				 Posted: Tue Feb 13, 2007 3:21 pm    Post subject: Dangerous UL Pilots??? |
				Things happen... though most are preventable, they
 | happen a lot more than they do to GA aircraft.
 |                                 -Dana
 Dana:
 Where have you been the last 20 or so years?
 You may be enlighted by reading the FAA daily accident briefs each
 morning.  I am amazed at the busted and broken airplanes, dumb stunts,
 and accidents GA aircraft and pilots are involved in each day.  Yes,
 and they kill themselves at an alarming rate.  Yesterday was an
 exception.  One accident reported and one fatality.
 I'll put my ultralight pilots up to your GA pilots any day of the
 week.  For example, take Oshkosh and Lakeland, we fly thousands of
 hours each year at both places, in and out of very tight, short grass
 airstrips, with no voice communications, no control tower, or other
 type control.  Very seldom do we have someone bust their ass.  Can not
 say that for the other side of the airport at OSH or LAL.  Yes, we
 have been flying that way, very safely, more than I have been around
 ULs, and I started in 1984.
 Prior to my interests in UL there were a lot of horror stories from
 folks deciding the could fly because they thought they could.  I think
 most of those days have been over for a long, long time.
 UL/Lt Planes are a lot more sophisticated now than they were in the
 early days.  One exception if Kolb aircraft.  They have been built
 tough since the beginning.  That is why I chose to build and fly them.
 Take care,
  _________________ John Hauck
Titus, Alabama |
		d-m-hague(at)comcast.net Guest
				 Posted: Tue Feb 13, 2007 4:31 pm    Post subject: Dangerous UL Pilots??? |
				At 06:21 PM 2/13/2007, John Hauck wrote:
 and accidents GA aircraft and pilots are involved in...
 No doubt.  My point was that when Part 103 was created, UL planes *were*
 crashing with distressing regularity, so the congested area prohibition
 made sense.  Things have gotten a LOT better since then, of course, but a
 person could still (perfectly legally) fly a dangerous UL, or fly with no
 training.
 I still suspect the UL accident rate is worse than GA's, but I don't know
 by how much... and I could very well be wrong.  The problem is that there
 is no record keeping; the FAA / NTSB don't report or even investigate UL
 crashes, except to determine that it was indeed an ultralight.
                                  -Dana
 Don't put it off, procrastinate today.
				 Posted: Tue Feb 13, 2007 5:11 pm    Post subject: Dangerous UL Pilots??? |
				Dana Hague wrote:
  a person could still (perfectly legally) fly a dangerous UL, or fly with
  no training.
  know by how much... and I could very well be wrong.  The problem is that
  there is no record keeping; the FAA / NTSB don't report or even
  investigate UL crashes, except to determine that it was indeed an
  ultralight.
                                  -Dana
 In the homebuilt experimental world, the accident rate is significantly
 higher during the test period. After that, the rate is within normal
 deviation of factory planes rate. If test period hours and corporate jet
 & other turbine flight hours were removed from the numbers, homebuilts
 would probably have a better record than other piston a/c.
 Truth is, the restrictions are political in nature, intended to give the
 appearance of safety with no actual value. Kinda like when they look up
 your privates before you get on an airliner.
 "Be afraid. Now trust on your government to protect you."
 If you are flying a cross-country in a homebuilt & using atc when near a
 major metro area with class B airspace, It's quite likely that the
 controller will take you directly over his active runways if you are
 crossing at right angles to the runway. This path minimizes conflict
 with his 'heavy' traffic.
 Bottom line: we can either accept the 'show' of safety written into this
 rule, or work to educate the 99.5% of the public who's never flown in
 *any* small plane & are deathly afraid of the unknown.
 Charlie
		Steven Green
				 Posted: Tue Feb 13, 2007 5:15 pm    Post subject: Dangerous UL Pilots??? |
				I have read FAA reports where unregistered planes such as this one were
 involved in a fatal accident and no investigation was done.  There are
 exceptions.  This one got a lengthy investigation.
 http://www.ntsb.gov/ntsb/brief2.asp?ev_id 050705X00921&ntsbno=DEN05FA100&akey=1
  	  | Quote: | 	 		   crashes, except to determine that it was indeed an ultralight.
                                   -Dana
  _________________ Steven Green |
				 Posted: Tue Feb 13, 2007 5:41 pm    Post subject: Dangerous UL Pilots??? |
 Steven:
 We know why this one gotten investigated.  Probably had something to
 do with being a multi-billionaire.
 DO NOT ARCHIVE
Titus, Alabama |
				 Posted: Tue Feb 13, 2007 6:01 pm    Post subject: Dangerous UL Pilots??? |
				At 08:13 PM 2/13/2007, Steven Green wrote:
 Unregistered plane, yes... but true ultralights, no (though there are
 exceptions).
                                  -Dana
				 Posted: Tue Feb 13, 2007 6:19 pm    Post subject: Dangerous UL Pilots??? |
				At 08:11 PM 2/13/2007, Charlie England wrote:
 In most cases (especially the current Transportation Security Gestapo) I'd
 agree with you, but Part 103 is a gift... they could have just said
 register all aircraft, even hang gliders, and license all pilots.  That
 they didn't would be unthinkable in today's political climate, and amazing
 even then.  Certainly there are things I'd like to change in 103 (SP/LSA
 completely missed the original target), but not at the risk of having them
 revise the whole thing.
  	  | Quote: | 	 		  Bottom line: we can either accept the 'show' of safety written into this
 The public doesn't *want* to be educated.  They'd rather feel safe taking
 off their shoes before boarding an airliner and evacuating buildings when
 somebody shakes his jelly donut and leaves "suspicious white powder" on his
 desk.
                                  -Dana
				 Posted: Tue Feb 13, 2007 6:21 pm    Post subject: Dangerous UL Pilots??? |
 are
 | exceptions).
 |                                 -Dana
 About 99.9 % of the ULs out there are really unregistered airplanes,
 by the regs.
 DO NOT ARCHIVE
Titus, Alabama |
				 Posted: Tue Feb 13, 2007 7:01 pm    Post subject: Dangerous UL Pilots??? |
				Dana Hague wrote:
 > <ceengland(at)bellsouth.net>
 > the appearance of safety with no actual value. Kinda like when they
 > look up your privates before you get on an airliner.
  amazing even then.  Certainly there are things I'd like to change in 103
  (SP/LSA completely missed the original target), but not at the risk of
  having them revise the whole thing.
 > this rule, or work to educate the 99.5% of the public who's never
 > flown in *any* small plane & are deathly afraid of the unknown.
  taking off their shoes before boarding an airliner and evacuating
  buildings when somebody shakes his jelly donut and leaves "suspicious
  white powder" on his desk.
                                  -Dana
 We are in agreement; That's the point I was (rather inadequately) trying
 to make.
 While I understand the pragmatic implications of your phrasing, I would
 disagree that it's a 'gift'. The authorities consider *anything* we do a
 'gift' from the authorities. This is a radical departure from the intent
 of those who framed the constitution. We should never miss a chance to
 tell our elected officials the we disagree.
 Charlie
				 Posted: Tue Feb 13, 2007 7:04 pm    Post subject: Dangerous UL Pilots??? |
				At 09:21 PM 2/13/2007, John Hauck wrote:
 by the regs.
 True.  Some are more blatant than others, though.
                                  -Dana
