d.michaud(at)web.de Guest
Posted: Fri Feb 03, 2006 2:13 pm Post subject: Brakes |
Hi All!
I have the Glasair N31BC,S/N 3177,Stationed Europe.
I have a problem with spongy brakes,I have pedals with intergrated
brake extention,I have bled the brake system so noair is in it,However
it is still
spongy,I have cleveland 10-19D master cylinders installed. is there any
thing better perhaps? Any one have an idea how to make the brakes more
solid. any help would be appricated
Thanx Dave
| - The Matronics Glasair-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Glasair-List |
Craymondw(at)aol.com Guest
Posted: Fri Feb 03, 2006 5:01 pm Post subject: Brakes |
Pump fluid into the calipers. I have the same problem and the air usually
works its way out.
Bruce(at)glasair.org Guest
Posted: Fri Feb 03, 2006 6:02 pm Post subject: Brakes |
Normally the best way to bleed brakes is from the bottom up. With a pressure
pot at the wheels.
Bruce
www.glasair.org
robin02(at)mindspring.com Guest
Posted: Sat Feb 04, 2006 4:57 pm Post subject: Brakes |
it is still
Thanx Dave
Try pulling the peddle back all the way so the shaft is at max extension.
Also, if you suspect the air is in the caliper, pump some fluid out before
attaching the bleed tube. A ten CC syringe is very helpful in removing
fluid from the reservoir as the bleeding done. RObin 286YM
