Pro seal
indigoonlatigo(at)msn.com
PostPosted: Mon Feb 12, 2007 10:45 am    Post subject: Pro seal Reply with quote
I used some proseal from Van's which was sold in the caulking tube style
system.
I read the instructions several times and for the life of me without any
pictures, the directions made aboslutley no sense to me. I ended up
shooting the catalyst tube into the main product tube and then expelling it
out and hand mixing.
The question is how long does it take before a skin starts forming on the
product. WHEN i DID THE trailing edges I left everthing for five days.
Fortunately I am only glueing the SV vents to the fuse but after two days,
it's like it is not setting.
How much time is required for a tacky skin to form.
John G
Greatful for not doing the fuel tanks.
jesse(at)saintaviation.co
PostPosted: Mon Feb 12, 2007 11:22 am    Post subject: Pro seal Reply with quote
If it is not cured after 2 days, I wonder if the catalyst didn't get mixed
well enough and possibly that part didn't get enough if any. I used one or
two of those tubes and they started skinning within 30 minutes if I remember
correctly. The stuff in the cans seems to take longer to cure, but always
seems to cure overnight. I have never seen any that takes 2 days to cure.
I would recommend removing the vents if they will come off, cleaning the
stuff off of them and trying it again with a new batch. I remember the
directions were not very easy to understand, but it seemed to work fine for
me.
Do not archive.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
rene(at)felker.com
PostPosted: Mon Feb 12, 2007 12:17 pm    Post subject: Pro seal Reply with quote
My 2 cents. Proseal needs to be mixed with the correct ratio or it will not
properly set. If I remember correctly, the set time on the stuff Vans sells
in the tubes is 30 Minutes, the can 2 hours. I think you did not get the
correct mix.
What color was it after you mixed it....black....grey......white....
Rene' Felker
40322
N423CF
801-721-6080
Albert Gardner
PostPosted: Mon Feb 12, 2007 1:03 pm    Post subject: Pro seal Reply with quote
After you push the catalyst into the main tube, I think you pull/push the handle for about 50 times to get it all mixed up before you push it out of the tube to use it. I'm sure you can mix it outside of the tube since that's the way we do it when we use the canned product. My experience with the stuff is that if the mix is just a little wrong it increases/decreases the curing time but it still cures. The properly mixed stuff should be kind of gray. The tubes are nice for the tanks since the nozzle lets you put down a nice bead inside the tanks but much more expensive than the bulk product. Also, you have to use/throw-away the tube but with the can you can mix up just what you need or, if short, just mix up a dab more. I use the old 1 dab on a popsicle stick to 10 dabs ratio and it works fine.
Albert Gardner
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
AV8ORJWC
PostPosted: Mon Feb 12, 2007 1:39 pm    Post subject: Pro seal Reply with quote
ProSeal is a trademarked product of PPG - DeSoto. FlameMaster makes a
similar product which is commonly confusing. Consistency is rated A, B
or C. They are mixed by product specification to a cure time of 1/4,
1/2, 1 and 2 hour set. The set process can be retarded by
refrigeration. The product has a shelf life as a perishable.
When properly mixed, it Does set and Does cure to final consistency.
Chewing gum comes to mind. It is paintable. When improperly mixed it
does not correctly cure.
B is the most often used in aviation. For Line aircraft, B1/4 sets the
quickest, B1/2 is most often used for initial construction or Heavy
Check (annual inspection) type repairs. When improperly mixed it never
becomes compliant and will fail. Spraying it with Isopropyl Alcohol
mist allows the operator to smooth the product and provide a finishing
touch. We use masking tape to form the sidelines. MEK dissolves it
before SET and is not recommended without correct clothing and barrier
skin protection.
It has many uses, it stinks, it can be messy.
A proseal "professional" for the World's Top Regional Airline of 2007.
"Proseal... love it or leave it".
John, call me on my cellphone 503-453-6016, and I will share all the
wisdom of proseal.
John Cox
#40600
PostPosted: Mon Feb 12, 2007 1:56 pm    Post subject: Pro seal Reply with quote
It turned grey. The black catalyst was mixed thoroughly, but I think the
catalyst quantity may have been higher in what remained in the tube(Unused
portion).
I'll pull the vents tonight and clean it all off. I've got some special
epoxy that I should have used from the start. Still don't understand the
mixing action by placing 10% into the tube, then pushing the tube in, then
putting in the rest, then pumping it, then rotating 340 degrees clockwise,
then one quarter turn counterclockwise. Or what ever. I re read it again
this am and it still made noi sense to me.
Just glad it worked for all you working on serious areas like fuel tanks.
guess I am just a visual type of guy. Thinking too hard.
I should have just mixed it like I did the can stuff, with my Pezo scale.
Thanks for the answers.
John G.
[quote]From: "Rene Felker" <rene(at)felker.com>
Subject: RE: Pro seal
Date: Mon, 12 Feb 2007 13:18:03 -0700
not
sells
correct mix.
Rene' Felker
40322
N423CF
801-721-6080
PostPosted: Mon Feb 12, 2007 2:30 pm    Post subject: Pro seal Reply with quote
As I remember it there are actually two plungers. One is to push the
catalyst into the black stuff and the other is to mix the black stuff. You
were supposed to push the catalyst plunger about 10% in to add 10% of the
catalyst to the black stuff at that end, then slowly push the mixing plunger
into the tube while adding the catalyst as well. This distributed the
catalyst in the black stuff (man, I wish I could get away from that term).
Then, after the catalyst is completely added, you mix it together with the
mixing plunger by pumping it a certain number of times, then twisting and
pumping again just in case it wasn't getting thoroughly mixed the first
time. Then, as I remember, you unscrew one of the plungers and screw on the
nozzle and start dispensing. It didn't make sense to me at first, but this
is my understanding now, and it seemed to work, as I mentioned before.
Do not archive.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
rv10builder(at)bellsouth.
PostPosted: Mon Feb 12, 2007 3:57 pm    Post subject: Pro seal Reply with quote
A tip for thorough mixing is to use a tap in a cordless drill, then
insert into the handle. Next best thing to machine mixing and will
ensure a good setup. I do recall encountering the same long setup time
when I attached my vents. I attributed it to my garage being cold at
the time. That's been a while ago and I am certain they're not going to
come off easily.
Brian
#40308
http://www.mykitlog.com/rv10builder
tadsargent(at)bellsouth.n
PostPosted: Mon Feb 12, 2007 4:00 pm    Post subject: Pro seal Reply with quote
I don't remember the origional post on Proseal cure but I have spoken to THE
lab at Flamemaster. The company who makes the stuff. The cure time is 48
hours at 77 degrees, then add 2 hours for each degree below 77 for a total
cure time.
Tad Sargent
7A and building a 10
KiloPapa
PostPosted: Tue Feb 13, 2007 12:19 am    Post subject: Pro seal Reply with quote
I had a similar slow set time in the cold, dry high desert
of SoCal. I called the company and they said each 10
degrees cooler than listed specs would double the set time
if I recall correctly. The set time listed is at a specific
temp and humidity. Cooler and dryer would certainly affect
that. It did finally set for me but took much longer than
the listed specs. (It was fresh stock from Van's)
Kevin
40494
----- Original Message Follows -----
Subject: Pro seal
Date: Mon, 12 Feb 2007 10:43:25 -0800
caulking tube style system.
me without any pictures, the directions made aboslutley no
sense to me. I ended up shooting the catalyst tube into
the main product tube and then expelling it out and hand
mixing.
forming on the product. WHEN i DID THE trailing edges I
after two days, it's like it is not setting.
John G
Kevin
40494
