Trim Tab Riveting (was flutter at altitude)
Jack.Phillips(at)cardinal
PostPosted: Tue Mar 27, 2007 4:44 pm    Post subject: Trim Tab Riveting (was flutter at altitude) Reply with quote
John,
Are you talking about riveting the trim tab spar to the skin? I just
did that Sunday, and found the best way to do it was to back rivet it
using the 12" back rivet set from Cleaveland tools. I love that tool
and use it wherever I can.
Jack Phillips
#40610
jjessen
PostPosted: Tue Mar 27, 2007 8:33 pm    Post subject: Trim Tab Riveting (was flutter at altitude) Reply with quote
Yes. What a great idea, if I only had a 12" back rivet set! I did figure
out you can make do with a longeron yoke. Worked just fine, but it took my
brain awhile to determine that I had to mount the hand squeezer in a vise so
I could control the situation. I'll write it up and put it on the web site.
But if I had had the 12", that would have been a better approach. Thanks
for the suggestion!
John Jessen
Now for some proseal...
