jhauck(at)elmore.rr.com Guest
Posted: Tue Jan 03, 2006 7:53 pm Post subject: 2 and 4 Stroke |
Hi Gang:
Been a lot of discussion about 2 and 4 stroke engines for our little
airplanes.
I had the opportunity to build and fly three 2 stroke powered Kolbs,
and am still flying the third one, but not with 2 stroke any more.
Did some serious cross country flying with a 447 point ign engine and
an original Firestar. Had a ball doing them all. Had some
disappointments, but survived them. Like an engine failure over the
Niagara River, just north of Buffalo, NY. Broke the airplane in the
process of getting me back on the ground. Got it repaired in about 4
days and flew a very bent FS back to Alabama. That engine out and
bent airplane was the decision point to rebuild the FS to do serious
cross country flying a little better than the first time around. BTW
the engine failure was caused by the NGK fine wire plugs I was using.
One of them let go of the tiny center electrode which lodged between
the ground strap and the base of the spark plug, effectively shutting
it down. Won't fly on one cylinder.
Don't ask me how I got off on that tangent, but what I wanted to share
was a very short description of what I see as the major difference
between the 2 and 4 stroke light aircraft engines. Primarily,
lubrication. The 4 stroke uses a dedicated, precision type, pressure
lube system. The 2 stroke uses a fuel/oil/air mix that relies on air
flow and chance to get things lubricated correctly.
As far as reliability is concerned, the area the 4 stroke is hands
down over the 2 stroke is piston to cylinder wall lubrication. Here
the 2 stroke does a good job as long as that microscopic film of oil
is kept in place between the piston and cylinder wall metal. If, at
anytime, it is broken, just a little bit, the piston is going to scuff
and probably seize in the cylinder. We don't have that problem with
the 4 stroke unless we loose oil pressure, and then the crank and rod
bearings are going to go first.
There are a lot of ways to break the oil film in a 2 stroke:
1-broken ring
2-stuck ring and a little blow by
3-produces a lot of carbon that might have a bearing on creating a
break in the oil film
4-acts of God
5-unnatural, mysterious, unexplainable acts
Can't think of any more at this time, but maybe you all can.
Correct me if I am wrong, but I don't know of any problems we have
suffered with the 4 stroke Rotax in the area of piston and cylinder
scuffing and seizing. In fact, the factory tolerance for piston to
cylinder wall clearance when new is 0.000 to 0.001". Not a whole lot
of clearance. However, another advantage of the 912 is the use of
plated aluminum cylinders and not cast iron or steel sleeves as used
in the 2 strokes.
Not looking for arguments. Thinking out loud tonight and wanted to
share my thoughts.
Most engine failures are operator induced on both 2 and 4 stroke
engines. I believe the critical difference is the all important oil
film on the cylinder wall.
hauck's holler, alabama
| - The Matronics Kolb-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
jlbaker(at)telepath.com Guest
Posted: Tue Jan 03, 2006 8:55 pm Post subject: 2 and 4 Stroke |
used |
Aaaakkkk! Heresy! My Hirth has the same Nikasil as your 912. So
there!
Jim Baker
580.788.2779
'71 SV, 492TC
Elmore City, OK
Posted: Tue Jan 03, 2006 9:13 pm Post subject: 2 and 4 Stroke |
| there!
| Jim Baker
Sorry Jim:
Was talking about Rotax (or is it Rotaxen?) Should have spelled that
out in my original post.
Rotax calls it something else, and my Suzuki DRZ400E 4 stroke thumper
calls it something else again, and Yamaha thumpers call their plating
something difference. Amazing technology. There is a plant in
Auburn, Alabama, that will replate a single cylinder for about
$150.00. When they finish with it, it is ready to go back together.
Send the new piston along with the cylinder so they can hone it to
specs. Will be a new cylinder no matter how bad you screw it up.
I imagine your Hirth still survives as long as that microscopic film
of oil is in place between piston and cylinder.
link(at)cdc.net Guest
Posted: Tue Jan 03, 2006 10:56 pm Post subject: 2 and 4 Stroke |
Gentlemen,
This has been the most interesting post session of the year. I guess I
have been very interested in this very subject. I have a pressure
washing business and use these little industrial engines and from what I
have seen would have no problem putting one behind me as a power plant.
I have used the briggs 18hp L-head engines at close to maximum power and
regularly get 3000 plus hours of service out of them. I have not used
the v-twins yet but plan on replacing both of my engines with them soon.
