3300A Electrical System Questions
jeffrey_davidson(at)earth
PostPosted: Mon Feb 19, 2007 8:56 am    Post subject: 3300A Electrical System Questions Reply with quote
I have my 3300A physically installed in my CH601 HD using the JabiruUSA FWF kit. I have a couple questions about the electrical system. First, let me also tell you that I am an electrical novice, so I may be missing some rather basic information.
I have Revision 4 of the 3300A Installation Manual dated 22/08/03. On page 10 is the electrical system. It does not include a battery contactor. Why is one not included? Is there a problem if I decide to add one based on other builder's recommendations?
On the same diagram, the master switch controls only the battery. There is no alternator master switch. Looking at the figure on page 18, the single phase alternator is hooked up very differently than the old three phase alternator. I have been told that Jabiru used to recommend an alternator master switch. Does that only apply to the old three phase alternators? Do I need one?
Thank you.
Jeff Davidson
Herndon, Virginia
Duncan.Bennett(at)talktal
PostPosted: Mon Feb 19, 2007 11:55 pm    Post subject: 3300A Electrical System Questions Reply with quote
Hi Jeff,
<![if !supportEmptyParas]> <![endif]>
The alternator master is only needed with the old 3 phase. It was necessary to prevent the rectifier burning out when the engine had not been started but the master was on.
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->Duncan Bennett
<![endif]--><![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com]On Behalf Of Jeff
Sent: 19 February 2007 16:55
Subject: 3300A Electrical System Questions
Thank you.
Jeff Davidson
Herndon, Virginia
[quote]<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]> - The JabiruEngine-List Email Forum ---> http://www.matronics.com/Navigator?JabiruEngine-List   - NEW MATRONICS WEB FORUMS ---> http://forums.matronics.com<![if !supportEmptyParas]> <![endif]>[b]
tonyplane(at)bellsouth.ne
PostPosted: Tue Feb 20, 2007 7:50 am    Post subject: 3300A Electrical System Questions Reply with quote
Jeff,
I use a battery contactor on my Zodiac 601XL/Jab3300A, activated by the
master switch. I also use a relay operated by an alternator switch to bring
power from the alternator to the buss bar. The "Master Switch" is a split
Cessna type (Master and Alternator switch). If you close the Alt you
automatically close the Master. I procured the relay from Radio Shack.
Tony Graziano
Buchanan, Tn
N493TG, 209 hrs
Time: 08:56:12 AM PST US
decide
the
recommend
Thank you.
Jeff Davidson
Herndon, Virginia
