voltmeter switch
kesleyelectric(at)chooseb
PostPosted: Wed Feb 14, 2007 9:16 am    Post subject: voltmeter switch Reply with quote
Bob and list,
In a reply a few days ago, it was suggested that a voltmeter on the endurance bus would be a good idea to monitor the health of the battery and the SD8 during alternator out operation. Rather than installing a second voltmeter, I am considering using a 2-3 switch for the e-bus alternate feed and wiring it as shown on the attached diagram. The voltmeter is a UMA "steam gauge". The voltmeter would read the voltage on the appropriate bus, according to the position of the switch.
Feedback welcome.
Tom Barter
Avid Magnum
voltage_monitor_switch.pdf
 Filename:  voltage_monitor_switch.pdf
 Filesize:  79.88 KB
 Downloaded:  206 Time(s)
PostPosted: Fri Feb 16, 2007 9:19 am    Post subject: voltmeter switch Reply with quote
From: kesleyelectric [mailto:kesleyelectric(at)chooseblue.coop]
Sent: Wednesday, February 14, 2007 11:14 AM
To: Aeroelectric-list (aeroelectric-list(at)matronics.com)
Subject: voltmeter switch
Bob and list,
Feedback welcome.
Tom Barter
Avid Magnum
 Filesize:  79.88 KB
 Downloaded:  207 Time(s)
nuckollsr(at)cox.net
PostPosted: Fri Feb 16, 2007 10:01 am    Post subject: voltmeter switch Reply with quote
Bob and list,
Feedback welcome.
That's how I would do it.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
