Posted: Sun Mar 25, 2007 6:53 pm Post subject: Slick magneto harness question |
I have an I0540-C4B5 engine going on my RV-10 with a Slick 6393 magneto on the left side (lightspeed ignition on the right side). I need to get a Slick harness for the magneto. The book says I need a M2877, M6029, or a M6027 harness.
My first question is how can you tell how long each of the wires are in the above mentioned harnesses? Is there a chart anywhere where you can tell the length of each wire in the harness? I looked on the Unison (useless) web site with no luck.
My second question is that I cannot seem to find any of those harnesses anywhere for sale (at least online). Are these old numbers and there are newer ones that replaced it?
My last question: Does anyone else have a similar set up, and if so, what harness are you using on the left side? Do the wires route nicely, or are there some that are a bit longer and need to be doubled over to get the correct length?
Any help would be greatly appreciated. Thanks
-Mike Kraus
RV-4 Flying
RV-10 75% complete, 90% to go
Rhonda(at)bpaengines.com Guest
Posted: Mon Mar 26, 2007 5:33 am Post subject: Slick magneto harness question |
Mike:
I can’t answer the first part of your question, but I can the second. The Unison harnesses have a left side and right side part number independent of the whole part number. The two sided harness part number is probably something like a M6014. Unfortunately, you won’t have much luck finding just a left or right side harness. No distributors that I’m aware of carry them in stock, and Unison has something like a 60 day lead time. If you need it right away, you’ll have to order a whole harness and then use only the left hand side.
[i]Rhonda[/i]
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Kraus
Sent: Sunday, March 25, 2007 9:51 PM
Subject: Slick magneto harness question
-Mike Kraus
RV-4 Flying
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
sam(at)fr8dog.net Guest
Posted: Mon Mar 26, 2007 5:02 pm Post subject: Slick magneto harness question |
Try Wagaero, I think that's where I got mine.
Sam Marlow
Rhonda Bewley wrote:
Mike:
//Rhonda//
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Mike Kraus
*Sent:* Sunday, March 25, 2007 9:51 PM
*To:* rv10-list(at)matronics.com
*Subject:* Slick magneto harness question
-Mike Kraus
RV-4 Flying
Tim_Lewis(at)msm.umr.edu Guest
Posted: Mon Mar 26, 2007 5:54 pm Post subject: Slick magneto harness question |
I had a similar situation, except I used a Bendix mag. I ordered a 1/2 harness from Skytronics, El Segundo CA, 310-322-6284 or 1-800-421-6846. I ordered through Aircraft Spruce. They had me contact Skytronics via phone to make sure the details were right. Cost was $98 including shipping.
I'd recommend you call Skytronics with your situation and see what they say. If nothing else, you can run string from your spark plugs to your mag to estimate the required length of each lead.
Interesting note on customer service... somehow Skytronics sent me a right half harness rather than a left half harness. ACS and Skytronics corrected the problem with no hassles, even though it was a custom job (they had made my harness to order).
| Quote: | --
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 850 hrs
RV-10 #40059 under construction |
Mike Kraus wrote: [quote] Message I have an I0540-C4B5 engine going on my RV-10 with a Slick 6393 magneto on the left side (lightspeed ignition on the right side). I need to get a Slick harness for the magneto. The book says I need a M2877, M6029, or a M6027 harness.
-Mike Kraus
RV-4 Flying
