LarryRosen
Posted: Thu Feb 15, 2007 7:23 pm Post subject: Camlocs (was Oil access pannel) |
Vic use Cam locs on his 10. I have some photos of his plane from
Sun-N-Fun posted here
<http://lrosen.nerv10.com/Construct/SunNFun_2006/Vic%20RV10/index.html>
These only show them from the exterior.
Some installation photos I have been sent from other builders including
Mark's are here
<.http://lrosen.nerv10.com/Construct/camloc/index.html>
Jeff's RV-7a site has some good cam loc info
<http://jeffsrv-7a.com/ENGINE.htm> about 1/2 way down in the Cowling
Section.
Larry
#356
Niko wrote:
[quote] Mark,
Do you have any pictures of your mounting you can share with the group?
Niko
40188
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
wayne.e(at)grandecom.net Guest
Posted: Fri Feb 16, 2007 6:40 am Post subject: Camlocs (was Oil access pannel) |
If any of you want photos of the cam lock install just let me know and I can forward them to you.
Wayne Edgerton #40336
LloydDR(at)wernerco.com Guest
Posted: Fri Feb 16, 2007 7:17 am Post subject: Camlocs (was Oil access pannel) |
I would like them and I am sure many others would too. Can you send them to Tim and he can post them under the mods section?
Tim is this good?
Dan
N289DT
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
Sent: Friday, February 16, 2007 9:40 AM
Subject: Re: Camlocs (was Oil access pannel)
gorejr(at)bellsouth.net Guest
Posted: Fri Feb 16, 2007 7:33 am Post subject: Camlocs (was Oil access pannel) |
I would like to see the pics. Did you use hinges on one side and camlocks? Jim
Date: 2007/02/16 Fri AM 10:17:08 EST
Subject: RE: Camlocs (was Oil access pannel)
Tim is this good?
Dan
N289DT
_____
Edgerton
