Arty Trost
Joined: 25 May 2006 Posts: 206 Location: Sandy, Oregon
Posted: Thu Mar 15, 2007 8:51 am Post subject: Rebuilding Fuel Pump |
How often do you folks like to rebuild/replace your
fuel pump? (I've got a 503 DCDI.)
This was a topic at our last club meeting, and Roger
Hankins and I are also discussing it - so I thought
I'd throw it out to this list.
Arty Trost
Sandy, Oregon
www.LessonsFromTheEdge.com
"Life's a daring adventure or nothing"
Helen Keller
"I refuse to tip toe through life just to arrive safely at death."
Posted: Thu Mar 15, 2007 9:29 am Post subject: Rebuilding Fuel Pump |
| fuel pump?
| Arty Trost
Arty:
I have an old Kubota tractor with a Mikuni impulse fuel pump just like
the one you fly with. It is about 30 years old and has about 3000
hours on it. It is still pumping, every time I crank the little
Kubota.
Of course, the Kubota lives in a different world than the Mikuni on
your Rotax. It also pumps diesel and not gasoline. If the Kubota
quits, no sweat.
I can not remember how often I changed out or overhauled Mikuni fuel
pumps back in the day when I was flying two strokes. Every couple
years or so. They are extremely reliable. Three parts: Top half,
diaphram, and bottom half. About the only thing to wear out is the
diaphram which also acts as the gasket.
How much does the overhaul kit cost?
Make sure it is genuine Mikuni. LEAF was selling a kit many years ago
that was not Mikuni. I had a forced landing the first flight after I
overhauled my fuel pump at the Flight Farm, Monterey, NY, 1989. Put
the old diaphram back in, flew to OSH, and home to Alabama. BTW:
LEAF grudeonly refunded my money for my fuel pump kit.
Don't think I answered your question.
_________________ John Hauck
Titus, Alabama |
d-m-hague(at)comcast.net Guest
Posted: Thu Mar 15, 2007 9:43 am Post subject: Rebuilding Fuel Pump |
At 01:29 PM 3/15/2007, John Hauck wrote:
overhauled my fuel pump...
The pumps are so cheap doesn't it just make more sense to replace the
entire pump than to rebuild it?
OTOH... the previous owner of my US made a forced landing (fortunately on
the airport, but he still broke a gear leg) when the brand new fuel pump
he'd just installed failed. Apparently it had been sitting on the shelf
for some time, and the diaphragm had dried out.
He actually did pretty good considering it was about his third solo flight
in any kind of airplane (he's got a lot of PPC and gyro time, and prefers
the gyro, which is why he sold the US to me).
-Dana
I started out with nothing. I still have most of it left.
boyter(at)mcsi.net Guest
Posted: Thu Mar 15, 2007 11:56 am Post subject: Rebuilding Fuel Pump |
frank-margie(at)worldnet. Guest
Posted: Fri Mar 16, 2007 3:28 pm Post subject: Rebuilding Fuel Pump |
REF:
> Arty
I rebuilt mine ever 100 hrs. Had one last year fail at 110 hrs. Glad I had
a electric back-up.
Back in the snow mobile days some of them would last for ever?
Wayne
I'd like to see a lot of input on this question, an impromptu poll of experiences/observations could provide some good guidelines, if enuf people added to it.
I rebuild at 2 years or 100 hrs max. And John Hauck is right on about using genuine Mikuni parts. The rebuild kits are cheap, and easy to install.
I've seen a lot of pulse pump failures. I don't know why they seem to fail a lot more often on ultralights, but that's my impression too. I don't completely trust them, even when rebuilt often, which is why I just added a Facet pump, in series, per Msr's Hauck/Pike and others on this list. (The grass strip I fly off of is not ultralight friendly, lots of big trees all around, lots of pucker factor until one gets a little altitude.) I mount my pump with tie-wraps and rubber hose standoffs, on the airframe (vs on the engine), to try and reduce the vibration level at the pump. Also mount with the pulse line input on the bottom, tilted down maybe 30 degrees, and I leave a "belly" in the pulse line below the pump. Hopefully the tilt and belly will let any residual fuel/oil run away from the diaphragm----I'm not convinced the little weep hole in the pump/pump fitting is enuf to do the job on a 2 cycle. Don't know how much my mounting methods help, but I personally have never had a pump failure, and I don't much care to if I can help it. (A friend went down on take off from SunN'Fun a few years back, and was real lucky to get it down in the paved parking area off the end of the strip, without getting hurt.)
I believe a large % of powerplant failures in GA are fuel system related, and I'd be willing to bet it's an even higher % in the ultralight world.
Frank Clyma
Orange Park, FL