The question that I have is if you can get the engine to run slow enough
to run the prop with out a reduction drive. I truly believe that These
engines will bring about a new chapter in ultralight aircraft. I Thank
Don and all who have contributed to this post .
Steve Garvelink
lstavenhagen(at)hotmail.c Guest
Posted: Wed Jan 04, 2006 5:10 am Post subject: 2 and 4 Stroke |
Quote: | As far as reliability is concerned, the area the 4 stroke is hands
I'm not arguing either, but I do have an observation. I think the 2 and 4
stroke both have the same constraint here. I don't see this as a significant
difference between the two designs. 4-strokes also depend on a film of oil
keeping the piston and cylinder apart and if the film breaks down the
results are similar.
For example, one way the film of oil can be broken down on the 4-stroke is
excessively rich running. Too much raw gas in the cylinder can wash the oil
film away leading to piston/cylinder contact with the you-know-what result.
Don't ask me how I know this...
The main operative difference when it comes to the piston/cylinder
reliablity issue is probably thermal shocking and not lubrication. The
4-stroke has it all over the 2-stroke here. Because the 2-stroke fires on
every stroke, heat buildup is much more intense and rapid. Also, for
durability reasons, a steel liner is used in the Rotaxen - very very tough
and long wearing design, but susceptible to thermal shocking especially due
to it being a 2-stroke. A long period of idling followed by sudden sustained
full-throttle is a recipe for disaster in the 2-stroke (especially the water
cooled motors). The piston heats up much faster than the liner and expands
faster as well. In extreme cases, siezure is the result as the
piston/cylinder gap closes. Don't ask me how I know this either.
This is much less of a problem with the 4-stroke. The piston heats up a
somewhat less rapidly there, due to the extra intake/compression stroke
which helps slow down the heating of the piston. Generally, then, you can
hammer away with the throttle on a 4-stroke with much less danger of
siezure.
And yes the aluminum/nickasil liners also help with this since they tend to
expand at closer to the same rate as the piston.
If there is one single reason I would ever switch to a 4-stroke, this would
have to be it. They're so much more durable regarding thermal shocking than
the 2-stroke it's not even funny.
Then of course there's the fact that the 912 has a TBO 4x longer than the
2-stroke rotax and is just much beefier in general for the power output,
etc.....
All I need now is just to win the lottery and I can get my kolbra and 912
Anyway, just my thoughts while drinking my morning coffee.....
LS
N646F
jrjungjr(at)yahoo.com Guest
Posted: Wed Jan 04, 2006 5:34 am Post subject: 2 and 4 Stroke |
Group,
All this talk about a 35 hp Vanguard engine, with the torque of a 503
got my attention. So, I Googled it. It weighs 153 pounds.
Source: http://www.commercialpower.com/display/router.asp?docid=78080
John Jung
Firestar II N6163J
Surprise, AZ
Posted: Wed Jan 04, 2006 6:04 am Post subject: 2 and 4 Stroke |
Ack! 153 lbs? that's more than my suzuki G10. Now I will admit
that it IS physically more bulky than a rotax 2 stroke but after fuel
load
considerations you aren't talking more weight. There are both
a gear type and cog belt drive with good reps available.
What is the reluctance to use them, other than the undeniably
excellent 912 series? The brain cell taxing labor? Skill isn't a big
factor.
-BB, 4 stroke suzie, about $3000 invested including total overhaul
and redrive.
On 4, Jan 2006, at 8:34 AM, John Jung wrote:
Group,
John Jung
Firestar II N6163J
Surprise, AZ
donghe(at)one-eleven.net Guest
Posted: Wed Jan 04, 2006 6:40 am Post subject: 2 and 4 Stroke |
John,
The Liquid cooled 35 is a real brute...but a tad heavy I think. It has a
double wide clevite bearing on the PTO end of the crank..makes it look like
a lycoming crankshaft.
Anyway...they have an aircooled 35 also...same size...just under 1 litre but
28 lbs less at 125...of which alot is a hugh commercial aircleaner.
another thing I might add,..is the 25 horse engines out there have the
torque of a 503....the 31/33/35 class of engines is a whole lot more, no
matter who the nmanufacturer...
