barry(at)pgtc.com Guest
Posted: Mon Feb 19, 2007 1:04 pm Post subject: GSC Propeller |
I would be remiss if I did not make other owners of GSC props aware of this. I think the people at GSC are good competent people and don't want to say nor do anything to hurt their business but feel I must get this message out.
Yesterday I took off from the airport and right after leveling at 2500 all three blades departed the hub. I landed the 912 S powered Kitfox with out any problems. This was an updated three blade with the aluminum bases and a bolt going through the aluminum base and the wood blade. The blades came out clean, leaving wood on the barbs of the bases, on the long wood screws that ran parallel to the blades and a chunk of wood behind each bolt.
There was a big bump when it occurred and the engine was definitely moved within the mounts but seems to have returned to its original position. One carb came out of its socket and this is probably what kept the engine from over revving.
I have already communicated with Lockwood and GSC and will speak to John McBean soon.
Barry West
smokey_bear_40220(at)yaho Guest
Posted: Mon Feb 19, 2007 1:51 pm Post subject: GSC Propeller |
Thanks for the info Barry. Glad you are still here to
tell us. Someone is definately looking out for you,
besides the expert airmenship too.
Kurt S.
--- Barry West <barry(at)pgtc.com> wrote:
| Quote: | Yesterday I took off from the airport and right
hub..............
Be a PS3 game guru.
Get your game face on with the latest PS3 news and previews at Yahoo! Games.
http://videogames.yahoo.com/platform?platform=120121
Float Flyr
Posted: Mon Feb 19, 2007 2:35 pm Post subject: GSC Propeller |
I know if it were me I would need the seat pads in the plane replaced too.
Don't bother playing the lottery for a while.... You've used up a fair
supply of good luck!
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
d(at)cfisher.com Guest
Posted: Mon Feb 19, 2007 3:51 pm Post subject: GSC Propeller |
Did it look like this ?
http://www.cfisher.com/gsc/
All props can depart at anytime, That is why i have a 1/8" atached to engine and airframe in case of separation.
You lose your engine in a Kitfox and I think you will be outta control .
I have hands on experience in blade departures as well. The one in picture was not mine.
Glad it all worked out for you.
Practice does not make perfect but it sure is better than without.
I did some dead stick videos on youtube as well.
Dave
dosmythe(at)cox.net Guest
Posted: Mon Feb 19, 2007 4:34 pm Post subject: GSC Propeller |
Dave,
Please re-read what you posted and explain. A 1/8" what?
[quote] All props can depart at anytime, That is why i have a 1/8" atached to engine and airframe in case of separation.
flier(at)sbcglobal.net Guest
Posted: Mon Feb 19, 2007 5:01 pm Post subject: GSC Propeller |
Hey Barry,
How many hours were on the blades? Was the aircraft always hangared? Did the prop ever see weather?
Just fyi, concerning the bolt through the blade roots GSC advised the hubs for the 912 have always been that way.
Ted
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Barry West
Sent: Monday, February 19, 2007 2:52 PM
To: Kitfox List
Subject: GSC Propeller
Barry West
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
