		d(at)cfisher.com Guest
				 Posted: Sat Mar 03, 2007 5:29 am    Post subject: Droop tips |
				I am looking for anyone that has changed from Droop  tips to the more current  hoerner style tip on a IV.
  What was gained  or lost  if anything ?
  I have mixed thoughts on Droop tips.    Personally would a winglet tip  ( invested tip) now give better STOL  ?
  Open for comments.
  Dave
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Float Flyr
				 Posted: Sat Mar 03, 2007 9:28 am    Post subject: Droop tips |
				At the speed my 'Fox flies I  doubt the droop tips make any difference to flight dynamics.  I don't think  winglets will make any difference either.  They do look distinctive  though.
 Noel [quote]
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		Michel
				 Posted: Sat Mar 03, 2007 12:35 pm    Post subject: Droop tips |
				Here is a place I think the droop winglets may help: It will protect
 the flaperons in case of a ground loop where the wing tip touches the
 ground. I never tried it so I have no idea if I am right, just a hunch.
 Michel
		Glenn Horne
				 Posted: Sun Mar 04, 2007 5:12 am    Post subject: Droop tips |
				You are right. Been there done that.
 Glenn
		mclayton(at)rochester.rr. Guest
				 Posted: Sun Mar 04, 2007 5:57 am    Post subject: Droop tips |
				Dave,
 I have done some digging on the effects of various wingtip designs on performance.  Here is what I remember....
 Winglets effectively increase the span of the wing by keeping the tip vortices outboard of the wing.  Hoerner tips and tips that droop or the reverse (stick up) also have the effect of pushing the vortices further outboard on the wing.  However, in order of effectiveness (as I recall) they are: 1. Hoerner tips, and 2. Droop tips.  However, published experimental data from wind tunnel tests, as well as mathematical modeling indicate that the differences between these are relatively small.
 I am rebuilding a KF2, and spent time looking into this issue to see if a change would be worthwhile, and concluded that the differences were not large enough to consider.  However, there is another technology that will help improve the stall performance of the aircraft, and that is vortex generators.  These are small devices that are usually attached to the wing, near the leading edge, and they help to prevent boundary layer separation at steep angles of attack, and thus improve the lift coefficient and reduce the stall speed.  They are very inexpensive, and John McBean sells a kit that can be used to install these on a Kitfox.
 There is lots of good information on the web, you just have to go digging a bit.  If I can resurrect the URL's for some of the web sites I looked at, I'll post them.
 On Mar 3, 2007, at 8:29 AM, D. Fisher wrote:
  	  | Quote: | 	 		  I am looking for anyone that has changed from Droop tips to the more current  hoerner style tip on a IV.
 Open for comments.
 Dave
  Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
				 Posted: Sun Mar 04, 2007 6:45 am    Post subject: Re: Droop tips |
				Hi Dave
 First off, you've got a great web-site!
 I don't have personal experience with the droop tips on the IV, but did have them on a Cessna 150 that I resurrected and flew for a year.  The "batman tips" (I think they were the Madras STC) became a magnet for talking such things with other droop-tip owners.  In short, they maybe-possibly-perhaps lowered the stall speed by a smidge (2mph?) in the Cessnas.  It sure wasn't the 5+ mph was advertised.  The Piper owners reported more pronounced effects, especially when in ground effect, which makes a lot of sense.  When the stall developed in the 150, the droop tips did seem to make things a bit more squirrely and I liked the stall less than in similar planes with hoerners or the old round tips. For how low and slow you seem to like flying around the mud-patch, that may be something to consider.
 The hard aerodynamics and common-sense perspectives agree with what Mike Clayton mentioned.  The big-3 in determining stall speed are your weight, wing area, and CL (coefficient of lift).  Your plane's weight is pretty well established and while the tips sorta kinda make a small change in effective area, it is relatively small.  However, the VGs change the CL for the entire wing.  The change can be enough that the size of the horizontal tail can become an issue, so if you go this route put a set on the bottom of the horizontal stab, as well.
 Aero Eng, A&P
 Vixen in work
  _________________ Remember that internet advice may only be worth what you pay. |
				 Posted: Sun Mar 04, 2007 4:21 pm    Post subject: Droop tips |
 Yup the site is a great way to share info with others.
 I agree with all you say...  and  VG's  I have afew sets from differnent
 companies here  and I might try them in the spring......
 Personally I think that  the fundamentals of the hoerner style give me the
 more interest. Droops tips I have mixed feelings on.
 A slight winglet like these are interesting
 http://www.crosswindsstol.com/prod01.htm
 Or these more hoerner style .........
 http://www.stewartshangar21.aero/wingtip.htm
 Food for thought for anyone who thinks they can tweak a bit more outta
 Kitfox.
 I think a the big hole in the round cowl is way to big for the needs of the
 582 and possibly a bit of drag there as well. ?
 Dave
		rexjan(at)bigpond.com Guest
				 Posted: Sun Mar 04, 2007 7:09 pm    Post subject: Droop Tips |
 Michel
 I agree but  although I have looped nothing touched the ground. In  fact  I
 just held the wing up with the stick. I also used rudder but I thought that
 was wasted effort. I thing holding the wing up was worthwhile though. I do
 feel the droop tip may be helpfull too.
                   Rex..
		trevorkebb(at)earthlink.n Guest
				 Posted: Mon Mar 05, 2007 6:01 am    Post subject: Droop Tips |
				Nah, ground looped my Model IV with Hoerner tips once and scraped the tip
 only. No damage to the flaperon.
 This was with standard, not Speedster, length wings.
 Droop tips were a fad that came and quickly went.
 RB
