JRatcli256(at)aol.com Guest
Posted: Wed Mar 14, 2007 6:26 pm Post subject: Fuel Filter / Water Seperator |
Hi gang,
Considering installing a Racor Fuel Filter/Water Separator in place of regular fuel filter.
Normal Mister Funnel and preflight fuel samples should take care of fuel source and condensation problems, but with ethanol fuels in our future would this be enough?
Water and alcohol mix quite readily. Would a water filter tend to separate the alcohol along with the water from the rest of the fuel? Could a water/alcohol emulsified mixture get by normal fuel checks?
Not worth worrying about?
Would like to hear general comments and as well as from those who may be using this type of filter.
John Ratcliffe
AOL now offers free email to everyone. Find out more about what's free from AOL at AOL.com.
dhkey(at)msn.com Guest
by0ung(at)brigham.net Guest
Posted: Thu Mar 15, 2007 10:37 am Post subject: Fuel Filter / Water Seperator |
Hi gang,
this be enough?
John Ratcliffe
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
If we get a small percent of alcohol in our gas.... then we will have no
concern for water in the gas..... unless we get more water than alcohol
in our systems.... a water alcohol mix of 50 - 50 will mix and burn
without problems in our fuel.... the water wont separate out until the
water is greater than 50 % compared to the alcohol in the fuel. to check
for alcohol in the gas is quite easy... fill a test tube 1/2 full with
water, then draw a line,,, then fill it the rest of the way with gas,
shake it up and let it settle. The difference between the line and the
water / gas line is the amount of alcohol. Now to test for the purity
of the alcohol will take a bit more time but is done in near the same
way.... fill the test tube to the first line with gas.... slowly put in
drops of water and shake between drops. When you first start noticing water
in the bottom of the test tube, you will know how much water the alcohol in
the gas will absorb before it starts to settle out.
For example... if you have a test tube marked from 0 to 150 CC... fill it
to 100 with gas... if it is 5 percent alcohol in the gas... you should
be able to fill it to the 105 before the water starts to settle in the
bottom.... if you only get it to 102.... then the alcohol in the gas
already had water mixed into it,, or it was only 2 percent alcohol in the
gas to start with.
Any way until you get enough water into the gas to cause it to settle out,,,
it will burn ok.
Boyd young
a58r(at)verizon.net Guest
Posted: Thu Mar 15, 2007 5:10 pm Post subject: Fuel Filter / Water Seperator |
Doubt if any filter that we could afford/lift would separate the fully miscible mixture of alcohol and water into its parts. Distillation?
regards,
Bob N. FireFly 070 Old Kolb
Posted: Thu Mar 15, 2007 6:06 pm Post subject: Fuel Filter / Water Seperator |
Boyd,
Was thinking, by using the water separator to filter the water/alcohol mixture, maybe it would remove the alcohol as well.
Thanks for the info on testing the fuel. Sounds easy to do in the field when your not sure of the source.
John Ratcliffe
biglar
Posted: Thu Mar 15, 2007 8:10 pm Post subject: Fuel Filter / Water Seperator |
Haven't used it on the plane, but I've used a Racor fuel/water separator on my outboard boat for several years, and it does a dandy job. Lar.
On 3/15/07, boyd <by0ung(at)brigham.net (by0ung(at)brigham.net)> wrote: | Quote: | --> Kolb-List message posted by: "boyd" <by0ung(at)brigham.net (by0ung(at)brigham.net)>
Hi gang,
Normal Mister Funnel and preflight fuel samplesshould take care of fuel
this be enough?
the alcohol along with the water from the rest of the fuel?Could a
John Ratcliffe |
_________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
