Vern(at)teclabsinc.com Guest
Posted: Tue Feb 27, 2007 8:39 am Post subject: Rolling and fitting of fuselage side skins |
William,
Thanks for posting the pictures and idea of using 1 ½” angle iron for rolling the fuselage side skins on your web site. I used this method the past weekend in place of the hardwood form called out in the plans. It worked great! I did leave the blue plastic in place until after the rolling process was complete (on the forward skins the plans say peal it off before rolling them.)
If anyone else is interested in this, it can be found at the following link.RV-10 Fuselage Construction - Fuselage Side Skins
Thanks again,
Vern Smith (#324 fuselage skins fitted:)
