Sound Proofing
acs(at)acspropeller.com.a
PostPosted: Thu Feb 02, 2006 2:29 pm    Post subject: Sound Proofing Reply with quote
I seem to recall a discussion on the pros and cons of soundproofing the -10.
Can anyone enlighten me or point me to where this info was posted?
John
40315#
LarryRosen
PostPosted: Thu Feb 02, 2006 2:50 pm    Post subject: Sound Proofing Reply with quote
Pros
It keeps the interior quiet (the key is to put the sound proofing in the
important locations to get the most noise reduction with the least
amount of material which is difficult to know before the plane is flying)
May add thermal insulation
Cons
Added weight
Potential for corrosion by trapping moisture especially in areas that
you cannot inspect (like under the floor panels)
Alternate
Use ANR headsets
Just my 2 cents
Larry Rosen
RV-10 #356
http://lrosen.nerv10.com
Larry Rosen
#40356
N205EN (reserved)
<http>
