naumuk(at)alltel.net Guest
Posted: Sat Mar 24, 2007 10:33 am Post subject: HD/HDS Arm rest sides |
Guys-
In a real pickle here. You'll have to follow closely.
I'm trying to install the arm rest sides. They don't come close to fitting without forcing the rear of the seat pan and channel forward about 10mm.
My plans clearly show, even emphasize the distance from the c-section spar web 535mm to the front of the rear pan.
1. I rechecked the distance and I'm within 1mm.
2. I checked the kit arm rest sides. Everything's dead on except the 138mm dimension which is 135mm. Shouldn't be a factor.
3. Like an absolute idiot, I removed the shims leveling the c-section thinking they might be distorting the pan. Nope. Now I have to re-level.
4. Checked the rear channel for bow. Nada.
5. Worked on the car for a while to clear my head and came up with another check. Put an angle gauge on the pan bottom to rear crossmember and came up with 60 deg. It's supposed to be 65. Reset the angle gauge and, guess what. Yep, the rear crossmember winds up 10mm forward.
Here's the kicker. If you index from the front of the spar cap rather than the spar web, you wind up 10mm forward and everything's hunky dory.
Everyone, please check you plans and see where your index point is indicated. If you ran into this while building and had to rebuild your way out, please let me know. For those of you who sleep next to your projects, another check would be the distance from the rear channel to the Z spar. (Please provide the numbers).
I'm looking at 2 weekends work to correct this mess and want to make absolutely sure before refabricating a half dozen components.
Thanks.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Posted: Sun Mar 25, 2007 7:28 am Post subject: HD/HDS Arm rest sides |
All-
Seems the reference point is correct. The other obvious explanation is that the print layout for the arm rest sides is incorrect. No indications that there will be any trouble if the rear of the seat pan is 10mm aft, but everything's right on except for the geometry of the arm rest sides.
I'm going to make a set of arm rest sides to fit the pan opening and get on with life.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
