jhstarn(at)verizon.net Guest
Posted: Fri Mar 23, 2007 6:43 pm Post subject: 567 data |
Went to Yahoo, search for "Loctite #567" this is a part of the manufactures
data sheet. KABONG Do Not Archive
LOCTITE® 567
June-2004
PRODUCT DESCRIPTION
LOCTITE® 567 provides the following product characteristics:
Technology Acrylic
Chemical Type Methacrylate ester
Appearance (uncured) Smooth, creamy, off-white pasteLMS
Components One component - requires no mixing
Viscosity High
Cure Anaerobic
Secondary Cure Activator
Application Thread sealing
Strength Low
LOCTITE® 567 is designed for the locking and sealing of metal
tapered threads and fittings. The product cures when confined
in the absence of air between close fitting metal surfaces and
prevents loosening and leakage from shock and vibration. The
high lubricating properties of this compound prevent galling on
stainless steel, aluminum and all other metal pipe threads and
fittings. LOCTITE® 567 is recommended for industrial
applications in the chemical processing, petroleum refining,
pulp/paper, waste treatment, textile, utilities/power generation,
marine, automotive, industrial equipment, gas compression
and distribution industries. It is also recommended for industrial
plant fluid power systems.
UL Classification
Classified by Underwriters Laboratories Inc.® as to fire
hazard only. Loctite® PST® 567 Pipe Sealant with PTFE. Fire
hazard is small. No flash point in liquid state. Ignition
temperature 465°C. For use in devices handling gasoline,
petroleum oils, natural gas (pressure not over 300 PSIG),
propane, and butane. 976P
