josok-e(at)ukolo.fi Guest
Posted: Sun Mar 18, 2007 10:29 am Post subject: 914: fuel over airbox pressure |
Hi team,
Does the UMA transducer connect between the airbox and the carburettor feed line or between the airbox and the fuel feed on the pressure regulator? In other words: before or after the pressure regulator?
In the rotax doc an after pressure regulator setup is shown as a desired, not supplied option, however i assume that it is more interesting to see a warning about fuel pressure drop before the regulator runs out of pressure to regulate
Kind Regards,
Jos Okhuijsen
Visit - www.EuropaOwners.org
europa(at)pstewart.f2s.co Guest
Posted: Sun Mar 18, 2007 10:48 am Post subject: 914: fuel over airbox pressure |
Jos
I've taken mine from pre regulator - not flying yet though.
Paul
G-GIDY
On 18 Mar 2007, at 18:25, josok wrote:
Hi team,
pressure regulator?
Kind Regards,
Jos Okhuijsen
jodel(at)nildram.co.uk Guest
Posted: Sun Mar 18, 2007 11:13 am Post subject: 914: fuel over airbox pressure |
Jos,
The only measure of fuel pressure on the 914 that Rotax mentions is that the
px to the carbs should be 2-5psi over airbox px. That sort of dictates that
you should measure the airbox px and the carb inlet px (ie between the
regulator and the carb).
I have seen somewhere in the Rotax manuals a picture of a special banjo bolt
and hose end to pick off the regulator output px (but I can't remember
where!). I also have a very vague memory that this should only be taken from
one particular side of the regulator?????
Simon
Posted: Sun Mar 18, 2007 11:16 am Post subject: 914: fuel over airbox pressure |
Just to add, see page 69 of the current installation manual on the Rotax
website.
Simon
Posted: Sun Mar 18, 2007 11:26 am Post subject: 914: fuel over airbox pressure |
Simon Smith a écrit :
| Quote: | That sort of dictates that
regulator and the carb)....
Hi all,
The pressure on the upper side of the regulator (IN and OUT connections)
is the fuel-to-carb pressure.
The pressure on the lower side of the regulator is the airbox pressure.
See installation manual or
http://contrails.free.fr/engine_regul_en.php
Hope this helps,
Gilles
Posted: Sun Mar 18, 2007 1:21 pm Post subject: 914: fuel over airbox pressure |
Gilles & all
I'm not familiar with 914 but I do remember that the return flow from
the regulator must be unrestricted otherwise the back pressure will
cause rich mixture? Because of the high flow rate required with all
pumps running the return pipe needs to be at least -6 size.
Hope I'm not confusing the issue
Graham
Gilles Thesee wrote:
<Gilles.Thesee(at)ac-grenoble.fr>
Hi all,
Hope this helps,
Gilles
Graham Singleton
Tel: +441629820187
Mob: +447739582005
Posted: Sun Mar 18, 2007 1:36 pm Post subject: 914: fuel over airbox pressure |
Graham Singleton a écrit :
| Quote: | I'm not familiar with 914 but I do remember that the return flow from
Graham,
You're right.
I recently conducted some tests to verify this point. I pressurized the
regulator to the max 1,3 bar absolute, while running the pump. All the
flow was by-passed by the regulator, with no problem to maintain the
specified ambient + 0.25 bar.
While I was perched on a ladder, doing the pressurizing with a U-tube,
my buddy sitting on the wing forgot to switch the different pumps, so
some additional tests are necessary.
Best regards,
Gilles
rehn(at)rockisland.com Guest
Posted: Sun Mar 18, 2007 3:47 pm Post subject: 914: fuel over airbox pressure |
UMA gauges makes a gauge specifically for measuring the difference between
the fuel pressure and air box pressure. The difference in pressure ( fuel
pressure above air pressure) must be between 2.18 and 5.08 PSI. This gauge
measures the difference which is much easier than using two gauges and doing
the math. The fuel pressure is measured at the starboard outlet of the fuel
pressure regulator. A banjo bolt fitting is connected at that point to form
a T. The air pressure is connected in the line that goes to the airbox
pressure sender via another T. Both of these lines are connected to the UMA
sender which in turn electrically sends the info to the gauge on your panel.
The gauge has range markings on it for the 914. I have had mine for two +
years and it works great and was easy to install. Check out spruce for more
details http://aircraftspruce.com/catalog/inpages/umadiff1.php
Jerry
Posted: Sun Mar 18, 2007 7:08 pm Post subject: 914: fuel over airbox pressure |
Hello Jos
Sorry I did understand exact wording of your question, but will describe
what you need to know and do.
The 914 uses a turbocharger to squeeze air molecules together at a greater
than ambient pressure. Unlike a normal aspirated engine, if you were to
vent the float bowl to ambient pressure on a turbo charged engine and
began to boost above ambient pressure, air would in fact flow the wrong
way through the carb jets and starve the motor for fuel.
