dave(at)abrahamson.net Guest
Posted: Fri Feb 23, 2007 4:27 am Post subject: Magneto failure in general, Was: P Mags |
I am running a Slick mag (4371) and a Lightspeed Plasma II+
electronic ignition on my TMXO-360. Haven't started the engine yet,
so I don't know what a Lightspeed failure and good mag, or mag
failure and good Lightspeed, would sound like/do to the RPM, CHT, and
EGT. Nevertheless, here's my thinking. I am pretty sure that the
second case (mag failure) would be undetectable in flight, or hard to
detect since the Lightspeed does most of the ignition work. Should I
get a MP drop, EGT rise, and roughness in flight, however, I'd
probably be justified in first suspecting a Lightspeed
failure. Emergency action would be to turn the Lightspeed switch to
OFF to see if there was any change in the fault conditions. If not,
assume I'm on my one mag and divert to an airport with
services. However, if the engine ran rougher, turn the Lightspeed
switch back on, enrich, carb heat on, see what happens,
divert. Lastly, if engine quits, implying mag failure, pull mixture
to idle cut-off, wait 10 seconds, turn Lightspeed back on, slowly
move mixture to full rich (maintain glide slope, declare emergency,
locate rabbit's foot), and hope for the engine to come back on.
Does that sound right? Thanks. David
mprather(at)spro.net Guest
Posted: Fri Feb 23, 2007 5:18 am Post subject: Magneto failure in general, Was: P Mags |
It's possible that a mag can fail in such a way that it's timing is
dramatically off. In such a case, it would make sense to turn off the
magneto and fly just on your LSE. I don't see that in your procedure.
Matt-
<dave(at)abrahamson.net>
BobsV35B(at)aol.com Guest
Posted: Fri Feb 23, 2007 6:02 am Post subject: Magneto failure in general, Was: P Mags |
Good Morning David,
Sounds Good To Me!
However, I am not familiar as to what Lightspeed uses to adjust it's timing so it is difficult for me to evaluate your scenario.
Does the Lightspeed unit adjust it's timing based on reading some parameter of the actual combustion event or does it adjust based on mapped parameters?
I am sure you are aware that if you have fixed timing for both ignition systems and one fails, there will be a substantial increase in EGT.
Given the existence of a good all cylinder EGT system, it is easy to find a faulty spark plug or bad harness lead by observing the action of the EGTs. If all is well, the EGTs on each cylinder will rise about the same amount when one ignition system is not firing..
If one plug or harness lead is bad, the EGT will stay nice and steady when the good one is lighting the fire and drop precipitously when the bad plug should be firing the cylinder.
If you could educate me on the operation of the Lightspeed, I would certainly appreciate the education!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
In a message dated 2/23/2007 6:31:25 A.M. Central Standard Time, dave(at)abrahamson.net writes:
| Quote: | I am running a Slick mag (4371) and a Lightspeed Plasma II+
AOL now offers free email to everyone. Find out more about what's free from AOL at AOL.com. [quote][b]
n744bh(at)bellsouth.net Guest
Posted: Fri Feb 23, 2007 8:39 am Post subject: Magneto failure in general, Was: P Mags |
David,
I'm using one mag and one Lightspeed Plasma II+ also on an IO-360. I can almost guarantee that if the Lightspeed unit fails you will know it immediately by the sound of the engine. I've tried turning off one or the other in cruise and the difference between a mag being off and the Lightspeed being off is very audible. And when switching from mag only to mag and Lightspeed together you can feel the difference in the seat of your pants. Your only issue here is, as you have said, telling if there has been a mag failure.
Bill
Glasair Super IIS
mlas(at)cox.net Guest
Posted: Fri Feb 23, 2007 9:22 am Post subject: Magneto failure in general, Was: P Mags |
The LSE ignition system uses manifold pressure for detection for the timing advance. Their is an option for electrically advancing the system as well. But I haven’t used that function.
Mike
Posted: Fri Feb 23, 2007 11:54 am Post subject: Magneto failure in general, Was: P Mags |
Good Afternoon Mike,
Very interesting! I guess I will have to check their website and see if I can figure out what they are doing.
Do you run one LSE and a magneto or two LSEs?
If you do run one of each, have you noticed what the EGTs do during a pre takeoff run up/ignition check and how that changes if a high cruise power ignition system check is performed in flight?
