Posted: Wed Feb 07, 2007 6:25 pm Post subject: The RV Smile - continued |
On Saturday, January 27th, RV4 pilot Jack Phillips took RV10 builder,
Bill Watson, for his first ride in an RV at Lake Ridge Airport, Durham NC.
The aircraft performed as designed, the pilot flew the aircraft with a
high degree proficiency, and an RV smile was firmly planted on both the
face and mind of the passenger. A little stick time for the pedal-less
rear seat passenger only served to deepen the smile.
It has been noted that an RV10 doesn't fly like an RV4 (neither do
Maules or Pietenpols for that matter). Nonetheless, riveting has
resumed with increased vigor at the Lake Ridge birthplace of #40605.
Thank You Jack Phillips for passing on the Smile.
Jack.Phillips(at)cardinal Guest
Posted: Fri Feb 09, 2007 8:45 am Post subject: The RV Smile - continued |
Not problem, Bill. I thoroughly enjoyed it. Now I've got to step up my efforts on the RV-10 to see if I can catch you. You've managed to get way ahead of me!
Jack Phillips
RV-10 # 40610
wayne.e(at)grandecom.net Guest
Posted: Sat Feb 10, 2007 5:27 am Post subject: The RV Smile - continued |
Hey Jack,
Do you always send encrypted messages :>} What the heck was that.
Wayne Edgerton #40336
Time: 08:45:53 AM PST US Subject: The RV Smile - continued From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com (Jack.Phillips(at)cardinal.com)>
LS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogTWF1bGVEcml2ZXIgPE1hdWxlRHJpdmVy
QG5jLnJyLmNvbT4NCg0KT24gU2F0dXJkYXksIEphbnVhcnkgMjd0aCwgUlY0IHBpbG90IEphY2sg
UGhpbGxpcHMgdG9vayBSVjEwIGJ1aWxkZXIsDQpCaWxsIFdhdHNvbiwgZm9yIGhpcyBmaXJzdCBy
aWRlIGluIGFuIFJWIGF0IExha2UgUmlkZ2UgQWlycG9ydCwgRHVyaGFtIE5DLg0KDQpUaGUgYWly
Y3JhZnQgcGVyZm9ybWVkIGFzIGRlc2lnbmVkLCB0aGUgcGlsb3QgZmxldyB0aGUgYWlyY3JhZnQg
d2l0aCBhDQpoaWdoIGRlZ3JlZSBwcm9maWNpZW5jeSwgYW5kIGFuIFJWIHNtaWxlIHdhcyBmaXJt
bHkgcGxhbnRlZCBvbiAgYm90aCB0aGUNCmZhY2UgYW5kIG1pbmQgb2YgdGhlIHBhc3Nlbmdlci4g
IEEgbGl0dGxlIHN0aWNrIHRpbWUgZm9yIHRoZSBwZWRhbC1sZXNzDQpyZWFyIHNlYXQgcGFzc2Vu
Z2VyIG9ubHkgc2VydmVkIHRvIGRlZXBlbiB0aGUgc21pbGUuDQoNCkl0IGhhcyBiZWVuIG5vdGVk
IHRoYXQgYW4gUlYxMCBkb2Vzbid0IGZseSBsaWtlIGFuIFJWNCAobmVpdGhlciBkbw0KTWF1bGVz
IG9yIFBpZXRlbnBvbHMgZm9yIHRoYXQgbWF0dGVyKS4gIE5vbmV0aGVsZXNzLCByaXZldGluZyBo
YXMNCnJlc3VtZWQgd2l0aCBpbmNyZWFzZWQgdmlnb3IgYXQgdGhlIExha2UgUmlkZ2UgYmlydGhw
bGFjZSBvZiAjNDA2MDUuDQoNClRoYW5rIFlvdSBKYWNrIFBoaWxsaXBzIGZvciBwYXNzaW5nIG9u
IHRoZSBTbWlsZS4gDQoNCiANCg0KTm90ICBwcm9ibGVtLCBCaWxsLiAgSSB0aG9yb3VnaGx5IGVu
am95ZWQgaXQuICBOb3cgSSd2ZSBnb3QgdG8gc3RlcCB1cCBteSBlZmZvcnRzIG9uIHRoZSBSVi0x
MCB0byBzZWUgaWYgSSBjYW4gY2F0Y2ggeW91LiAgWW91J3ZlIG1hbmFnZWQgdG8gZ2V0IHdheSBh
aGVhZCBvZiBtZSENCg0KSmFjayBQaGlsbGlwcw0KDQpSVi0xMCAjIDQwNjEwDQoNCg0KDQoNCg0K
DQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09
PT09PT09PT09DQpfLT0gICAgICAgICAgLSBUaGUgUlYxMC1MaXN0IEVtYWlsIEZvcnVtIC0NCl8t
PSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCl8t
PSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIHRoZSBTdWJzY3JpcHRpb25zIHBhZ2Us
DQpfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEs
DQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09ICAgLS0+IGh0dHA6Ly93
d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQpfLT09PT09PT09PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAg
ICAgICAtIE5FVyBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpfLT0gU2FtZSBncmVhdCBjb250ZW50
IG5vdyBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0gICAtLT4gaHR0cDov
L2ZvcnVtcy5tYXRyb25pY3MuY29tDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg0KDQoKX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXwoKVGhpcyBtZXNzYWdlIGlzIGZvciB0aGUg
ZGVzaWduYXRlZCByZWNpcGllbnQgb25seSBhbmQgbWF5IGNvbnRhaW4gcHJpdmlsZWdlZCwgcHJv
cHJpZXRhcnksIG9yIG90aGVyd2lzZSBwcml2YXRlIGluZm9ybWF0aW9uLiBJZiB5b3UgaGF2ZSBy
ZWNlaXZlZCBpdCBpbiBlcnJvciwgcGxlYXNlIG5vdGlmeSB0aGUgc2VuZGVyIGltbWVkaWF0ZWx5
IGFuZCBkZWxldGUgdGhlIG9yaWdpbmFsLiBBbnkgb3RoZXIgdXNlIG9mIHRoZSBlbWFpbCBieSB5
b3UgaXMgcHJvaGliaXRlZC4KCkRhbnNrIC0gRGV1dHNjaCAtIEVzcGFub2wgLSBGcmFuY2FpcyAt
IEl0YWxpYW5vIC0gSmFwYW5lc2UgLSBOZWRlcmxhbmRzIC0gTm9yc2sgLSBQb3J0dWd1ZXNlIC0g
U3ZlbnNrYTogd3d3LmNhcmRpbmFsaGVhbHRoLmNvbS9sZWdhbC9lbWFpbAo
Posted: Tue Feb 13, 2007 7:05 am Post subject: The RV Smile - continued |
Hi Bill,
Apparently my earlier reply was garbled (was using my wife's computer), so I'll try again.
I was very happy to be able to produce the "RV Grin". I thoroughly enjoy flying my RV-4 and will miss it when I sell it (can't afford to own it and the RV-10 both). Now you understand why RV's are such popular airplanes. The RV-10 doesn't fly like an RV-4, but it shouldn't - you don't need or want a cross country cruising airplane to roll at over 140 degrees per second. The RV-10 climbs as well or better than the RV-4 and is faster. Most important it is MUCH more comfortable on a trip. My wife is getting tired of staring at the back of my head whenever we travel in the -4.
Now I've got to get cracking on the RV-10. You are way ahead of me - much more so than you should be since your kit was just 5 before mine.
Jack Phillips
RV-4 N18LR
Pietenpol Air Camper NX899JP
RV-10 kit # 40610 (N142KW reserved)
Finishing the elevators
