What have you done about defrost fan's ?
Deems Davis
PostPosted: Thu Mar 22, 2007 8:23 pm    Post subject: What have you done about defrost fan's ? Reply with quote
I'm planning on installing a couple of fans in the glareshield (upper
fwd fuse) and am interested in learning what fans people have used,
where they bought them and any install tips. I'm toying with the idea of
installing them in removable access panels ala David Mc Neil if it
doesn't introduce any structural issues. Any advice?
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
Deems Davis wrote:
Spel ckeck, we don tneed no stinking Spel check Razz
Deems Davis # 406
RV Builder (Michael Sausen) wrote:
> Matt bought KitLog?!? Wow, that’s cool! Maybe he will fix the problem
> where clicking next on a project web page takes you backward in dates
> instead of forward. That’ has always drove me nuts along with the run
> on paragraphs. Spell check would be great too. I also mentioned to
> Paul way back when I was beta testing his 2.0 release that adding the
> ability to attach files to entries like scanned receipts to expenses
> would be useful.
> Michael Sausen
> Do not archive
recapen(at)earthlink.net
PostPosted: Fri Mar 23, 2007 3:11 am    Post subject: What have you done about defrost fan's ? Reply with quote
I bought a couple of small pancake fans from radio shack, matching flanges
and scat tubing from spruce. I have mounted the fans under the topskin
centered in the through viewing area of the appropriate side. I dimpled the
through-skin attachment holes for #6 screws and drilled a bunch of #40 holes
for each fan's air to flow through. I will be wiring them to a switch
between both heater-cables and the scat will terminate so it scoops the
heated air at the firewall entry. Access is via my removeable instrument
panel so I don't have seperate panels for them.
My way for my 6A slider - not flying yet so I don't know if it'll even
work......
jwt(at)roadmapscoaching.c
PostPosted: Fri Mar 23, 2007 4:07 am    Post subject: What have you done about defrost fan's ? Reply with quote
Deems,
I mounted a couple of small computer fans under the glareshield. I used a
circle cutter but now wish I had just drilled small holes (easier and don't
have to add a screen). I wired them to a panel switch.
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
Paint prep and LOTS of misc stuff
LloydDR(at)wernerco.com
PostPosted: Fri Mar 23, 2007 5:17 am    Post subject: What have you done about defrost fan's ? Reply with quote
I used two direction heat ports, with flappers that can close each one,
then I used SCAT and a T to hook them together and terminated them to a
single fan port. This way you can get to it from down below and not have
to worry about it. Use the cheappo valves Van's gives for the panel for
this, and get the good ones from Stein for the panel.
Dan
N289DT
Dick Sipp
PostPosted: Fri Mar 23, 2007 7:05 pm    Post subject: What have you done about defrost fan's ? Reply with quote
Deems:
McMaster-Carr has a broad selection of fans...too many to pick from.
Dick Sipp
Deems Davis # 406
