donaho(at)csrlink.net Guest
Posted: Thu Feb 02, 2006 2:22 pm Post subject: Detroit & Sunday 10 mile no fly zone |
Hi all, I saw on the news that there is a 10 mile NO FLY zone around the
super bowl this Sunday. Lanny Fetterman N598 LF Firestar II Do
not archive
johndeereantique(at)qwest Guest
Posted: Thu Feb 02, 2006 3:38 pm Post subject: Detroit & Sunday 10 mile no fly zone |
I heard it was 30 mile?
Gary r. voigt
David.Lehman
Joined: 10 Jan 2006 Posts: 265 Location: "Lovely" Fresno CA
Posted: Thu Feb 02, 2006 3:48 pm Post subject: Detroit & Sunday 10 mile no fly zone |
30 miles...
http://tfr.faa.gov/save_pages/detail_6_1310.html
Gary r. voigt
_________________ ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw |
rlaird
You guys really need to go to the source.... here's the TFR...
6/1310 - PART 1 OF 4 MI.. FLIGHT RESTRICTIONS FORD FIELD, DETROIT, MI.
PURSUANT TO TITLE 14 CFR SECTION 99.7, SPECIAL SECURITY INSTRUCTIONS,
ALL AIRCRAFT FLIGHT OPERATIONS ARE PROHIBITED DUE TO THE NATIONAL
FOOTBALL LEAGUE SUPER BOWL. WITHIN A 30 NMR OF 422025N/0830243W OR THE
YQG305011.1 UP TO BUT NOT INCLUDING FL180. EFFECTIVE 0602052100 UTC
(1600 LOCAL 02/05/06) UNTIL 0602060459 UTC (2359 LOCAL 02/05/06).
WITHIN A 10 NMR OF 422025N/0830243W OR THE YQG305011.1 UP TP BUT NOT
INCLUDING FL180. EFFECTIVE 0602052100 UTC (1600 LOCAL 02/05/06) UNTIL
0602060459 UTC (2359 LOCAL 02/05/06). EXCEPT AS SPECIFIED BELOW
EXCLUDING CANADIAN AIRSPACE: A. ALL AIRCRAFT OPERATIONS WITHIN A 10
NMR AREA LISTED ABOVE ARE PROHIBITED EXCEPT FOR: 1. APPROVED LAW
ENFORCEMENT, MILITARY AIRCRAFT, EMERGENCY MEDICAL FLIGHTS IN DIRECT
CONTACT WITH ATC AND ARE SQUAWKING AN ASSIGN DISCRETE BEACON CODE. 2.
COMMERCIAL PASSENGER, PRIVATE CHARTER AND ALL-CARGO CARRIERS OPERATING
UNDER ONE OF THE FOLLOWING TSA-APPROVED STANDARD SECURITY
PROGRAMS/PROCEDURES: AIRCRAFT OPERATOR STANDARD END PART 1 OF 4 WIE
UNTIL UFN
PART 2 OF 4 MI.. FLIGHT RESTRICTIONS FORD FIELD, SECURITY PROGRAM
(AOSSP), DOMESTIC SECURITY INTEGRATION PROGRAM (DSIP), TWELVE FIVE
STANDARD SECURITY PROGRAM (TFSSP), PRIVATE CHARTER STANDARD SECURITY
PROGRAM (PCSSP), ALL-CARGO INTERNATIONAL SECURITY PROCEDURE (ACISP),
OR MODEL SECURITY PROGRAM (MSP) AND ARE ARRIVING INTO AND/OR DEPARTING
FROM 49 CFR PART 1542. 3. EXCEPT AS AUTHORIZED IN PART C. B. WITHIN
THE AIRSPACE BETWEEN 10 NMR AND 30 NMR LISTED ABOVE: 1. ALL AIRCRAFT
ENTERING OR EXITING THE 30 NM RADIUS TFR MUST BE ON AN ACTIVE IFR OR
VFR FLIGHT PLAN WITH A DISCRETE CODE ASSIGNED BY AN AIR TRAFFIC
CONTROL (ATC) FACILITY. AIRCRAFT MUST BE SQUAWKING THE DISCRETE CODE
PRIOR TO DEPARTURE AND AT ALL TIMES WHILE IN THE TFR. 2. ALL AIRCRAFT
ENTERING OR EXITING THE 30 NM RADIUS TFR MUST REMAIN IN TWO-WAY RADIO
COMMUNICATIONS WITH ATC. 3. ALL AIRCRAFT OPERATING WITHIN THE 10 TO 30
NM RADIUS TFR AND OPERATING AT ALTITUDES OF UP TO BUT NOT INCLUDING
FL180 ARE LIMITED TO AIRCRAFT ARRIVING OR DEPARTING LOCAL AIR- FIELDS
AND ATC MAY AUTHORIZE TRANSIT OPERATIONS. AIRCRAFT MAY NOT LOITER. END
PART 2 OF 4 WIE UNTIL UFN
PART 3 OF 4 MI.. FLIGHT RESTRICTIONS FORD FIELD, 4. FLIGHT TRAINING,
PRACTICE INSTRUMENT APPROACHES, AEROBATIC FLIGHT, GLIDER OPERATIONS,
PARACHUTE OPERATIONS, ULTRALIGHT, HANG GLIDING, BALLOON OPERATIONS,
AGRICULTURE/CROP DUSTING, ANIMAL POPULATION CONTROL FLIGHT OPERATIONS,
AND BANNER TOWING OPERATIONS ARE NOT AUTHORIZED. C. DETROIT
METROPOLITAN (DTW) ARRIVALS/DEPARTURES ARE AUTHORIZED UNDER THE
FOLLOWING CONDITIONS: 1. BE ON AN ACTIVE IFR FLIGHT PLAN WITH A
DISCRETE CODE ASSIGNED BY ATC. 2. REMAIN IN TWO-WAY RADIO
COMMUNICATIONS WITH ATC. D. AIRCRAFT OPERATORS WHO HAVE PREVIOUSLY
RECEIVED WAIVERS UNDER NOTAM 3/1862 MUST REAPPLY. ALL WAIVER
APPLICATIONS ARE SUBJECT TO THE PROVISIONS IDENTIFIED IN SECTION 521
OF PUBLIC LAW 108-199. APPLICATIONS CAN BE OBTAINED FROM THE FAA
WEBSITE AT HTTP://WAIVER.TFR.FAA.GOV E. FAA RECOMMENDS THAT ALL
AIRCRAFT OPERATORS CHECK NOTAMS FREQUENTLY FOR POSSIBLE CHANGES TO
THIS TFR PRIOR TO OPERATIONS WITHIN THIS REGION. NOTE THAT A SIMILAR
TEMPORARY FLIGHT RESTRICTION HAS BEEN ESTABLISHED IN ADJACENT CANADIAN
AIRSPACE. SEE CANADIAN NOTAMS. SYSTEM OPERATIONS SUPPORT CENTER, PHONE
END PART 3 OF 4 WIE UNTIL UFN
PART 4 OF 4 MI.. FLIGHT RESTRICTIONS FORD FIELD, 202-267-8276 IS THE
POINT OF CONTACT. THE FEDERAL AVIATION ADMINISTRATION /FAA/ SOSC,
PHONE 202-267-3333, IS THE COORDINATION FACILITY. END PART 4 OF 4 WIE
UNTIL UFN
Gary r. voigt
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Posted: Thu Feb 02, 2006 4:13 pm Post subject: Detroit & Sunday 10 mile no fly zone |
like i saidm, 30 miles....my news is the source...
Gary...
