nuckollsr(at)cox.net Guest
Posted: Wed Feb 21, 2007 6:00 am Post subject: Stripping Longer Piece of Shielded/Twisted Pair Wire |
At 10:48 PM 2/20/2007 -0600, you wrote:
| Quote: | I have a few electrical cables (e.g., from nav lights) to my panel that
are shielded/twisted pairs. One of the wires goes to the panel switch and
the other goes to the ground block on the firewall. Is there any easy way
to strip of 2' to 3' of the outer cable jacket so I can reach both the
switch and the ground block without splicing in a piece of wire to run to
the ground block?
You have a ground block located adjacent to the switches?
Interesting. In answer to your question, try a pair of
cuticle scissors, the slim points can be pushed under the
jacket and between the twisted wires far enough to allow the
shears to cut the jacket away. Obviously, this doesn't work
on single conductor cable.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
