		wreining(at)gmail.com Guest
				 Posted: Sun Feb 25, 2007 3:19 pm    Post subject: Is It OK to Flatten a Dimple? |
				Oops – I mistakenly dimpled a hole in one of the flanges on a tail cone frame (where the longeron attaches).  It flattened right out when I squeezed it with a rivet set.  Is this OK?  I wouldn’t think a whole row would be a good idea, but just one?
 Bill (and Jon) Reining
 40514
				 Posted: Sun Feb 25, 2007 9:35 pm    Post subject: Is It OK to Flatten a Dimple? |
				Looks like no one is answering your question. In general, as you already
 know this is a bad idea. But as you said one probably won't be an issue. You
 may want to wet rivet it with a small dab of proseal or other bonding
 material to help prevent any cracks that might have or will be forming when
 the rivet expands.
 JOhn G. 409
 Do NOt Archive
  	  | Quote: | 	 		  From: "Bill Reining" <wreining(at)gmail.com>
 Subject: Is It OK to Flatten a Dimple?
 Date: Sun, 25 Feb 2007 15:18:10 -0800
 Oops - I mistakenly dimpled a hole in one of the flanges on a tail cone
 squeezed
 it with a rivet set.  Is this OK?  I wouldn't think a whole row would be a
 40514
				 Posted: Mon Feb 26, 2007 12:48 pm    Post subject: Is It OK to Flatten a Dimple? |
				As John already mentioned, it is probably OK on one, but you don’t want to do it much.  In general, if you dimple something that doesn’t need a dimple, you are better off using a flush rivet if you can than flattening it out and using a round head.  I think Van’s would say it is OK to rivet it flattened out if it is just one hole.  To see how it weakens the part, take a scrap piece, drill a hole, then dimple it, flatten it, dimple, etc. until it breaks out.  It doesn’t take long.  If you dimple it the wrong way and then dimple it back the right way, it can break even after the second dimple, so it is definitely a LOT weaker.
 Do not archive.
 Jesse Saint
 Saint Aviation, Inc.
 www.saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Reining
  Sent: Sunday, February 25, 2007 6:18 PM
 40514  [quote]   [b]
