N369LM
PostPosted: Thu Feb 09, 2006 12:07 pm    Post subject: nameplate location Reply with quote
Sorry Lynn I thought you were in Oregon. Can't help with FSDO there. Ron
NB Ore
Date: Tue, 7 Feb 2006 19:14:20 -0500
Lynn
> Ron NB Ore
> do not archive
>> plate
>> and
>> sure.
>> Lynn
