Deems Davis
Posted: Sat Mar 24, 2007 5:42 am Post subject: Defrost fans - THANKS |
Larry, GREAT link! I just ordered a pair of low noise 80mm fans w/ speed
controller, black mesh filter/grill and screws, EASY!
THANKS to all who responded and provided very helpful information.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
Larry Rosen wrote:
*You may want to consider a larger fan with a speed control to reduce
the RPM. This would help reduce the noise from the fan.
Tim mentioned stand offs to help keep the fan from warping. You may
want to consider a gasket or bushing like stand offs. This also would
reduce the noise from fan vibration.
Look at <www.Directron.com> they have a huge selection of fans along
with some resources on Quiet fans and Quiet computers. You might as
well put in a fan that is quiet.
They have a black steel mesh filter that could be used in lieu of the
DIY approach <http://www.directron.com/smf80.html>
LarryRosen
Posted: Sat Mar 24, 2007 5:51 am Post subject: Defrost fans - THANKS |
Looking forward to the photos on your site.
Larry
Deems Davis wrote:
speed controller, black mesh filter/grill and screws, EASY!
Deems Davis # 406
> would reduce the noise from fan vibration.
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
