Empty Weight
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
info(at)usjabiru.com
PostPosted: Thu Feb 08, 2007 7:12 am    Post subject: Empty Weight Reply with quote
The Arion Aircraft development team has been working hard to reduce the empty weight of the basic Lightning. We have found new core materials and new methods of fabrication that reduce weight but maintain the strength of the structural components. We have redesigned some of the non structural components as well to make them lighter. Based on the empty weights of recently completed Lightnings we are reducing the empty weight specification by 25 lbs to 775 lbs. Builders can achieve this weight for a Lightning with VFR instruments, Becker Radios (they are light), minimal interior finish, and a wood prop.
Pete Krotje
Arion Aircraft, LLC
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
pequeajim
PostPosted: Fri Feb 09, 2007 10:18 pm    Post subject: Re: Empty Weight Reply with quote
Hi Pete:
That's great news... Continuous inprovement!
When do you think this updage will make it into production?
Jim!
pete(at)flylightning.net
PostPosted: Sat Feb 10, 2007 7:13 am    Post subject: Empty Weight Reply with quote
Jim,
It's already there. The last 15 or so kits would be able to be built at the
lighter weight. Final weight will always depend on additions to the basic
airframe. Nice interiors add 8 lbs or so. Carbon ground adjustable prop
adds two or three lbs. Extra paint (pearl, extra stripes, etc) can add 5
lbs or more. Extra instruments or EFIS's can add 5 lbs. Garmin radios
instead of Becker add 4 lbs. Auto pilot servo's weigh 3 lbs+ each.
It's easy to make it heavier and a real challenge to make it lighter.
Pete
JamesL(at)Lugoj.com
PostPosted: Sat Feb 10, 2007 8:41 pm    Post subject: Empty Weight Reply with quote
Hi all,
Speaking of empty weight, have any of the Lightnings built so far had
the BRS parachute option installed? If so, what was the weight penalty
and what did it do to the empty balance relative to a comparably
equipped non-BRS plane?
Thanks for any information you can supply!
Jim Logajan,
Still just kicking tires.
dashvii(at)hotmail.com
PostPosted: Sun Feb 11, 2007 6:18 am    Post subject: Empty Weight Reply with quote
Jim,
There was the prototype built with a BRS, don't know the weight penalty,
Nick can answer that. There was also one customer plane with it, but the
plane is on hold until finances and medical can be worked out as I
understand. It does signifigantly reduce the amount of room you have for
baggage though since that is where it hangs. Brian W.
Reply-To: lightning-list(at)matronics.com
Subject: Re: Re: Empty Weight
Date: Sat, 10 Feb 2007 20:39:42 -0800
Hi all,
Jim Logajan,
Don’t miss your chance to WIN 10 hours of private jet travel from Microsoft
georgiemun
PostPosted: Sun Feb 11, 2007 12:04 pm    Post subject: Re: Empty Weight Reply with quote
What about useful load now?
On the web site, it lists the following:
Gross Weight 1425 lbs
Empty Weight 775 lbs
That makes the useful load 650. Are these the latest figures? The weight that is listed, is this with a standard instrument package; or what configuration was used to determine the empty weight?
PostPosted: Sun Feb 11, 2007 1:01 pm    Post subject: Empty Weight Reply with quote
These are the latest figures. To quote from the web site:
"The Arion Aircraft development team has been working hard to reduce the
empty weight of the basic Lightning. Based on the empty weights of recently
completed Lightnings we are reducing the empty weight spec by 25 lbs to 775
Becker Radios (they are light), minimal interior finish, and a wood prop."
As you can see this weight is achievable with VFR instruments, a Becker Comm
radio, intercom, EIS engine monitor, wood prop, and a lightweight interior.
We really have no such thing as a "standard" instrument package as most
builders use the panel to individualize their plane.
Pete
vettin74(at)yahoo.com
PostPosted: Mon Feb 12, 2007 6:15 am    Post subject: Empty Weight Reply with quote
Aircraft with a bacic interior, meaning mostly speckled paint in the rear baggae are and on the sides of the cockpit, carpet on the baggage floor and cockpit floor, nice seat cushions. As for instruments, a single Horizon sport EFIS , EIS, becker radio and transponder, PM501 intercomm, swiches and breakers. A wood prop, 2 color paint. The basics to make a good day/night VFR aircraft...
Nick
georgiemun <georgiemun(at)yahoo.com> wrote:
[quote]--> Lightning-List message posted by: "georgiemun"
That makes the useful load 650. Are these the latest figures? The weight that is listed, is this when a standard instrument package, or what [quote][b]
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
