rene(at)felker.com Guest
Posted: Fri Mar 16, 2007 6:22 pm Post subject: Phosphoric Acid |
Rene'
801-721-6080
Any ideas of where I can get some phosphoric acid?
Rene
N423CF
40322
Finish......or something like it.
LarryRosen
Posted: Fri Mar 16, 2007 6:37 pm Post subject: Phosphoric Acid |
Lowe's
Aqua Mix Quart Phosphoric Acid Cleaner $6.95
Larry
Rene wrote:
Rene'
801-721-6080
Rene
N423CF
40322
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
rvbuilder(at)sausen.net Guest
Posted: Fri Mar 16, 2007 6:43 pm Post subject: Phosphoric Acid |
Various soda's like Pepsi, naval jelly, or more commonly from Lowes Depot in the paint department as it's commonly used as concrete cleaner/etcher.
Michael
DAVELEIKAM(at)wi.rr.com Guest
Posted: Fri Mar 16, 2007 7:18 pm Post subject: Phosphoric Acid |
Try Coca Cola.
Dave Leikam
Jack.Phillips(at)cardinal Guest
Posted: Mon Mar 19, 2007 3:35 am Post subject: Phosphoric Acid |
Poly Fiber makes Aluma-Dyne E-2310 phosphoric acid etch cleaner,
available through Aircraft Spruce. A.S.S also selsl Alumiprep 33, which
is another brand of phosphoric acid etch for aluminum. The alumiprep is
about $30 a gallon, the Aluma-Dyne is about $45 a gallon. Same stuff,
as near as I can tell. I've used both. You need to alodyne or prime
within 8 hours of acid etching the aluminum.
Jack Phillips
#40610
