nuckollsr(at)cox.net Guest
Posted: Thu Feb 22, 2007 1:29 pm Post subject: Magneto failure in general, Was: Re: P Mags |
At 11:11 AM 2/22/2007 -0700, you wrote:
Quote: |
Hello Bob,
I have read/been-told that cycling the mag switch while at high power
settings might cause the engine to backfire if one mag is dead and the
other is turned back on, and that such a backfire might damage components
of the intake and exhaust systems.. What do you think about this?
That is a risk. Magenetos will do it too but is it a
"backfire"??? When the engine is totally deprived of
ignition it continues to pull stoichiometric mixture through
the plumbing. Then when any source of ignition returns, there's
a volume full of unburned mixture that includes the entire
exhaust system and any cylinder with an exhaust valve open
at the time this volume gets lit off.
I've experienced this on the ground when doing mag checks
where I inadvertently turned off both mags during a run-up
and then got them back on while the engine was still
turning. Folks have done this in their cars too and I've
heard of mufflers being split open from the resulting
explosion. Hmmm . . . guess we need to agree on the word
"backfire" which I use as ignition on the intake side of the
cylinders. Does this make the exhaust side explosion a
"foreward fire"?????
In the common public vernacular, a loud report from a
vehicle is referred to as "backfire" . . . I suppose because
it blows flames out the back of the car . . .
Oh well, I THINK we know what we're talking about!!!!
Posted: Thu Feb 22, 2007 1:30 pm Post subject: Magneto failure in general, Was: Re: P Mags |
At 01:50 PM 2/22/2007 -0500, you wrote:
Quote: | Good Afternoon Matt,
The procedure, as taught, is to be very sure you DO NOT turn on the
remaining good magneto if the engine does quit. The drill then is to put
the mixture in full lean, count to ten, turn on the magneto and slowly
richen the mixture until the engine starts.
I have never had it happen that way and I am sure it will take a lot of
discipline to wait those few seconds for the engine to clear itself before
the magneto is placed back in service!
It does help if the operator has experience deliberately running fuel
tanks dry.
That procedure is another one that is rarely taught these days, but having
run a tank dry often does instill confidence in the restart procedure.
Hadn't heard that one. Makes a lot of sense. Something
to check my instructor on at the next checkride!
dsleepy47(at)hotmail.com Guest
Posted: Thu Feb 22, 2007 3:58 pm Post subject: Magneto failure in general, Was: Re: P Mags |
In FAA terms a backfire would be fire in the intake which would go "back" through the carb or throttle body. "afterfiring" or "afterburning" is the term for burning in the exhaust. From a mechanics standpoint it would be nice to keep them straight because the items to check for damage after a backfire are different than an afterfire.
Deems
> Date: Thu, 22 Feb 2007 15:25:52 -0600
Bob .=====
Explore the s=7+wonders+world&mkt=en-US&form=QBRE' target='_new'>Learn more! [quote][b]
