norton(at)optonline.net Guest
Posted: Wed Mar 21, 2007 8:47 am Post subject: Instant building space |
Tom,
I think that it is doable but here are some considerations that I would
need to factor in if I were doing this...
1.) most containers are very long, but not very wide so that can make
some aspects of construction more difficult.
2.) they normally do not have any electrical connections so I would want
to put an electrical feed line, a sub-panel (distribution box) and
grounding rods. remember this is a metal box and all electrical
outlets need a little extra care in wiring (good luck if an electrical
inspector happens by...)
3.) they have no windows - so no light even in the day and
ventilation. Hot in summer, cold in winter, always stuffy. All these
can be easily addressed but you need to factor in the added time and
costs of these additions.
4.) probably the local zoning laws in Rockaway have size and offset
restrictions regarding use and placement of the container, if a neighbor
complains - its gone...
5.) access through the double doors at the end can be very frustrating,
and I'm not sure one can open and close those doors from the inside
without a bit of metal work.
6.) ground work to keep the container fairly level may involve some
yard work, one may not want to plop a 20 foot long container on uneven
soft wet ground.
In Budd Lake, the neighbors and town officials would have fits if I
tried to use a container as a (temporary) structure, but if I thought
I could get away with it I would.
An alternative would be to go over to 84 Lumber, they have pans for
building storage sheds, I would build a 10 X 12 shed (probably the
maximum without a permit to get started. when you need more space,
build a 4 foot section in the middle and move the rear of the shed
back. It won't draw as much attention.
