Progressive loss of radio quality
aaaron(at)tvp.com.au
PostPosted: Tue Mar 20, 2007 2:23 am    Post subject: Progressive loss of radio quality Reply with quote
My friend has a cozy (fibreglas construction) with an icom a200 (i think) tranceiver. When he transmits the initial quality is good but if the transmission continues for many seconds it degrades to the point of being unreadable. Is this likely to be an antenna grounding issue, a factor related to it being a glass plane or a fault with the radio? Any thoughts appreciated.
allan
nuckollsr(at)cox.net
PostPosted: Tue Mar 20, 2007 5:21 am    Post subject: Progressive loss of radio quality Reply with quote
appreciated.
if it has anything to do with local RF getting back
into the radio, a dummy load check will show this up.
Put this device on the transceiver's feedline.
http://www.aeroelectric.com/Pictures/Tools/DummyLoad.jpg
Listen on adjacent airplane or handheld while transmitting
on subject radio. If the problem goes away when the antenna
is out of the loop, then the investigation will focus
outside the radio.
Is this a new condition or has it existed since day-one?
N6030X(at)DaveMorris.com
PostPosted: Tue Mar 20, 2007 5:36 am    Post subject: Progressive loss of radio quality Reply with quote
It could be that the SWR on the antenna is so high that the
transmitter is protecting itself by reducing power. I don't know
about the A200 but a lot of modern transmitters have that
feature. Make sure all connectors are good and that the coax isn't
shorted somewhere.
Dave Morris
allan