I would assume that the pre takeoff check would have all EGTs rise when either ignition system is off and fall when they are both operating. Does it do that?
For the high power check, I would assume the change night be variable based on any number of factors including the altitude.
If the engine uses LSEs only, I would imagine the EGTs would react the same as with dual magnetos.
Any thought?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
In a message dated 2/23/2007 11:34:59 A.M. Central Standard Time, mlas(at)cox.net writes:
The LSE ignition system uses manifold pressure for detection for the timing advance. Their is an option for electrically advancing the system as well. But I haven't used that function.
Mike
Posted: Sat Feb 24, 2007 5:08 am Post subject: Magneto failure in general, Was: P Mags |
Thanks. Very glad that someone out there has the same setup as
me. When you turned off the mag in flight, what effect did you
see? If it's slight/minimal, perhaps this means that mag failure in
flight won't be noticed until you get on the ground. One other
question is, what is your shutdown procedure or pre-shutdown
procedure? Do you pull to idle cutoff and then switch both the mag
and LSE off, or do you shut one or the other off and then pull to
idle cutoff? I'm implying that shutting the LSE off prior to
shutdown would test the mag, and then you could pull to idle cutoff,
still burning up the fuel left in the system. Lastly, if you would
show me your emergency procedure checklist relating to the engine,
I'd be very interested. Thanks.
David
Posted: Sat Feb 24, 2007 5:36 am Post subject: Magneto failure in general, Was: P Mags |
I do cover that eventuality in "Lastly, if the engine quits...", but
running a diagnosis that stops a rough-running -- but otherwise
healthy engine, obviously needs to be refined. The core issue, I
think, is how you figure out the mag has failed/malfunctioned in
flight if the symptoms are very subtle, as I suspect they are if the
LSE is firing away lustily. I've asked Bill Hibbing what his
experience is with shutting off the mag in flight, and I plan to test
that myself when I take flight in a couple of months. It may be that
your only safe alternative is to shut off the mag to see if that
makes any difference, enrich and add carb heat, and if the roughness
persists, land and test the mag on the ground.
David
Posted: Sat Feb 24, 2007 6:56 am Post subject: Magneto failure in general, Was: P Mags |
Good Morning David,
Considering the vast array of engine monitoring equipment that is available today, don't you think that we should be able to get a lot of information from those systems that most of us use?
I find that most of my impending spark plug, harness and magneto problems give good early warnings on the engine monitoring equipment during a high power inflight ignition system check.
With a bit of monitoring, many mechanical aberrations can also be detected way before the engine gets rough.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
In a message dated 2/24/2007 7:43:36 A.M. Central Standard Time, dave(at)abrahamson.net writes:
| Quote: | --> AeroElectric-List message posted by: David Abrahamson <dave(at)abrahamson.net>
David
Posted: Sat Feb 24, 2007 5:35 pm Post subject: Magneto failure in general, Was: P Mags |
David,
With the Lightspeed operating I doubt if you'd notice anything if the mag
failed. When I shutdown on the ground I just pull the mixture although
shutting down with just the mag operating sounds like something I may have
to try. As far as an engine emergency I have just 3 steps. 1. FLY THE
AIRPLANE. 2. Take up a nearest toward the nearest suitable airport. 3.
Turn off the fuel and declare an emergency in case of a destructive failure.
Otherwise, troubleshoot if time permits.
We did have an interesting case withaCirrus powered by Continental. It
seems that the gear on one of the mags stripped and it was firing all over
the place. Unfortunately the person that was flying it at the time didn't
bother to check the mags and flew for 200 miles in this condition. It
destroyed the engine and it could have been prevented if he had simply
switched them off one at a time. I don't really know why he didn't land
when it happened and he's very lucky that the Feds didn't get wind of it as
it was a sure violation.
Bill
Posted: Sun Feb 25, 2007 5:44 am Post subject: Magneto failure in general, Was: P Mags |
You're right, I'm sure. The last airplane I owned was an Archer III
in which I had an Insight GEM installed. My RV7 has a GRT dual efis
with EIS and I have not had a chance to devote time to learning about
all the information I will be presented with, or how I am going to
interpret all that data. There is much to learn, but I figure that I
need to develop emergency procedures based on my current experience
set (feel, sound, EGT, CHT), knowing that I will/will need to refine
these procedures as I learn to best interpret a full screen of
graphical engine information.
David
