clouduster(at)austin.rr.c Guest
Posted: Sun Mar 25, 2007 4:12 pm Post subject: Capacitors for Whelen strobe power supply |
A friend gave me his Whelen strobe power supply. It was still cycling
but not firing the strobes. Whelen will not repair it because they no
longer support this unit. I checked the capacitors and found one of the
two main capacitors has low resistance - partial short I believe. I'd
like to try to make it work again for use in my RV 7A.
The capacitors are 400UF - 300 VDC. They were manufactured by Sprague
and have the # D77072 on the aluminum case. Also the numbers 7821L
19-03 are also on the case. Does anyone have a source I can purchase 2
from? I have looked on the web but don't know which capacitor design
these are - aluminum, electroletic, etc.
Thanks much,
Dennis H.
jmfpublic(at)comcast.net Guest
Posted: Sun Mar 25, 2007 10:08 pm Post subject: Capacitors for Whelen strobe power supply |
Dennis,
Digikey catalog lists 12 different capacitors, 9 of which are in stock, which would work for you if they fit mechanically. These are all 350v at 390UF units. You can use anything rated 300 volts or better, and the 400UF is rather approximate, as the electrolytics are rated + and - 20%. It seems that 390 UF is now commonly used. Prices run from the $5 to $7 range. I will try to send you the results of the search on the Digikey site privately. Below are 390UF at 350v units:
Diameter(mm) Length(mm)
P11920-ND 25 40
P11921-ND 30 30
P11790-ND 25 45
P11791-ND 30 30
There are others, but mainly the ratings differ for service life at rated temperature. The first two are 3000 hr at 85 degrees C, the next two are 2000 hr at 105 degrees C.
Search for these part numbers on the Digikey site, and they will lead you to all the information.
Jim Foerster J400 wiring-veerry sloooly
klehman(at)albedo.net Guest
Posted: Mon Mar 26, 2007 3:52 am Post subject: Capacitors for Whelen strobe power supply |
Careful guys. There is more to this.
For proper performance and decent life you need "photoflash" capacitors
specifically designed for fast high current discharge.
They tend to be more difficult to find.
Ken
James Foerster wrote:
| Quote: | Dennis,
P11920-ND 25 40
P11921-ND 30 30
P11790-ND 25 45
P11791-ND 30 30
