Looking for Engine Primer
swift(at)fuse.net
PostPosted: Tue Mar 20, 2007 7:07 am    Post subject: Looking for Engine Primer Reply with quote
Looking for engine primer - Kohler, or Essex 'push-pull' type for use on carbureted O-360.
Thanks!
Don Duke
swift(at)fuse.net (swift(at)fuse.net)
Hm: 513.321.4745
n616tb(at)btsapps.com
PostPosted: Tue Mar 20, 2007 10:07 am    Post subject: Looking for Engine Primer Reply with quote
Why not use the electric setup that Van’s sells? I love it. I put a push button on my panel; master on, boost on, push button for 1..2..3. start engine. Perfect.
Just a thought
Tim
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Don Duke
Sent: Tuesday, March 20, 2007 10:06 AM
To: rv-list(at)matronics.com
Subject: Looking for Engine Primer
Thanks!
Don Duke
Hm: 513.321.4745
rocketbob(at)gmail.com
PostPosted: Tue Mar 20, 2007 10:59 am    Post subject: Looking for Engine Primer Reply with quote
I've started many times in the cold in my RV-6 and never have used the primer. Two shots of the throttle while the engine is cranking does the trick every time. If I were doing it over I wouldn't put a primer system in.
Bob Japundza
RV-6 flying F1 under const.
jmsears(at)adelphia.net
PostPosted: Tue Mar 20, 2007 12:26 pm    Post subject: Looking for Engine Primer Reply with quote
>Why not use the electric setup that Van's sells? I love it. I put a push
>engine. Perfect.<<
I have that set up, except that I used a momentary toggle switch for
triggering the primer valve. I installed a T fitting downline from the
boost pump that's located on the firewall. Yeah, I chose to not install the
pump inside the cabin. One exit from the T goes to the primer valve. The
other goes to the mechanical pump. I' ve been using that setup since 1999,
installed it on a friend's RV-9A, and plan on doing the same thing for my
RV-7A, if I ever get that far. Smile
Jim Sears in KY
RV-6A N198JS (Scooter)
PostPosted: Tue Mar 20, 2007 3:18 pm    Post subject: Looking for Engine Primer Reply with quote
I don’t know about yours or all carbs, but I started one on fire this way. The updraft carb allowed the fuel to run out when it didn’t start right off. Then when it did, it lit the fuel. You never saw two adults scramble out of an airplane so fast.
Tim
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob J.
Sent: Tuesday, March 20, 2007 12:58 PM
Subject: Re: Looking for Engine Primer
Bob Japundza
tcervin(at)valkyrie.net
PostPosted: Tue Mar 20, 2007 3:21 pm    Post subject: Looking for Engine Primer Reply with quote
Bob, I put an electric primer in that primes all 4 cylinders and agree with you. I have never needed it in sunny tropical Ohio!! Waste of time and money!!!!!!
                      Tom in Ohio-RV6-A
lsbrv7a(at)yahoo.com
PostPosted: Tue Mar 20, 2007 5:55 pm    Post subject: Looking for Engine Primer Reply with quote
I agree with the fire hazard. However, this can be mininmized by only pumping with care once the engine is cranking. The prinmer goes directly into the cylinder, rather than the induction system.
Tim Bryan <n616tb(at)btsapps.com> wrote:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} I don’t know about yours or all carbs, but I started one on fire this way. The updraft carb allowed the fuel to run out when it didn’t start right off. Then when it did, it lit the fuel. You never saw two adults scramble out of an airplane so fast.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Tim
Bob Japundza
Sherman Butler
RV-7a Wings
Idaho Falls
Don't pick lemons.
See all the new 2007 cars at Yahoo! Autos. [quote][b]
ceengland(at)bellsouth.ne
PostPosted: Tue Mar 20, 2007 6:26 pm    Post subject: Looking for Engine Primer Reply with quote
Actually, it goes into the intake port. The fuel will still run out of
the carb; it just takes a little longer.
Charlie
Tim
[mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Bob J.
*Sent:* Tuesday, March 20, 2007 12:58 PM
*To:* rv-list(at)matronics.com
*Subject:* Re: Looking for Engine Primer
primer system in.
Bob Japundza
Sherman Butler
RV-7a Wings
Idaho Falls
Don't pick lemons.
<http://autos.yahoo.com/new_cars.html;_ylc=X3oDMTE0OGRsc3F2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3Y2Fycw-->
at Yahoo! Autos.
PostPosted: Tue Mar 20, 2007 7:50 pm    Post subject: Looking for Engine Primer Reply with quote
You have to do it *AFTER* you start cranking and you make it through the first compression stroke. If you pump the throttle before cranking then fuel will run out the bottom of the carb.
Bob Japundza
On 3/20/07, Tim Bryan <n616tb(at)btsapps.com (n616tb(at)btsapps.com)> wrote:[quote]
I don't know about yours or all carbs, but I started one on fire this way. The updraft carb allowed the fuel to run out when it didn't start right off. Then when it did, it lit the fuel. You never saw two adults scramble out of an airplane so fast.
Tim
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of Bob J.
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Bob Japundza
[quote][b] http://www.matronics.com/Navigator?RV-List http://forums.matronics.com [quote][b]
PostPosted: Wed Mar 21, 2007 4:42 am    Post subject: Looking for Engine Primer Reply with quote
In my case it was an unfamiliar airplane. The master had a key switch as well as a toggle and one of them wasn’t on. Just don’t forget to turn on the switch as the engine won’t start without it. Then when you turn it on, there may be left over fuel that ran out of the updraft carb.
Tim
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Sherman Butler
Sent: Tuesday, March 20, 2007 7:55 PM
Subject: RE: Looking for Engine Primer
Tim
Bob Japundza
Sherman Butler
RV-7a Wings
Idaho Falls
Don't pick lemons.
HCRV6(at)comcast.net
PostPosted: Wed Mar 21, 2007 12:39 pm    Post subject: Looking for Engine Primer Reply with quote
