bakerocb
Posted: Thu Mar 01, 2007 8:12 pm Post subject: GPS Antenna? |
3/1/2006
Hello Fellow Listers, I am trying to identify an object on the bottom of the
fuselage of a Beech Sierra airplane. It is black plastic about the size of a
cigar box. Embossed on the bottom of the box is an arrow pointing forward
and the letters 3M.
It was described at one time as a GPS antenna, but that does not make much
sense to me. Why would a GPS antenna be on the bottom of the fuselage? I
also am not able to locate any antenna created by 3M.
Any good ideas? Many thanks.
OC -- The best investment we can make is the effort to gather and understand
knowledge.
Float Flyr
Posted: Thu Mar 01, 2007 8:57 pm Post subject: GPS Antenna? |
How about RadAlt?
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Thu Mar 01, 2007 9:01 pm Post subject: GPS Antenna? |
The size of a cigar box... With an arrow. That puts a different wheel on
the cart.
That would be a loop antenna for an ADF. The long wire antenna, porobably
on the top, would be the sense antenna also for the ADF.
Noel
[quote] --
Kitfox III-A
douglas.dodson(at)pobox.c Guest
Posted: Fri Mar 02, 2007 6:29 am Post subject: GPS Antenna? |
That is likely a stormscope antenna.
Douglas L. Dodson, Jr.
Glasair II-S FT
Flight Test Engineer, CFI-A,G
kensmith(at)springnet1.co Guest
Posted: Fri Mar 02, 2007 4:42 pm Post subject: GPS Antenna? |
Stormscope Antenna - 3M corporation
Noel Loveys wrote: [quote] [quote]--> Avionics-List message posted by: "Noel Loveys" <noelloveys(at)yahoo.ca> (noelloveys(at)yahoo.ca)
How about RadAlt?
Noel
[quote]--
Float Flyr
Posted: Fri Mar 02, 2007 6:49 pm Post subject: GPS Antenna? |
Storm scope antennas are similar to radar dishes and are mounted in the nose
of the plane. ( assuming it isn't single engine prop)
Noel
[quote] --
Kitfox III-A
Float Flyr
Posted: Fri Mar 02, 2007 7:00 pm Post subject: GPS Antenna? |
Just did a Google check on 3M Stormscope and you are absolutely right. That
makes me wrong... Twice! The antenna does look a lot like the ADF loop.
Noel
[quote] --
Kitfox III-A
Bruce(at)glasair.org Guest
Posted: Fri Mar 02, 2007 7:05 pm Post subject: GPS Antenna? |
Storm scopes work by receiving the radio energy produced by the lightning.
Their antennas emit no energy and thus can be mounted at any RFI quite
location on the airframe.
Bruce
www.glasair.org
Float Flyr
Posted: Fri Mar 02, 2007 7:57 pm Post subject: GPS Antenna? |
Thanks Bruce. I had it crossed with WX radar.
Noel
[quote] --
Kitfox III-A
j.rippengal(at)cytanet.co Guest
Posted: Fri Mar 02, 2007 10:32 pm Post subject: GPS Antenna? |
I think that needs just a little qualification. Apart from being in a quiet
RFI location it must also be unscreened from a low frequency RF point of
view.
John
Bruce
www.glasair.org
bakerocb
Posted: Sat Mar 03, 2007 4:38 am Post subject: GPS Antenna? |
3/3/2007
Thanks to all that responded. It is indeed a Stormscope antenna made by 3M
back in the days when they were replacing Ryan as the manufacturer of that
equipment.
knowledge.
Posted: Sat Mar 03, 2007 8:05 am Post subject: GPS Antenna? |
Could be, Both are about the same physical size.
kensmith(at)springnet1.com (kensmith(at)springnet1.com) wrote: [quote] Stormscope Antenna - 3M corporation
How about RadAlt?
Noel
[quote]--
mlas(at)cox.net Guest
Posted: Sat Mar 03, 2007 12:59 pm Post subject: GPS Antenna? |
I would guess that it is a storm scope antenna (lighting detector).
Mike Larkin
