barcusc(at)comcast.net Guest
Posted: Sat Feb 10, 2007 8:21 am Post subject: XL Kit & Engine for sale |
For personal reasons I am selling my 601 XL kit and completely assembled Corvair engine using nearly all of William Wynne's parts.
601 XL Kit with the following options: Strobes, landing lights, wing locker baggage option, 2 axis trim, dual stick option, dual brakes, wheel fairings, upgraded to latest drawings and components. Thorough documentation including pictures, log and receipts. Rudder, elevator, stabilizer, flaps, ailerons, two axis trim finished. Both wings complete including wing lockers, controls and wiring, except outboard ends need trimmed and end caps put on. Rear fuselage assembled, cabin floor, rudder pedals and brakes assembled but not riveted yet. Paid $18,569 not including shipping, will sell for $14,900. Located near Nashville, Tennessee. Total hours to date: 1000
William Wynne Corvair Conversion and firewall forward package. I do not have the carb, alternator or deep sump pickup. Paid $7,701, will take $5,700. Crankshaft was nitrided.
Company Part # Price Extra capacity oil pan Albert Ramsey $150.00 Used Corvair Engine Albert Ramsey $275.00 Rear Oil Accessory Case William Wynne $249.00 Corvair Engine installation William Wynne $20.00 Warp Drive Prop William Wynne $600.00 Dual Ignition Distributor William Wynne $239.00 Damper William Wynne $100.00 CNC Machined Prop Hub William Wynne $319.00 Modified Crank w/shaft, studs & hardware. William Wynne $449.00 Alternator Pulley William Wynne $59.00 Front Starter Kit William Wynne $645.00 13" spinner bulkhead William Wynne $149.00 Fiberglass Nosebowl William Wynne $349.00 Motor Mount William Wynne $639.00 Stainless Intake William Wynne $269.00 Stainless Exhaust William Wynne $499.00 SET--Pistons, Chrome Rings, Cylinders Clark's C8327 $630.25 SET-- Reconditioned & Balanced Rods Clark's C9203 $236.00 Assemble pistons, rods & pins (set) Clark's C8828R $25.00 New OT-10 Cam & Billet Gear assembled Clark's C8800FG $275.05 Gasket set Clark's C120WW $92.40 Head Stud Nuts Clark's C-1089 $10.10 Blind Ended Nut for installing head studs Clark's C2001 $5.55 Oil Pump Primer Rod Clark's C-366 $4.15 Lifters Clark's C5856X $45.80 Valve guides Clark's C6702 $54.00 Intake Valves Clark's C3020P $30.60 Exhaust Valves Clark's C3022P $53.70 Valve Springs Clark's C8619 $52.85 Copper Head Gaskets Clark's C3946 $17.75 3/8 Drill Clark's C3440 $6.05 Helicoil 3/8 CoarseTap Clark's C3220 $19.85 Helicoil Installer Clark's C3221 $11.45 3/8 helicoil inserts for head studs (24) Clark's C3223 $50.40 ARP Studs SC Performance $240.00 Head Work & Welding Sexton's $359.10 Tubing for intake Burn's Stainless $36.14 Used Corvair engine Albert Ramsey $275.00 Spinner FP-13 Van's $160.00 Total $7,701.19
If interested contact offline.
Clyde Barcus
Hendersonville, TN
615-822-2135