Thus on a 914 the float bowl is vented instead of to ambient pressure, to
airbox pressure. When not in boost airbox will be close to ambient, when
boosting it will go above ambient pressure.
OK so now we have at least bowl pressure following turbo output.
Now you need greater fuel pressure than float bowl pressure (which is the
same as airbox pressure) to be able to fill float bowl with fuel. This is
the job of the fuel pressure regulator. You want between approx 2 and 5
PSI fuel pressure (absolute) over airbox pressure (absolute).
In absolute terms, you need your fuel pumps to work harder in thinner air
than in thicker air. It is very possible that filters and pumps can
provide at 2K, but not at 8K. If pressure can not be kept up, you are in
danger of having your motor playing silent night. Turning on second pump
can help, going down in altitude can help, and dropping manifold pressure,
which will drop airbox pressure will help. Remember a stuck wastegate can
overboost a 914. The fuel pressure regulator can not keep up if you go too
much over redline boost pressure. Thus you can run out of fuel on take off
in a very bad position. If you are not between 2 and 5 when rolling, abort
take off. If you get airborne, and have engine quit, see if reducing
manifold pressure helps get back differential of at least 2 PSI, if it
does,you can probably fly pretty safe at a reduced power till you can
land.
An awful lot of words. Simple way to follow is to have a differential
gauge and keep it between 2 and 5.
I hope the following will answer your question:
You need to plumb 2 lines to your differential sender, 1) fuel pressure
and 2) airbox pressure.
1) Fuel pressure. You need to connect to one of your carburetor fuel
supply lines that run between the fuel pressure regulator and the
carburetors. You can purchase a double length banjo bolt from Rotax and
extra crush washer and stack another banjo (run to your sender) on the
output of the fuel pressure regulator. Don't reuse old crush washers.
(that said when you you are stuck somewhere you can heat real hot with
blow torch or cigarette lighter and quench crush washers in oil to soften
them, then do figure 8s on a piece of wet dry sandpaper on a flat surface
to make them flat, get to 600 grit should do it). I am using Earls -3
teflon hose and will fill lines with 100LL. Don't want 20 years old mogas
in there after a while
2) Now for the other side of the sender. Airbox pressure. You can do this
2 ways. You can purchase an extra nipple for a spare plug in your airbox
and run that to sender. If you don't have an extra hole, you can T to the
fuel pressure regulator line or the actual airbox pressure side of the
enrichment solenoid.
Or you could do as I am going to do. There are 2 pressures in the airbox.
Actual pressure (Port most side of airbox) and Impact air pressure ( Think
starboard most side of airbox). Impact air pressure is a bit more than
Actual airbox pressure. It is used to increase the float bowl pressure a
bit more to in fact allow the engine to run a bit richer. If TCU
determines that boost is OK to apply, above 108% power the wastegate will
close, and the enrichment solenoid will in fact plumb impact air to the
carburetor float bowls, instead of plumbing actual airbox air. This will
give a richer mixture that will greatly aid in cooling engine that is
huffing and puffing quite a bit harder than if run at 100% power.
I will use a injected molded 316 Stainless steel "T" from www.mcmaster.com
to take instead of actual airbox air, the pressure going to the
floatbowls. This pressure will be actual airbox air up to ~108% throttle,
and impact air if the solenoid is in fact working. I don't think there
will be a tremendous difference between the 2, but I am hoping I can see a
flicker of the differential needle when the solenoid switches from actual
to impact. This "T" needs to go somewhere between output of the enrichment
solenoid and the carb float bowls. Be very careful not to break the nipple
on the enrichment solenoid, it is plastic. If there was a leak going to
carb, this T should indicate higher than normal differential pressure that
you probably would not see if you were plumbed to the airbox. Running lean
in during war Emergency Power (115%)is not very conducive for long engine
life. Just a note, I don't like the white plastic Ts Rotax uses and
changing to the stainless ones as described, and since I need to re wrap
the hoses, will not put back the cheap stuff Rotax provides but Teflon
spiral wrap also obtainable from www.mcmaster.com
Try burning a piece of the Rotax supplied spiral wrap, then try teflon.
Bob as far as your question, you want as little restriction on return flow
flow of the fuel pressure regulator. Do not consider a restrictor. If
restrict a bit too much you could easily exceed the max 5PSI especial in
thick air. Parallel pump design best check that when both pumps are
running in thick air you do not exceed 5PSI. Rotax in their manual tells
you how to measure restriction of return.
Differential pressure is what you are interested in on a 914. A restricted
filter or gasculator, or plugged pre pump filter will restrict flow. If
you put your thumb over output of pump in one of the mentioned conditions
you probably have great pressure. The way the fuel pressure regulator
works, is it needs a specific flow for its internal designed restrictor to
restrict enough for "Crack" pressure to be achieved and begin flowing
fuel to carbs. Differential gauge can give you heads up to fuel
starvation. Thinner air, pumps worked harder, failure will most like be
not enough pressure. Thick air and 2 pumps running in parallel, or
restricting return line will most like fail in that more than 5PSI going
to carbs.
Ron P.
