JAPhillipsGA(at)aol.com Guest
Posted: Mon Mar 26, 2007 7:58 am Post subject: RV8-List Digest: 2 Msgs - 03/25/07 |
Stan, thanks for the info, Bill
AOL at http://www.aol.com. [quote][b]
| - The Matronics RV8-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
aerobubba(at)earthlink.ne Guest
Posted: Mon Mar 26, 2007 2:22 pm Post subject: RV8-List Digest: 2 Msgs - 03/25/07 |
Bill-
Quote: | I live in Forsyth, about 25 miles north of Macon. I'm building my 8 in my shop
there. Question: when do you ProSeal the duct face to the bottom of the right
wing ?
Whenever it's convenient...
Quote: | Is there any way to clamp it to the metal without drilling and dimpling
Sure. Duct tape to locate it, and a block of wood wedged between the inlet and the opposite skin to hold it tight.
Quote: | Should the duct hose be connected at attachment or can I get to the rear of
the duct after the glue cures ?
I found it easier to have the duct attached during the gluing process.
FWIW-
Glen Matejcek
Posted: Mon Mar 26, 2007 2:29 pm Post subject: RV8-List Digest: 2 Msgs - 03/25/07 |
Hi Dennis
Quote: | Has anybody out there ever sucessfully mounted an oil cooler on the firewall
of an 8? If so do you have pictures?
I hung mine from and between the enging mount tubes aircraft right. Angle on the coler mounting flanges connects to the eng mount tubes with P clamps. There is an aluminum angle strut from the upper eng mount tube to the outboard edge of the cooler make it rock solid. A 4" scat picks off the right rear baffle and makes about a 90 deg turn downward. This connects to a composite diffuser that mounts to the face of the cooler.
So far, so good. We'll see how it works when it flies!
Glen Matejcek
