[jabiruengines] Pete please read this about my EGT...
Skypics234(at)aol.com
PostPosted: Tue Mar 27, 2007 2:13 pm    Post subject: [jabiruengines] Pete please read this about my EGT... Reply with quote
Allen:
Not only does the distance from the exhaust flange affect the reading, but also the tip of the probe should be in the center of the exhaust pipe.
In other words...
If the probe is inserted to deep or too shallow the temps will be lower.
Personally I believe your EGT is acceptable if 1480 is all you get with it being 1/2 the distance called for. Assuming this is your hottest and it is in lean cruise.
My number 4 runs As high as 1500 in lean cruise 2600-2800 RPM.
John M
AOL now offersle="http://www.aol.com?ncid=AOLAOF00020000000339" href="http://www.aol.com?ncid=AOLAOF00020000000339" target="_blank">AOL.com.
