		rehn(at)rockisland.com Guest
				 Posted: Mon Mar 19, 2007 1:48 pm    Post subject: battery |
				Was wondering what kind of batteries are being used out there. I am about to
 replace and am considering the Odyssey which has 680 amp cranking power and
 weighs in at 15lbs.
 Jerry
 914
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		carl(at)flyers.freeserve. Guest
				 Posted: Mon Mar 19, 2007 2:44 pm    Post subject: battery |
				You could look at the Red Top batteries. The Red Top 25 weighs in at 13lb
 with a similar cranking current.
 We used the Car/ Motorcycle type before (as supplied by Europa) and had
 nothing but problems. Since installing the Red Top eighteen months ago the
 engine starts like a dream. The Rotax 912 now cranks really well and nearly
 always fires up on the first attempt.
 Even after 3 months of no use (over the winter) and with no top up charge we
 still managed to start after 3 attempts. There was no noticeable loss of
 cranking power from the battery even after such a relatively long layoff.
 I think we paid approximately £100 stirling and IMHO worth every penny.
 Carl Pattinson
 G-LABS
 PS: Looking at the Odessy website I suspect they are the same as the Red
 Top - specs appear to be similar.
		topglock(at)cox.net Guest
				 Posted: Mon Mar 19, 2007 3:13 pm    Post subject: battery |
				Jerry,
 I've been using the Odyssey 680 for almost two years, without issue.  I
 turn the key, the engine turns over...
 Jeff - Baby Blue
 Jerry Rehn wrote:
  about to replace and am considering the Odyssey which has 680 amp
  cranking power and weighs in at 15lbs.
  Jerry
  914
		acrojim(at)cfl.rr.com Guest
				 Posted: Mon Mar 19, 2007 3:25 pm    Post subject: battery |
				Jerry
 I have a Van's RV-7A with the Superior IO-360 engine. We have the small 17
 Amp hour Odyssey installed.  We have put 320 hrs in less than a year, on
 this a/c, and the battery hasn't missed a beat. You have to see the cranking
 power in these small batteries, to understand how good they are....
 Jim Brown
 N398JB Europa
 N112B RV-7A
		bberube(at)tampabay.rr.co Guest
				 Posted: Mon Mar 19, 2007 3:37 pm    Post subject: battery |
				Jerry,
 We use the 635 or the 680 exclusively in all the aircraft whether it is the
 big lycomings, Jabirus or Rotax.  Good service and warranty from the dealer.
 Try not to let them go dead as they are difficult to regenerate with average
 battery chargers.  We take them back to the dealer and if they cannot get it
 to charge, they replace it.  Using a small Battery Minder works well if you
 have a keep alive circuit.
 Bob Berube
 Flight Crafters
		raimo.toivio(at)rwm.fi Guest
				 Posted: Tue Mar 20, 2007 1:33 am    Post subject: battery |
				I have The Odyssey and absolutely would like
 to purchase it again. It keeps its promises.
 Wishes, Raimo
 Raimo M W Toivio
 OH-XRT Europa XS Mono #417, completed
 OH-CVK C172 Skyhawk, under reinterioring
 OH-BLL Beechcraft C45, w radial engines (grounded)
 37500  Lempaala
 Finland
 tel + 358 3 3753 777
 fax + 358 3 3753 100
 gsm + 358 40 590 1450
 www.rwm.fi
				 Posted: Tue Mar 20, 2007 1:47 am    Post subject: battery |
				And my Odyssey 680 has now given faultless service for 5 yrs without even
 needing charging during winter lay offs. David Joyce, G-XSDJ
