Posted: Sun Mar 18, 2007 3:04 pm Post subject: Outriggers - fitting |
All,
After searching thru 245 postings on outriggers, I find no discussion
of a problem I'm having as I trial-fit my outriggers.
Namely, that...although the build manual describes simply sliding the
nylon tubes into the SS wheel forks...I'm finding that the wheel forks
are simply too small to accept the nylon tubes. My attempts to reduce
the diameter of the tubes by rotating them against my stationary belt
sander only succeeds tin roughing up the surface and...due to friction
heat...the nylon seems to expand rather than diminish in size.
My next notion is to chuck the nylon into a wood lathe and turn it down
til I have a snug and smooth fit.
Is my problem unique?...and if not, can anyone share their solution?
Fred
davedeford(at)comcast.net Guest
Posted: Sun Mar 18, 2007 9:27 pm Post subject: Outriggers - fitting |
| Quote: | Namely, that...although the build manual describes simply sliding the
wheel forks
friction
turn it down
Fred
Fred,
Our outrigger rods were too large to fit into the sockets on both ends, so I
had a friend with a metal lathe turn the ends down for a snug fit. I don't
think abrasives or files are practical solutions. The simplest (though
maybe not quickest) solution is probably to get properly-sized rods from
Europa. Other factory-supplied rods we later tested in our outrigger
hardware fit just fine, so the problem was clearly in the original rods that
we received with out kit (8 years ago).
Dave DeFord
N135TD
william(at)wrmills.plus.c Guest
Posted: Sun Mar 18, 2007 10:25 pm Post subject: Outriggers - fitting |
Fred,
The latest nylon legs supplied by Europa have the ends already turned down
to fit the sockets at both ends. I have just replaced mine at 1,100 hrs,
because the old ones have developed a permanent set to bend rearwards which
makes ground looping easier to happen in a cross wind.
William
josok-e(at)ukolo.fi Guest
Posted: Sun Mar 18, 2007 11:39 pm Post subject: Outriggers - fitting |
Mine were fitted using a file and sanding paper. Took a couple of hours, less time then going after power tools and try that to work properly. The economics worked!
Kind Regards,
Jos Okhuijsen
Visit - www.EuropaOwners.org
