jlisler(at)alltel.net Guest
Posted: Mon Mar 12, 2007 7:20 pm Post subject: RV-4 First flight |
After 12 years of on and off construction, RV-4 N455J is officially a flyable airplane. After receiving the airworthiness certificate this morning, I performed a full power ground run on the engine just to make sure it would develop adequate power and to see that there were no issues with the fuel delivery system. A quick adjustment of the low speed idle and another 15 gallons of 100LL (for a total of 20 gallons, 10 in each side) I was ready to go. At 1715 this afternoon I pulled onto runway 18 at 17J (Donalsonville, GA) and applied full power. The take-off roll was brisk but the airplane tracked straight. It broke ground after a short ground run and climbed away at 1500 FPM. At 2000 feet I orbited the airport feeling out the controls and watching the oil pressure. The left wing is slightly heavy and I hope to correct that with a squeeze of the left aileron. Also, right rudder was required to keep the ball centered. I may try to correct the rudder first before squeezing the aileron, just to see how it affects the heavy wing. Stalls were non events at less than 50 knots indicated. Oil pressure was to high and I had to throttle back to keep it in limits. The oil pressure relief is adjustable so that should be a simple fix. The most annoying thing was a canopy buzz on the trailing end at high speed. How do you stop that?
I would like to report that the first landing was a greaser but that would not be so. After the third bounce I remembered to plant the main gear on by raising the tail. Life was good after that. The 4 sure handles better than my Cessna C140A on the ground and in the air. I think I can get use to this airplane.
Thanks to Pierre Smith, Louisville, GA., for my transition training. I was as prepared for this flight as any I have ever made.
Jerry Isler
Donalsonville, GA
RV-4 N455J - Flying
aeroncadoc(at)comcast.net Guest
Posted: Mon Mar 12, 2007 7:46 pm Post subject: RV-4 First flight |
Congrats on your milestone. According to an article in the latest issue
of General Aviation News, the 5000th flying RV launched on Feb 14th in
San Antonio. Another first flight was recorded that day as well. So, you
must be number 5020 or something. Congrats again.
Henry H.
part time flyer of N72224 RV-6 KAWO
Jerry Isler wrote:
| Quote: | After 12 years of on and off construction, RV-4 N455J is officially a
Jerry Isler
Donalsonville, GA
RV-4 N455J - Flying
billshook2000(at)yahoo.co Guest
Posted: Mon Mar 12, 2007 7:52 pm Post subject: RV-4 First flight |
You don't see as many -4's leaving the ground for the first time anymore. Congrats on
your new bird! May she serve you faithfully and deliver you safely to any destination
you choose.
Bill
-4 wings
Sucker-punch spam with award-winning protection.
Try the free Yahoo! Mail Beta.
tlump51(at)sbcglobal.net Guest
Posted: Mon Mar 12, 2007 10:55 pm Post subject: RV-4 First flight |
Jerry,
Congratulations on your successful flight. Regarding your canopy buzz, I had the same problem. I solved it by installing rubber edging along the rear of the canopy skirt. I used a more rounded shape that I found in the McMasterCarr catalog. This not only stopped the buzzing, but also made the cockpit less drafty and gave the canopy a more solid feel when closed.
Ted
deruiteraircraftservices( Guest
Posted: Tue Mar 13, 2007 1:10 am Post subject: RV-4 First flight |
Congrats Jerry.
12 years is not bad for an old style kit. I have only build the tail of mine since '99, but have completed a -7 and finishing a -10 at present. Soon I'll purchase the rest of -4 and get started again. I'm sure it'll be a shock to the system after the pre-punch stuff!
Happy Landings!
khorton01(at)rogers.com Guest
Posted: Tue Mar 13, 2007 2:53 am Post subject: RV-4 First flight |
Yes, correct the rudder first. Then have a read of the info that Van
has published on heavy wings:
http://www.vansaircraft.com/pdf/Wing_Heavy.pdf
Then, if all else fails, squeeze the aileron of the light wing - i.e.
the right wing.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
rhdudley1(at)bellsouth.ne Guest
Posted: Tue Mar 13, 2007 5:45 am Post subject: RV-4 First flight |
Congratulations, Jerry. Enjoy your new pride and joy!!!!!
Richard Dudley
RV-6A flying
Jerry Isler wrote:
[quote] After 12 years of on and off construction, RV-4 N455J is officially a flyable airplane. After receiving the airworthiness certificate this morning, I performed a full power ground run on the engine just to make sure it would develop adequate power and to see that there were no issues with the fuel delivery system. A quick adjustment of the low speed idle and another 15 gallons of 100LL (for a total of 20 gallons, 10 in each side) I was ready to go. At 1715 this afternoon I pulled onto runway 18 at 17J (Donalsonville, GA) and applied full power. The take-off roll was brisk but the airplane tracked straight. It broke ground after a short ground run and climbed away at 1500 FPM. At 2000 feet I orbited the airport feeling out the controls and watching the oil pressure. The left wing is slightly heavy and I hope to correct that with a squeeze of the left aileron. Also, right rudder was required to keep the ball centered. I may try to correct the rudder first before squeezing the aileron, just to see how it affects the heavy wing. Stalls were non events at less than 50 knots indicated. Oil pressure was to high and I had to throttle back to keep it in limits. The oil pressure relief is adjustable so that should be a simple fix. The most annoying thing was a canopy buzz on the trailing end at high speed. How do you stop that?
Jerry Isler
Donalsonville, GA
RV-4 N455J - Flying
crowbotham(at)hotmail.com Guest
Posted: Tue Mar 20, 2007 2:32 pm Post subject: RV-4 First flight |
Jerry,
CONGRATULATIONS and WELL DONE !!
Chuck & Dave Rowbotham
RV-8A
| Quote: | From: "Jerry Isler" <jlisler(at)alltel.net>
Reply-To: rv-list(at)matronics.com
To: <rv-list(at)matronics.com>
Subject: RV-4 First flight
Date: Mon, 12 Mar 2007 23:12:48 -0400
flyable airplane.
Jerry Isler
Donalsonville, GA
RV-4 N455J - Flying
i'm making a difference. Make every IM count for the cause of your choice.
Join Now.