Take the Vanguard 35 aircooled at 52.2 ft lbs torque vs the 582 blue head at
51 ft lbs
and you have a closer comparison
The Vanguard LC 35 is rated at 55 ft lbs...now we are gonna run these thru a
reduction unit and get the speed down to ...say 2500....lets see...1.44 to 1
ratio...what is the torque now?....(where's Topher when ya need him!)
anyway...you fellas see what I mean..these thoughts have been working on me
for awhile..I certainly dont know for sure just how it would be..but the
numbers sure seem favorable.
Some of you know , or remember a year or 2 ago I was fooling around with a
24 hp vtwin and a 60 inch ivo 3 blade. I was able to turn the ivo at a hub
speed of 2200, pitched at the same degree that it was on my cuyuna. At 2200
hub speed..the firefly would run 60 mph.
now..how can that be?...Cuyuna ULII-02 rated at 38 hp and the Vtwin rated at
24hp...both close performance when bolted to a reduction drive with a prop
for the load?....pretty obvious that the torque was about the same.
....just some thinkin as I am competeing to drain the coffee pot this morn!
http://www.commercialpower.com/display/router.asp?docid=78069
Don Gherardini
OEM.Sales / Engineering dept.
American Honda Engines
Power Equipment Company
CortLand, Illinois
800-626-7326
Posted: Wed Jan 04, 2006 6:41 am Post subject: 2 and 4 Stroke |
Lucien, are you sure lubrication is not an issue???
| siezure.
Not in the "real world". Try it in an old Continental or Lycoming
aircraft engine. ;-(
tend to
Not actually a liner, but a coating. Aluminum coated cyls and pistons
expand at the same rate, thus the "zero to 0.001" clearance on 912
engines.
than the
output,
| etc.....
Not necessarily "beefier" but a better proven design.
DO NOT ARCHIVE
Posted: Wed Jan 04, 2006 7:03 am Post subject: 2 and 4 Stroke |
Quote: | | The main operative difference when it comes to the piston/cylinder
It doesn't seem to be, no. Thermal shock is far and away the more prevalent
cause of scuffing and siezure in the 2-strokes I've run or seen run to
destruction than any design problem with cylinder wall lubrication. The
basic principle is the same in both motor types, though the source of the
oil is different in each case.
When not thermal shocked leading to seizure, 2-stroke piston/cylinder
lubrication appears to work pretty well. The liners actually wear very
little; frequently new pistons can be put in liners at 400 some odd hours
and the clearances obtained are close to new limits...
Putting it another way, 2-strokes tend to blow up and rot away from
neglect/abuse much more than they actually simply wear out through normal
operation.
Don't ask me why I know this....
Quote: | Not in the "real world". Try it in an old Continental or Lycoming
I did for a number of years - the Continentals and Lycomings I learned
behind and rented took FAR more throttle abuse that I would ever dare to
attempt to put over on my 2-strokes, with nary a problem. To my knowledge,
all those motors ran right out to TBO......
Those motors are much more durable regarding thermal shocking than even the
air cooled 2-strokes, trust me .
Quote: | Not actually a liner, but a coating. Aluminum coated cyls and pistons
engines.
You're right - tnx for the correction....
Quote: | Not necessarily "beefier" but a better proven design.
Well, for example, take a 582 crank and set it beside a 912 crank. The delta
in terms of power output asked of them is only about 15 hp, but the
difference in size and strength is pretty substantial.......... That's what
I mean by beefy....
And yes it is a better proven design, IMO, probably the best 4-stroke on the
market.....
LS
N646F
Quote: | john h
DO NOT ARCHIVE
tophera(at)centurytel.net Guest
Posted: Wed Jan 04, 2006 8:28 am Post subject: 2 and 4 Stroke |
for the load?...
How can that be? Because the rating for the two strokes is at 6500 rpm and
the rating for the little industrial engines is at 3500.
Relationship between torque and HP is really simple: power in units of "hp",
torque is in "lb-ft", and rotation rate is in "rpm", then
power = torque dralle.txt gigi.txt grant.txt matt.txt save.txt rotation rate / 5252
(This means that the hp and torque curves always cross(they are equal) at
5252 rpm.)
So an engine with a hp rating given at a lower rpm will make more torque
then an engine with the same hp rating at a higher rpm.
Example:
Engine A makes 100 hp at 6000 rpm --> torque = 100*5252/6000= 87.5
Engine B makes 100 hp at 3000 rpm --> torque = 100*5252/3000= 157
Half the rpm twice the torque.
