1rv4
Posted: Thu Feb 08, 2007 9:57 pm Post subject: Cowl clearance? |
Hi
I'm looking for advice on a cowl -- fuel injector servo clearance
problem. I have a HRII with Airflow Performance Fuel injector servo and
elbow. There is lots of clearance between the elbow and the stock HRII cowl
but when the Fuel servo is bolted on there is major interference between
cowl and leading edge of the fuel injector. Has anyone encountered this
problem?
I think a fix would be to have the elbow at an angle greater than the 95
deg. Is this what John's induction elbow does? As a last resort I could cut
the cowling but I really don't want to go there!
Any advice or comments much appreciated.
Chris
Fordham
| - The Matronics Rocket-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Rocket-List |
jhstarn(at)verizon.net Guest
Posted: Thu Feb 08, 2007 10:20 pm Post subject: Cowl clearance? |
Not sure of the degree's in John's elbow but it is noticeably more than 90
degrees. I would call John, go to the source. KABONG HRII N561FS Do Not
Archive.
fairlea(at)amtelecom.net Guest
Posted: Fri Feb 09, 2007 3:42 am Post subject: Cowl clearance? |
Chris
I believe that AFP makes an additional little angle wedge that you
can use to get your clearance. While you are at it order one of their
little waffle valves. It is a good idea for that unit.
Tom Martin
