jack.byrne(at)bigpond.com Guest
Posted: Fri Mar 02, 2007 10:46 pm Post subject: Stereo Input Jack |
I have a stereo jack to install for input to a GMA 340.
The jack has one long lug which I will attach the white wire to.
The jack has 2 shorter lugs, a bronze colour and a silver colour. I have a 3 wire cable from the GMA340 wired by the supplier. Which lug should the white/blue wire and the white/orange wire go to or dosnt it matter.
The logic to the earphone jack is white/blue to tip and white/ orange to the ring if that helps.
Chris Byrne
SYDNEY
zk-vii(at)rvproject.gen.n Guest
Posted: Fri Mar 02, 2007 11:29 pm Post subject: Stereo Input Jack |
Hi Chris,
Assuming your harness was made be Stark (which I think it was) and it is the same as mine....
DB44-340-J2:23 - Music 1 L In Audio In - White
DB44-340-J2:24 - Music 1 R In Audio In - White/Orange
DB44-340-J2:25 - Music 1 Return Audio In - White/Blue
Standard 3.5 mm music jack
Tip - Left Channel
Ring - Right Channel
Sleeve - Ground / Common
HTH,
Carl
ZK-VII - RV 7A QB - finishing? - New Zealand
http://www.rvproject.gen.nz/ [quote] --
Posted: Sat Mar 03, 2007 2:53 pm Post subject: Stereo Input Jack |
G'Day Carl
Thanks for your help Carl. I am still a bit confused though. I should have been a bit clearer, I am trying to wire the female socket. This sort of stuff is not my forte. Stein did mine and I did clarify it once with them but have lost the info, I have had a bit going on lately. I might just have to pester them again.
Mine should have flown in Jan but I have had a bit of a hiatus.
Chris