Put them both through a reduction drive to get them to the same rpm say 2200
so you can turn a nice big prop and they will both have the same torque.
Torque at 2200 = 100*5252/2200=238.7
100 hp at a given rpm is always the same torque... don't care where it comes
from.
Comparing the little industrial motors which would be perfect except for
having a poor power to weight ratio with the lighter 2-strokes you get
Rotax 503 makes 50 hp (at) 6800 rpm --> torque = 50*5252/6800= 38.6
Brigss ns600 makes 24 hp at 3600 rpm --> torque = 24*5252/3600= 35.01
So yes the torque is about the same at the engine output shaft... but that
isn't what matters, we need torque at the prop shaft
When you put both engines through a redrive to get to a usable prop rpm
Then you see the real usable torque:
Rotax 503 makes 50 hp (at) 2500 prop rpm --> torque = 50*5252/2500= 105.0
Brigss ns600 makes 24 hp (at) 2500 prop rpm --> torque = 24*5252/2500= 50.4
Wow, half the power = half the torque... imagine that.
Sure the fuel burns are better( mostly cause your not making any power!),
but half the performance and it weights much more, especially after you add
the redrive.
I don't think these engines are ever going to make a high performance
aircraft engines. Low performance perhaps... but nobody wants low
performance.
Topher
Posted: Wed Jan 04, 2006 12:30 pm Post subject: 2 and 4 Stroke |
rpm and
performance
| performance.
| Topher
Topher/Gang:
Thank you for presenting a very understandable explanation of hp and
torque. I also got a lot out of your comparison of the two
"different" engines' performance. Nice to have someone explain
something mathematical to us old guys that are not mathematically
inclined.
Take care,
PS: Got a good dose of aviating today. First flight since I flew
back from Texas a month ago. Had some airplane parts to deliver to my
buddy, Ted Cowan, over on the other side of the Tallapoosa River.
Didn't get to log quite two hours, but what I got was first class.
The old 912ULS is clocking 1,099.8 hours and still keeps on ticking.
Amazed that it would even fly with all the dirt we picked up on the
flight out to Texas and back, but it did.
eugenezimmerman(at)dejazz Guest
Posted: Wed Jan 04, 2006 2:24 pm Post subject: 2 and 4 Stroke |
On Jan 4, 2006, at 3:34 PM, John Hauck wrote:
Quote: | The old 912ULS is clocking 1,099.8 hours and still keeps on ticking.
WOW!
What is that?
More than $10,000.00 worth of hydrocarbons blown out the pipe?
jbhart(at)onlyinternet.ne Guest
Posted: Wed Jan 04, 2006 7:00 pm Post subject: 2 and 4 Stroke |
Kolbers,
Just viewed a program on the History Channel, that described a two stroke
engine that drives a container ship. I wrote down the model number
"12K98MC" and Googled it. The engine is designed by MAN B&W Diesel,
Denmark. It has 12 cylinders, with a total output of 101,645 bhp or 8,470
bhp per cylinder. Bore of 3 feet, 2.58 inches and a stroke of 8 feet 8.72
inches and develops full power at 97 rpm. Burns 0.281 pounds of oil per
horsepower hour or 14.27 tons of oil per hour at rated hp. This is quite
efficient in that if one computes fuel burn for a 40 hp engine at this rate
it comes out to be less than two gallons per hour. The engine weighs 2,157
"tonnes". This works out to 42 pounds per hp. This engine is expected to
run about 8,000 hours per year for the life of the ship.
At rated hp, the engine uses 165 pounds of cylinder oil per hour or 0.00162
pounds of lub oil per hp hour. The ratio of piston lube oil to fuel is 173
to one.
Now if we could just improve the weight to hp ratio and shrink it down to 40
hp ........
Jack B. Hart FF004
Winchester, IN
tombrandon(at)mac.com Guest
Posted: Wed Jan 04, 2006 8:29 pm Post subject: 2 and 4 Stroke |
This is what you want.
http://www.bath.ac.uk/~ccsshb/12cyl/
On Jan 4, 2006, at 9:06 PM, Jack B. Hart wrote:
<jbhart(at)onlyinternet.net>
Kolbers,
stroke
or 8,470
feet 8.72
oil per
quite
this rate
weighs 2,157
expected to
0.00162
fuel is 173
to one.
down to 40
hp ........
Jack B. Hart FF004
Winchester, IN
